Question about Zebex 90940-RS232-9 Handheld
How can I determine input whether coming from keyboard or scanner?
I'm using zebex wedge scanner on my vb application. The problem is I can't determine whether input is coming from the keyboard or scanner. Would you like help me?
Why you need to know from which it is comming? As a wedge is 2 inputs is merged as 1 output. There is no way to tell unless you use special coding in the BArcode that cannot be manually keyin. If I know your need maybe there is a altermnate way to do it.
Posted on Aug 07, 2008
SOURCE:
My scanner is scanning but why it's not coming in system notepad while scan sound everything is ok fine?
Your scanner may be set/programmed for a mode other than "keyboard wedge". Scanners typically come with a quick start guide with multiple barcodes that you can scan to program the scanner for your particular needs.
If you are trying to scan into Notepad or other text application, you will want to make sure the scanner is in keyboard emulation/wedge mode, and if you want it to have a "return" or "tab" after the scanned barcode, you should have options for that also.
If you have a used scanner and do not have the quick start guide or manual, you will want to look it up and download it from the manufacturers website.
Mar 26, 2016 | Computers & Internet
How to use zebex barcode scanner?
Click below for a link to the support site. Click on the User's manual for you model scanner.
Zebex Manuals
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Zebex Computers & Internet
Sir i have booked 3 tickets from air inida express through online in that i have entered my passport number wrong whethere it may cause any problem for me on travel can u help me
Yes it could do, if this website you ordered your tickets from has a support link, such as contact us, click on it and look for a phone number or email address and contact them, hope this helps
Feb 06, 2010 | Zebex ZBA AIRLINE TICKETS MAGNETIC SWIPE...
I cant use symbol ls2208ap . how i use it
hello, once you have it connected to your computer via usb, serial or keyboard wedge, you scan the barcodes that come in the user guide to set it up, its pretty much a plug and play. you can find the quick start guide at
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201cpdf&sliceId=&dialogID=165478796&stateId=1%200%20165462678
Let me know if i can be of additional assistance,
Kim Ganoe
800.933.2839 x251
Feb 01, 2010 | Symbol LS2208-7AZK0100S Handheld
Stopped scanning
I seldom do this ...but I will comment on the Zebex scanner. This is ...errr ... not the best choice for future scanner needs. I will never forget commercial Zebex experience. They should have stuck to anti freeze (just kidding).
However if it did work and now doesn't there is one problem that is so obvious no one thinks of it ... check the clear plastic protector on teh front and see if it need cleaned. Greasy environments usually fog it over time.
I have the Zebex default codes somewhere in the shop ... but you can replace that scanner with a nice PSC, Mot, or Intermec for about 120.00 why not do that?
Jan 07, 2008 | Zebex Alpha-70 Handheld
Datalogic Dragon D101
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc. You would also have to use the correct scanner codes to ensure that the scanner is configured properly. Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem. If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Aug 28, 2007 | Datalogic Dragon D101 (902151240) Portable...
No code appear after I scanned the barcode.. Please help!
First of all,have you tried using a notepad ? just to verify that your scanner connected correctly to your pc If it's fine then you should find out if there's an enabled properties of your object such as text box, combo box, that was set to False,change it into true.
Aug 22, 2007 | Zebex 90940-RS232-9 Handheld
Metrologic Keyboard Wedge Barcode Scanner (MS5145)
are you using usb keyboards if so set the scanners to stand alone keyboard wedge you will find this in the manual. if this is not the case it could be that the scanner is set for a different keyboard type just set the scanner for keyboard wedge emulation. hope this helps Pete
Aug 15, 2007 | Metrologic Instruments MS5145 Handheld
Zebex Z-3080 - prefix ? software ?
Please download the Programming Guide from the link http://www.zebex.com/documents/Users'%20Manual/A.Handheld/Programming%20Guide%20(MUL-53221-07).pdf.
Attached please find the samples for programmings.
Aug 15, 2006 | Zebex Z-3080 Handheld
Zebex 90940-RS232-9 Handheld Logo
194 people viewed this question
Top Zebex Computers & Internet Experts
Ekse
Alun Cox
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
