Question about i-mate JAQ3 Smartphone
Windows Mobile Device Center (i mate JAQ 3)
I have a new imate JAQ3 that I bought just a month back. The EMI no. is 353332010514040. I am not able to connect this phone to the windows mobile device centre for vista. Have tried all the possible options but not able to get the success. On connecting it through the USB cable it does not open the windows mobile device centre window automatically and does not connect.
I am fed up because I am not able to sync the files and use the phone as modem. One more problem is that, I am not able to delete the picture from the picture folder as well as the storage card. It says that “cannot delete”, access denied. Make sure that disk is not full or write protected and file is not in use”.
Please help me sorting out the problems or I will through away my phone.
  • Anonymous Nov 02, 2008
    i have reset the device, after this, shows align screen. noe not working device
  • Anonymous May 11, 2009
    And my micro SD card is also now write-protected.
    Someone Help
Brod band wifi setting
Posted on Apr 04, 2008
    New Friend:
I have signal problem in roaming
Posted on Jun 30, 2010
Align screen
Posted on May 25, 2008
2 Suggested Answers
SOURCE:
Joed911
  • 4338 Answers
SOURCE: how to do factory reset of i-mate JAQ
i-Mate JAQ3 soft reset
Resetting Your Pocket PC Phone
Occasionally you may need to reset your Pocket PC Phone. A normal
(or soft) reset of your device clears all active program memory and
shuts down all active programs. This can be useful when the device is
running slower than normal, or a program is not performing properly.
A soft reset is also necessary after the installation of some programs.
If a soft reset is performed when programs are running, unsaved work
will be lost.
You can also perform a hard reset (also known as a full reset). A hard
reset should be performed only if a normal reset does not solve a
system problem. After a hard reset, the device is restored to its default
settings — the way it was when you first purchased it. Any programs
you installed, data you entered, and settings you customized on the
device will be lost. Only Windows Mobile software and other preinstalled
programs will remain.
To perform a soft reset
Remove the battery cover and using the stylus, press on the small
button to the left of the battery. Otherwise simply remove the battery,
wait a few seconds and then insert the battery again.
To perform a Hard Reset
Hard reset by pressing device buttons:
1. Turn off your device.
2. Hold down the Send button, End button and Camera button.
3. Do not release Send, End and Camera, press the Power button.
4. After on-screen indication, release all the buttons.
i-Mate JAQ3 hard reset Hard reset using Master Clear
1. Tap Start > Settings > System tab > Master Clear
2. On the System tab, select the Master Clear (!) icon
3. Proceed to enter the confirmation code: 1234 and push reset button,
system will auto reboot to complete the operation.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jun 02, 2009
I am not able to connect the i-mate jaq3 with PC with data-cable
You must have either ActiveSync (for Windows XP) or Windows Mobile Device Center (for Vista and 7). You can download any of them from this location. By the way, you, most probably, know that, in order to have stuff like Calendar, Contacts, Tasks,and e-mail, you must have Microsoft Outlook installed on your PC too.
Please, let me know if I can help you any further.
Regards,
Carlos
Nov 01, 2010 | i-mate JAQ3 Smartphone
Tip
Hi, i got new Imate-jaq. I am facing problem in synchronising the imatejaq with...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Dec 28, 2007 | T-Mobile MDA
Need pc suite
Regards, Carlos
Jul 19, 2010 | i-mate JAQ3 Smartphone
WHILE RESETTING MY IMATE JAQ MOBILE A SCREEN (ALIGN SCREEN) HAS APPERED. I PRESSED ALL KEYS BUT STILL IT APPERES. kINDY GIVE ME A SOLUTION TO ENTER IN TO MY PROGRAME
align screen is for screen calibration. At that screen all you have to do is press with your stylus at the centre of the "+" sign.
Oct 28, 2009 | i-mate JAQ3 Smartphone
Is there any other way to reset my imate JAQ .... its internal function of factory reset is notworking plzz tel me some way to format i-mate JAQ i-mate JAQ WinCE version:- window mobile 5.1.422 AKU 3.2.0 i...
Please Vote...
Sep 08, 2009 | i-mate JAQ3 Smartphone
How to do factory reset of i-mate JAQ
will be lost.
Thanks, Joe
Jun 02, 2009 | i-mate JAQ3 Smartphone
here is how to do a hard reset:
note: all three at the same time
1)push stylus into soft reset hole + press FN key + press right soft key.
2) phone will restart to factory settings
enjoy.-->
Dec 25, 2008 | i-mate JAQ3 Smartphone
IMATE jAQ aLIGN SCREEN
how to remove align screen
Jul 05, 2008 | i-mate JAQ3 Smartphone
Synchronise and connection problem in Imate jaq
hello! pradeep
let me tell u if u r using windows XP as an operatin system
then activesync creates some problem it is better to download activesync 4.5 which is the latest one and your problem will be solved. you can download it from net...
Dec 28, 2007 | i-mate JAQ Pocket PC
Windows locked up
I know that you should press & hold these 4 buttons simultaneously to reset i-mate JAQ3:
Camera, Green Call, Red Call, Power
Not sure about JAQ!
Nov 16, 2007 | i-mate JAQ3 Smartphone
Open Questions:
AmaZon PrImE ReFunD PhOnE NuMbER ```+1-++85O++-812+-+4OO9``` Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone contact amazon prime ++++^AmaZon PrImE ReFunD PhOnE NuMbER^ +1-++85O++-812+-+4OO9``` Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime?AMAZON PRIME Tech Support Number +1-85O**8I2**4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues.
Oct 20, 2019 | Amazon Computers & Internet
AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime?AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues.
See all i-mate JAQ3 Smartphone Questions
i-mate JAQ3 Smartphone Logo
336 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
