Question about ASUS m6n Notebook
RAM upgrade for Asus AR9p notebook.
Hey ho,
I have the abovementioned computer and would be gratefull if someone could tell me what type of ram I need to buy and how to get to the slot (there are no convenient little hatches on te bottom of the unit) to insert it.
    Sergeant:
  • 458 Answers
ASUS has a great website and it will have the directions listed under the model of your system. They have everything that you will ever need there.
Rate me as FIXYA if this helps.
Posted on Jun 05, 2008
  • Anonymous Jun 09, 2008
    Did you figure out what you needed to know. If you could not find out, let me know the entire model number and I can find it for you. I know that site very good. They break down everything and tell you what memory that they have tested for your system. That model number that you have is not complete. If you can not find the complete model number, give me the serial number or anything else that you see on it. I can contact them for you and see what I can find out.
    You should be able to unscrew a cover off of the back of the laptop. That is the normal place for ASUS to put the memory. How old is the laptop?
SOURCE:
What type of memory is used in an Asus Notebook UX302LA-BHI5T08?
The unit has both built in memory + a slot available for 12800 Ram modules.
Jun 17, 2014 | ASUS U Computers & Internet
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
Model type & number of 512mb or 1gb ram memory for
There are many different specifiactions for RAM.
Firstly is it Desktop or Notebook RAM that you are looking for.
Below is a list of RAM specifiactions:
DDR
DDR2
DDR3
Now these RAM specifiacations run at different clock speeds.
For example:
DDR 400MHz
DDR2 800MHZ
DDR3 1333MHz
What I need you to do is to tell me the following:
What is it to be used for, Desktop or Notebook/Laptop?
What is written on the RAM modules? You may need to remove one from your computer or use a software program like CPU-Z to check what it is you are running in your computer.
Reply via a comment to this post!
Take care!
damnor01
Sep 13, 2011 | ASUS Computers & Internet
What kind of RAM does this computer use, want to upgrade
Hey there, the easiest way to figure out what you can do as far as a RAM upgrade is go to www.crucial.com and run their little scanner program. This will tell you what you have and what can go into your computer. You do not necessarily have to buy their RAM, but it is a useful product.
seth
Jun 26, 2009 | Dell Latitude C640 Notebook
Is it possible to upgrade my k8smx motherboard to
Look for bios updates in Asus website... i'm sure you'll find information about that.
Best Regards
Jun 24, 2009 | ASUS K8S-MX Motherboard
Ram Upgrade
Yes, you can increase the RAM of your Asus X53L, but first, please review/check the product manual of your laptop on what type & maximum capacity of RAM will its motherboard can support & compatible. Any Brand of RAM will do as long as your laptop motherboard is compatible wih & can support its capacity, this is being made to ensure best operations performance of PC. regards
May 12, 2009 | Computers & Internet
Use of DDR2 RAM in ASUS MOTHER BOARD
This motherboard only support DDR type of RAM up to 4GIG , 400 MHz • 333 MHz this are the support speed of DDR RAM, so you can go ahead upgrade up to 4 GIG of RAM and that will make your computer very fast...
Nov 04, 2008 | ASUS GeForce® 4 V9180SE MX 440, AGP...
Where is the expansion slot for the RAM for ASUS Notebook A2400H?
The manual is incorrect. Memory is under keyboard. There is a small hole to the left of the right speaker. insert a paperclip vertically into the hole and apply a slight amount of pressure at the same time sliding the plastic section to the left. It should be obvious at this stage. then fold back keyboard. 2 memory slots are located under the plate near the middle of the unit. Specs say max of 2 x 512MB modules. they are PC2100 DDR266 200 pin SODIMM. If there is someone else reading this maybe they can tell me what the slot is for under the smaller plate to the right of the memory compartment.
Cheers.
Aug 06, 2008 | ASUS A2H (A2HOB) Barebone
ASUS Ram Location
look in the manual on page 16.shows where its located.
http://dlcdnet.asus.com/pub/ASUS/nb/A2H/e1309_a2_hw.pdf
Apr 04, 2008 | ASUS A2400H Notebook
Info question, RAM
Well this question is too vague! I need to know specific Model of your PC is it 2560, 2570? What is the model Number as this is very important when doing an upgrade of any kind to any type of PC! I have an answer just need specific model!
Nov 27, 2007 | Computers & Internet
ASUS m6n Notebook Logo
241 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
