Question about Hyundai Televison & Video
Hyundai LCD/TV Imagequest E32OD
When reviewing the electronic program guide (EPG), then selecting the relevant program selection' The outlined paragraph giving the story line and / plot of the program, only show the beginning section of the paragraph.
I've tried rescanning the TV channels, scrolling up/down/left/right on the paragraph but still same problem of only half the paragraph.
Also, when scrolling through the channels via the remote controller, the title of the previousn program is still evident, i.e. it dosen't refresh to the current program.
Please advise, and I will respond accordingly.
Rgds
Brian Taylor : emai;l nisan14b@hotmail.com
SOURCE: Channel changing on PROSCAN 32LA25Q
I had the same problem, what fixed it for me was to set auto scan to setup all the channels for me again. Another thing to check would be whether it is set up to use CATV or AIR.
Posted on Dec 30, 2007
SOURCE: set top box and remote control
the piece of electrical tape over the cable box worked - genius!!! (I have the 46" aquos from 2007, and the SA 8300HD). Thanks again
Posted on Jun 14, 2008
SOURCE: tv guide on our LG tv
It is NOT the main board. You need a V CHIP UPGRADE "epk file" Email me and I can walk you through it, very easy introspectionx2@yahoo.com Put "TV GUIDE" in the subject line
The problem started with TV GUIDE messing with things while they are doing their digital conversion
Posted on May 14, 2009
h_caines
  • 8 Answers
SOURCE: Comcast Remote Control Code
10150 worked for my mitsubishi wd65737
Posted on Jun 17, 2009
  • 285 Answers
SOURCE: Need code to program Direct TV Remote
I do not think your remote will support that. Use DTV remote to change channals, IMGQ remote to change volume, input, and power.
Posted on Jul 03, 2009
EPG WILL NOT WORK ON PHILIPS 42PFL9703 TV
Philips - Support Forum
www.philips.com/supportforum
PhilipsHere you can discuss all topics related to using Smart TV and Smart TV apps. Also find topics on IP-EPG, HbbTV, MHP, and Google Play store apps on Philips TVs Powered.... First of all JorisM, you're not the only one with this kind of Problem.Missing: 42pfl9703
No EPG data when using WEP EPG ' MediaPortal Forum
forum.team-mediaportal.com > ... > Electronic Program Guide > WebEPG
Jan 1, 2010 - Remote: Microsoft remote. TV: Philips 42pfl9703. TV - HTPC Connection: HDMI Hi, can use some help here. I can not get web EPG to work.
Powerscheduler shuts down PC too early during WEB EPG grabbing ...
Feb 8, 2010 - TV: Philips 42pfl9703 ... I found that data is loaded, but randomlystopped. ... EPG grabbing is busy, but still the system shuts down to early.
DVDR 7250H missing EPG problem - Philips - Digital Spy Forum
Jan 30, 2016 | Philips Televison & Video
Record a programme a day ahead?
What make and model are you using? Do you have the user's manual? Most DVRs have an electronic program Guide where you find the program on the day you want and you simply select it for recording. The little iView 3600STB II I have for over-the-air TV recording can only list one station at a time and at most only about 12 hours ahead of time. So when I want to record something on the next day I can't do it unless I do within that 12 hour time frame. (NOTE: The instructions in the user's manual says that the box EPG will show one week's worth of programming, and as I've just said I've never seen it list more than 12 hours worth of programming and most times less than that.)
Oct 11, 2014 | Televison & Video
The channel guide only shows no information available most of the time
sidbashford
You are getting that message because the receiver is not updating the Electronic Program Guide (EPG). Try unplugging the receiver from your electrical outlet for about 10 seconds (make sure all lights on receiver go out) and plug back in. This will cause the receiver to reboot and re-acquire satellite signal. Allow it also to download the program guide. After you get your channel back, pull up your guide, go into the future to see if it updated.
If it did not update, you'll need to run a check switch test. Press Menu on your DISH remote; should have Main Menu on TV screen. Press 6 (System Setup), 1 (Installation), and 1(Point Dish). Highlight the CHECK SWITCH button on the upper right of the screen and press the Select button on remote. On the Installation Summary screen, highlight the TEST button at the bottom of screen and press the Select button on the remote. This will initiate the test. Allow the test to complete. Once completed, exit out of each screen till you get to Acquiring Satellite Signal on TV screen. After acquisition completion, allow it to download the program guide. If this doesn't fix the problem, you may need a new receiver. I hope this helps.
Ray Calo
DISH Network
Feb 26, 2011 | Televison & Video
My Hyundai B70A's screen is blank grey. I've changed the power supply, the vga cord and the video card with no change. What should I do now?
If you get just the grey glowing screen (as shown in my guide), it means that the T-CON board on the LCD panel is not getting the 5 or 12vdc from the logic board or it has blown fuse on the T-CON board due to shorts circuits, not much you can do but replacing the LCD panel.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 15, 2010 | Hyundai ImageQuest ImageQuest B70A (Black,...
Hyundai n71s with the screen always white
not transistor, but it's capacitor problem. It's happen almost to all kind of LCD monitor and TV, just click here to solve your problem.
dm
Mar 30, 2010 | Hyundai Electronics ImageQuest N71S 17"...
How to use EPG
EPG or Electronic Programme Guide is the on-screen version of a tv guide for digital tv. The remote control usually has a dedicated button for the display of the EPG.
The information displayed is often incomplete and some digital boxes or tv sets perform better than others though in theory it needs no setting up. Once the box has searched and made a channel list the programme guide will be available.
Nov 17, 2017 | Pinnacle Televison & Video
Hyundai imagequest B90D orange standby
hyundai will not repair this however a electronic service center aka tv repair may. I can do it as most likely is it several capacitors that have blown. Hyundai is also a little picky to open they are assembled very well actually compared to other monitors (they are difficult to open up) let me know what you would liek to do.
Nov 13, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Pioneer dvd recorder dvr-530H
The EPG is the electronic program guide trying to download TV listings.
http://en.wikipedia.org/wiki/Electronic_program_guide
This is normal for this player. To disable this, you would need to turn off the TV guide function.
Sep 28, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Televison & Video Logo
50 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
