Question about Apple iPhone Smartphone
Handsfree How can i use my apple iphone to make it answer automatically when connected to bluetooth headset?? do i need to add a software?? if yes which one??
    Problem Solver:
  • 5 Answers
Depends with ur bluetooth headset
Posted on Apr 12, 2008
SOURCE:
Will the bsh-100 pair with Iphone4s?
Yes. Starting with the iPhone 4 and newer, all support the following Bluetooth Profiles: A2DP(high fidelity stereo sound for music) , AVRCP(remote control, letting a headset's buttons change tracks, volume, etc), Handsfree and Headset(answer and make calls using the headset) , PAN (tethering a laptop to your cellular data conndction), PBAP (allows access to your contacts/phone book), HID (let's you use input devices like Bluetooth keyboards to type on your phone), and MAP (lets a bluetooth device send texts and get alerts if you receive one). Any bluetooth device with any of those profiles will work.
The BSH-100 uses the A2DP, AVRCP, Handsfree and Headset profiles, all of which your iphone supports. So all features will be enabled and work flawlessly on your phone.
Mar 06, 2015 | Anycom BSH-100 Bluetooth Headset
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
I have my backbeat 903 synced to my ps3 and phone how do i switch to my phone when i leave the house and back to the ps3 when i want to use it in gaming
Multipoint is a new development in Bluetooth technology that allows your headset to be connected to two Bluetooth devices at the same time. When a call comes in, the Bluetooth headset knows which handset is ringing and will connect to the phone automatically. Multipoint can benefit most Bluetooth Headset users.
Good luck from Headsets Direct!
Jan 20, 2011 | Plantronics Backbeat 903 Bluetooth...
My iphone wont connect to the bluetooth in my valkwagen golf car?
As I have learned the hard way the iphone's bluetooth is only to pair with wireless bluetooth headset and car stereo. You cannot connect to any other kind of devices. Also you must have Iphone Os 3.0 or higher to stream music to your car stereo. If it still does not work then the belkin bluetooth audio receiver should solve your problen
http://www.blueplastic.net/en/escuchar-musica-de-tu-iphone-via-bluetooth-conectar-iphone-a-radio-de-tu-coche-via-bluetooth/
Oct 04, 2010 | Apple iPhone 3G
I can't listen music through my bluetooth headset with iPhone
My Jabra Halo works to play iPhone's iPod music as well as phone calls. So does Jabra Arrow, I'm told. The bluetooth must have A2DP.
Aug 20, 2009 | Apple iPhone 3GS Black (16 GB)
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
How do I connect my IPOD nano to my Motorola S9 HD Headsets
I downloaded the instructions manual for the Motorola S9 HD and implemented them. It worked fine!
Jun 19, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Halfway working bluetooth
You cannot at present use iphone's Bluetooth to transfer files/link up phones/computers etc as Apple has intentionaly crippled the Bluetooth so you can only connect to some handsfree kits and headsets.. this is to force use of itunes only for file/music/apps transfer and of course to prevent copy of said files between your iphone and other phones/devices to force each person to buy apps and music (prevent theft by file sharing)
Sep 03, 2008 | Apple iPhone Smartphone
Bluetooth
I will take a guess that you are trying to pair with something other than a bluetooth headset. The iPhone cannot connect (even though it may pair okay) to other phones, headphones, or any device other than a bluetooth headset. This feature is intentionally crippled by Apple.
If my assumption is wrong, please provide additional information about what exactly you are trying to do (and with what) to get your problem resolved.
Jan 12, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
