Question about AOpen vKM400Am-S Motherboard
Aopen vkm400an-s hi i have a aopen vkm400an-s with a sempron 2800 fitted and pc2700 333mhz ram. my bios says i have a athlon 2400 fitted running at 1.6ghz.as far as i am aware the 2800 should run at 2ghz. i think the bios needs updating for the sempron but an unable to find one for this many thanks martyn
  • bones698 Apr 06, 2008
    my bios version is R1.09 already and it still wont detect it,very strange.i have managed to overclock it to around 1.8ghz but still cant get the bus speed to the 166mhz it should be for this processor
    my bios is version R1.09 already but still no joy i have overclocked it to 1.8ghz but still cant get the bus speed to 166mhz which it should be.any other ideas would be appreciated
    thanks
    bones
    President:
  • 2,351 Answers
Hi bones698, you can go to the link below & check the bios's listed for your vKM400Am-S board.
http://download.aopen.com.tw/Default.aspx
You will need to fill in the three dropdown windows as follows:
Motherboard
vKM400Am-S
Bios
I have gone over ever bios listed at AOpen.
There is one update for AMD Sempron Processor's. Version R1.01 Release date; 7/27/2004 Please double check your system at boot up for your version. Use the Pause/Break button on your keyboard to freeze your screen. This will give you the time needed to check your current bios version. To flash your bios go to pg. 40 in the manual.
Good Luck! Take your time.
Mike
Posted on Apr 05, 2008
  • Mike Peluso
    Mike Peluso Apr 05, 2008
    Hi martyn, If you want to increase your CPU manually you would need to change the CPU multiplier.
    (Take baby steps while doing this), or you'll cook the CPU.
Asus m3n78-vm ram increase
Well, how much have you got? and are you running a 32 or 64 bit OS? For the Max ram you can fit to your mobo go to the ASUS site and look at the spec for your board. If you have a 32 bit os you cannot use more than 3.7 GB of ram, you can use as much RAM as you can afford or will fit if you have a 64bit OS.
Apr 04, 2013 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
Hi, does any one knows about which type of RAM is suitable for the mother board MS-7168 VER 1C for the HP PC and whats the max capacity mine has only got a 512mb and i can see it has four ram slots in the...
Here you go....
CPU Support
  • Socket 939
  • Support AMD Sempron, Athlon 64 and Athlon 64FX processors.
  • Support 800 and 1000Mhz HyperTransport (HT) interface speeds.
System Memory
  • Four 184-pin DDR SDRAM DIMM sockets.
  • Serial Presence Detect
  • Support for single-sided or double-sided DIMMs (DDR 333 / DDR400)
  • Support for up to 4 GB system memory
  • Asynchronous HyperTransport and memory controller interface speeds
  • Supports dynamic link width and frequency change
  • Non-ECC RAM (ECC memory will run in non-ECC mode)
  • Single and dual channel mode operation:
    • Single channel mode with single DIMM, non-symmetrical population or non-identical DIMMs
    • Dual channel mode with 2 or 4 identical DIMMs, populated symmetrically
Sirwriter
Nov 14, 2009 | Computers & Internet
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
I would like to find the spec manual and what cpu slot it has.
I tried to get the exact link, but the website will not allow it.
Go to this page, and put in your model number, and you will find it really easy.
http://support.asus.com/download/download.aspx?SLanguage=en-us
This board is a socket A for AMD processors.
You will need adobe reader to get this manual.
Apr 16, 2009 | ASUS A7N8X Motherboard
Amd 2800+
tried another motherboard ? that will tell you if you git a burned processor
Sep 09, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
Bios version
Hi bones, you're sempron's revsion may not be compatable with you're board. I suggest you call AOpen's tech support.
For US Technical Support Line: 1-510-489-8928
For other AOpen numbers click the link & scroll down the page.
http://www.aopen.nl/about_ContactUs.aspx?Top=Y
Luck!
Mike
Apr 06, 2008 | AOpen vKM400Am-S Motherboard
Sempron 2800 cpu speed
hey, here is the latest bios witch is required for your new sempron!
http://download.aopen.com.tw/userdownload_List.aspx?RecNo=9923&Model=vKM400Am-S
Dont foget to rate the solution as fixya! Thanks
If you need more assistance let me know, I'm here to help
Apr 02, 2008 | AOpen vKM400Am-S Motherboard
Ak77 8x max
a bootable will work out
Jan 05, 2008 | AOpen AK77-8X Max (91.8A710.101)...
Cpu size
Hi handydak
For your Mobo
VKM400 AM-S Try this link it will tell you what max size CPU & Memory you can install to improve performance.http://download.aopen.com.tw/Default.aspx
Regards,
ajb2000
Dec 28, 2007 | AOpen vKM400Am-S Motherboard
AOpen vKM400Am-S Motherboard Logo
103 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
