Question about IBM ThinkPad R50e Notebook
Memory upgrade Hi, I am having problems plugging a memory upgrade into the slot underneath the laptop. I can't get it to stay in place. Can anyone give me some advice?The laptop is an IBM thinkpad r50e. Thanks
  • derek30 Apr 03, 2008
    Hi J,
    Thanks for this.
    I was trying to slide it into place but couldn't get enough purchase on it to push it in the last little bit. But it clipped into place once I put it in at 45 degrees.
    Do I need to do anything else now to the laptop or does it recognise the memory straight away?
What do you mean by you cant get it to stay in place.
Usually you put it in at a 45 degree angle and press gently until it goes in no more, then you lower the chip until it clicks in on the board.
Hope this helps.
J
Posted on Apr 03, 2008
  • JAE52110 Apr 03, 2008
    Hi Derek,
    It should recognise it automatically, but just to be sure, when you turn on the machine press F1 and look at the memory displayed.
    I dont know how much you have installed just now but it will show you the total memory.
    J
I have a Northgate laptop 755110. I upgraded the
Some laptop keyboards have small "tabs" on the edge closest to the LCD screen, and those tabs fit "under" something metal,
in order to hold the keyboard in-place. Gently "work" that area, to get those tabs to move "above" (instead of "under"), to release the keyboard.
Apr 27, 2010 | Northgate Computers & Internet
1. Has anyone installed 2Gb RAM memory in a Sony PCG-TR3A? please give details of memory specification. 2. Has anyone installed a HDD bigger than 40GB? please give me details of HDD specification.
You can only upgrade the memory to 1GB in that model Vaio laptop.
The memory supported is DDR SDRAM which runs at 333MHz. There are 2 memory slots which support 1x512 module in each slot.
I recommend Kingston RAM as the manufacturer.
As for the HDD the laptop supports EIDE (IDE/ATA) hard drive. you can have anything up to 320GB. Seagate are excellent drives as well as Fujitsu.
Regards.
Sep 29, 2009 | Sony PCG-TR3A Notebook
How to install RAM?
You can get detailed description of how to install the ram in the below link
http://www.helpwithpcs.com/upgrading/install-laptop-memory.htm
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 05, 2009 | Toshiba Tecra M7 Tablet PC
How do you remove and replace dell laptop memory? (d600)
I dont know this particular model, but usually it's underneath the computer, there is one screw to remove and you can take out a door which gives you acess to the memory slots. If it's not there, you will need to remove the top cover to get there. But it's most likely a small door underneath the laptop.
Jun 03, 2009 | Dell Latitude D600 Notebook
II need to upgrade the memory, and this means taking the laptop to peices. can someone please post a how to for this, thanks
The other slot is located under the keyboard on the top of the motherboard - not under. There may be screws on the bottom that secure the panel above the keyboard. Remove the panel and you will see the screws securing the keyboard. If you are careful, you may not have to disconnect the keyboard connector.
May 24, 2009 | eMachines M5116 Keyboard
Hi there, Just wondering if someone can help me. I just received today two 1GB memory modules so I could upgrade my laptop. Only problem is, It states on numerous sites that my laptop has two memory...
Here is the link for the Toshiba Satellite M105-S1021 manual. It is zipped and you can download it to your machine. It will tell you exactly how much RAM you can hold and where it is located.
Please don't forget to rate this solution.
Jan 09, 2009 | Toshiba Satellite M105-S1021 Notebook
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Memory slots?
I found the solution to roger2 and my own problem. The secondary memory add-on slot is on the bottom of the unit, and can be accessed by removing one screw and the slot cover. The other, main memory slot is actually located underneath the keyboard. You should shut down the computer completely, unplug the power plug, and also remove the laptop battery before installing memory. Also, it may void your warranty if you mess around inside of your laptop, so please keep this in mind. You will need to take a very thin flat head screwdriver to gently pry up the panel above the F1-F12 keys. The panel is the entire plastic piece covering the speakers that has the power on, play, stop, ff, rw buttons on it. I used a very thin and flat hair clip that I found laying around to pry up the edges starting from the Pause/Break key moving left towards the ESC key. The screen lid has to be opened all the way for the piece to be completely removed. Once that is taken off, you will see two small screws holding the keyboard in place. Remove these two screws and gently pull out the thin ribbon cable connecting the keyboard to the laptop. The ribbon cable is located directly underneath the spacebar, so move slowly and carefully when removing the keyboard so as not to damage anything. In the center of the exposed area, there is a sort of rectangular metal cover with two screws holding it in place. The one that is about the same size as the slot cover on the other memory slot is the correct one. Remove the screws and open the metal cover. Underneath is the other memory slot. After you install the other memory stick, if you have 4 GB of total RAM, you should know that in 32-bit operating systems, Windows will only be able to use approximately 3.0-3.5GB of RAM. This is because of a limitation of 32 Bit Windows operating systems, and not because of the RAM itself. Only 64-bit operating systems will be able to use all 4 GB. On my system for example, I have the same Toshiba M105-S3041 laptop as you do, running Windows XP Home with two 2 GB sticks, and My Computer properties shows that I have 2.99 GB memory.
Oct 28, 2007 | Compaq Presario Notebook
Acer Aspire Notebook 3694 wlmi
First thin you have to remember is if you want to have to memories in parallel...Then the new one should be of the same size and frequency(ex:133Mhz,533Mhz..etc.,)Then folow these steps:
  1. Turn off the computer and remove all power cords from the computer system.
  2. Locate the panel used for access to the memory modules. This is generally located on the bottom of the laptop computer. Refer to your laptop instruction manuals for locating the panel.
  3. Remove any screws that the panel in place and place somewhere safe to prevent losing it.
  4. Remove the panel from the laptop and set aside.
  5. If replacing or upgrading an existing memory module, remove the memory modules by undoing and module clamps and gently lifting the edge of the module to a 45-degree angle and then pulling the module out of the slot.
  6. Align the notch of the memory module with that of the memory slot and gently insert the module into the slot at a 45-degree angle.
  7. Once all the pins are in the slot, gently rotate the module down flat until the clamps lock into the module into place.
  8. Replace the memory access panel onto the laptop computer.
  9. Replace any screws or fasteners that hold the panel in place.
  10. Replace the power cord and power up your computer system.
Step 1:
Step 2:
Step 3:
Step 4:
Step 4_1:
Step 5:
Step 6:
Step 7:
Oct 26, 2007 | Computers & Internet
Memory upgrade
Oct 13, 2007 | Acer Aspire 3610 Notebook
IBM ThinkPad R50e Notebook Logo
43 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
