Question about Cameras
I have a samsung camera s630.it keeps on telling me the batteries are low.ihave replaced them twice with the same result.
  • andersona Apr 10, 2008
    solution#1.not applicable.solution#2did not work.
    Genius:
  • 1,226 Answers
VErify the charger maybe cannot recharge or have and error and then reset all the setting of the camera. melnavz
Posted on Apr 10, 2008
  • Emelio Navaja
    Emelio Navaja Apr 10, 2008
    do you still use the camera, If the camera shut off automatically and after low bat indication, maybe there something grounded connection inside, and the camera detected and indicate low battery. if you can do disassebling your camera you may do to seat all the parts in order. but be carefull camera parts is sensitive. You may let service center to troubleshoot what is in it without risk in your part. or you can contact samsung in their website (www.samsung.com) under 'contact us" in the bottom of the page.
    melnavz
  • 790 Answers
Try resetting ur camera by leaving the batteries out & pressing the power button!!
Samsung S630 camera says "low battery" then shuts off
This camera needs rechargeable batteries usually lasts about a week with much use. I thought what a waste of batteries then tried these rechargable and the situation hasn't occured . it is probably because it is small digtal camera which uses alot of power.
Dec 31, 2008 | Samsung Digimax S630 Digital Camera
Samsung s630
Not a solution, but empathy. I'm having exactly the same problem.
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Low battery
Your cam has a not so rare battery drain defect, mine had the same problem.
call Samsung and send yours in, they will either fix it or give you a new one.
May 26, 2008 | Samsung Digimax S630 Digital Camera
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
Dec 23, 2007 | Samsung Digimax S630 Digital Camera
Battery Killer
When I got my s630 at first it went through batteries like crazy. Than I changed the battery type, like you did, only, mine started working just fine. I would try contacting Samsung on their website, and if your still in warranty, if it is a technical problem, they will replace your camera, or at least fix it. It's worth a shot, I guess.
Dec 07, 2007 | Samsung Digimax S630 Digital Camera
Samsung s630
well uhmm same thing used to happen to me you have to get really good batteries or just buy a charger the chargers easier
Nov 23, 2007 | Samsung Digimax S630 Digital Camera
Problem in s630 digital camera
There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set- Up 2
- Select Battery Type
Under Battery Type there are two options:
- Alkaline- if you are using non- rechargeable batteries
- NiMH- if you are using rechargeable batteries
Nov 19, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
