Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Problem with oracle
I have installed oracle9i on windows xp. the installation process was successful but the database configuration failed.then if i run the sql plus with (scott, tiger or system , manager) as username and password.i got a error.
Oracle not available
Posted on Apr 04, 2008
SOURCE:
DBF file lost after OS reinstalled
Some helpful resources for you:
Non-commercial project, which can give you an alternative view to your issue:-
http://www.filerepairforum.com/forum/databases/databases-aa/dbase-iv-clipper-foxpro/429-how-can-i-open-corrupted-dbf-file-via-ms-foxpro
One more method, must be DBF Fix Toolbox - this is shareware software
You may download its demo: http://www.dbf.fixtoolbox.com/ - who knows, apparently it also can resolve the trouble.
Another fresh alternative way
The new database is useless. Drop it and its associated service.
Copy your files, all the database files (control file, redo logs, data, configuration files...) in the new hardisk, if possible at the same location (directories).
Then use oradim to create the service: oradim -new <sid> -startmode manual
Start the service if it is not already started.
Execute sqlplus "/ as sysdba" and try a startup.
If all files were copied in the same location, this should work.
Nov 01, 2014 | Oracle Computers & Internet
I installed oracle 10g express edition.now I dono how to remove it. please let me kno how to uninstall it.I even stopped the oracle services but i dino abythin further.
Follow these steps:
  1. Open the Windows Services utility: From the Start menu, select All Programs, then Administrative Tools, and then Services.
  2. If any of the following Oracle services exist and have the status Started, then select each of the services, and click Stop:
    • OracleXE
    • OracleXETNSListener
    • OracleJobSchedulerXE
    • OracleXEClrAgent
    • OracleMTSRecoveryService
  3. Exit Services.
See also the Microsoft online help for more information on stopping services.
7.2.2 Step 2: Remove the Oracle Database XE Registry Editor Settings Follow these steps:
  1. Log on to Windows with Windows administrative privileges.
  2. Ensure that you followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop the Oracle Database XE services.
  3. Start the Registry Editor at a command prompt:
    SYSTEM_DRIVE:\> regedit
  4. Go to HKEY_CLASSES_ROOT.
  5. Delete the following keys:
    • NEED TO CONFIRM THE XE-SPECIFIC ONES.
  6. Go to HKEY_CURRENT_USER\Software.
  7. Under Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Start Menu\Programs, delete the Oracle Database 10g Express Edition key.
  8. Go to HKEY_LOCAL_MACHINE\SOFTWARE and search for the ORACLE group key.
  9. Expand the ORACLE group key and then delete the KEY_XE and OracleMTSRecoveryService keys.
  10. Go to HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI.
  11. Expand the ODBCINST.INI key and remove the Oracle in XE key.
  12. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services.
  13. Delete the following keys:
    • OracleServiceXE
    • OracleXEClrAgent
  14. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog\Application.
  15. Delete the Oracle.xe key.
  16. Exit the Registry Editor.
  17. Restart your computer.
7.2.3 Step 3: Update the System Variable Path Follow these steps:
  1. Open System from the Control Panel.
  2. In the System Properties dialog box, click the Advanced tab, then click the Environment Variables button.
  3. Select the system variable Path and edit the Path variable to remove the Oracle Database XE entry. For example:
    C:\oraclexe\app\oracle\product\10.2.0\server\bin;
  4. Save your changes and then exit the Control Panel.
7.2.4 Step 4: Remove Oracle Database XE from the Start Menu and Desktop Follow these steps:
  1. Select Start, then All Programs, and then Oracle Database 10g Express Edtion.
  2. Right-click Oracle Database 10g Express Edtion and from the menu, select Delete.
  3. On the desktop, right-click the Get Started with Oracle Database 10g Express Edition icon and from the menu, select Cut.
7.2.5 Step 5: Remove the Oracle Database XE Directories Follow these steps:
  1. Ensure that you have followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop all Oracle Database XE services.
  2. From the Windows Explorer, navigate to the directory where you installed Oracle Database XE, for example, c:\oraclexe.
  3. Right-click the Oracle Database XE installation directory and from the menu, select Delete.
7.2.6 Step 6: Install and Run the Windows Installer CleanUp Utility Run the Windows Installer CleanUp utility to remove the Windows Installation configuration information for the Oracle Database XE installation. You can download it from Microsoft at:
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
he deinstallation completes, click Finish.
Sep 14, 2010 | Oracle Database 10g
I want to install oracle 8i in windows 7, how i do this?
sir, i have a window7 in all in one hp but there is a software called mstar which run on oracle 8i when i install the oracle 8i there is a problem and show dll file corrupted. Pls tell me the solution because my client want it very urgently and i am not able to install and run the programm.
Feb 26, 2010 | Veritas Cluster Server for Solaris Oracle...
How to install oracle 9i in vista ?it is not supported.
Your best bet is to look on metalink and search for the error code you are getting. Oracle is very particular about what versions work with specific OS's
Oct 03, 2009 | Microsoft Windows Vista Ultimate Edition
I didn't know how to uninstall oracle 10g enterprise edition.
Dear sir
Please do the following.
start>run> ( please type services.msc)
in services window you can find some oracle services.
please stop all the services by right clicking.
after that you can uninstall the oracle software.
again you can reinstall the oracle.
please vote.
regards
murali
Feb 15, 2009 | Oracle Database 10g
Uninstall oracle 10g database
hve uninstalled oracle 10g from xp!! but still one program is left over say oracleserviceXE, that i could not find!! how to remove this, to install the s/w again!! plz kindly help me regarding this
Jun 01, 2008 | Computers & Internet
Installation of oracle9i
dear friend
if u wan to uninstall yr oracle 9i u need yr installaction cd.
then yr cd run installaction precess it's show all installed compantant then i selicket compotant which u want to uninstall then ckick next it's precess to unintall.
don't forget to vete thanks in advance...
thnaks for using fixya.
jo_Chinmay
Mar 31, 2008 | Computers & Internet
Windows xp pro oracle 8i database access very slow
check your computer comfiguration check the ram for memory
Nov 28, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
130 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
