Missing file "usbscan.sys" for a hp deskjet f2180
  • 4 Answers
You can see a step by step guide to fix this issue here:
www.killertechtips.com/2008/03/28/how-to-restore-missing-usbscansys-in-windows-xp/
Posted on May 03, 2009
  • 655 Answers
Your driver for printer has been currepted. you need to re-install the driver.
1.) Remove the drivers for your printer.
2.) Reboot
3.) Install the printer driver......and..........:))
Thanks
Iqbal
Posted on Apr 03, 2008
My HP F280 printer stops in the middle of printing... I looked at the message, sometime it is "ink cartridge empty" and sometimes "paper Jam". I changed my printer with another F2180,...
first are you using genuine cartridges. also check that you are installing correctly eg removing the pull tab that some need to have removed. not saying you haven't but have worked in a office for number of years and it can be something that simple. also refer to the help people at HP printing they are a good source to trouble shoot their products. they have case files and can quickly work out whats happening a advise how to fix.
Dec 28, 2017 | HP Deskjet F2180 All-In-One InkJet Printer
Dear team i have lost my printer driver cd/dvd so i cant install driver in my laptop so pls help me serial no hp deskjet f2180 series all in one
To download the printer drivers please click on this link for HP Support and drivers and select your model printer and the XP or Vista Windows version :- http://welcome.hp.com/country/us/en/support_task.html
Jun 12, 2010 | HP Deskjet F2180 All-In-One InkJet Printer
Hewlett-Packard Deskjet F2180 / Copier / Fax All-In-One InkJet Printer: Lost cd that came with my hp deskjet f2180 all-in-...
You can download the software for free and then install it to your computer.
Given below are the steps and link for downloading the software for your printer supporting windows Vista.
http://ftp.hp.com/pub/softlib/software10/COL18547/al-64285-2/DJ_AIO_NonNetwork_ENU_NB.exe
May 18, 2010 | HP Deskjet F2180 All-In-One InkJet Printer
My hp photosmart 2610xi
You are missing the scanning file for your printer software. I suggest reinstalling your software that came with the printer. This should solve the problem.
Oct 02, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Scanning
Hi saly_60,
You can try the following steps to resolve the issue:
1. Connect the USB cable directly to a USB port on the computer Ifyou are connecting the device through a USB hub* or other USB device,disconnect it and try connecting directly to a USB port on thecomputer. If successful, the problem may have been with the device.
*Somescanners are powered by the USB connection. This is why connecting thescanner through another device, such as a USB hub, may prevent thescanner from communicating properly with the computer.
Connecting the cable to the your device.
usbtoprtr.gif Connecting the cable to your computer.
2. Check USB Connections Youshould disconnect and reconnect the USB cable at both ends to ensurethere is a secure connection on the device side as well as the computerside. It may also be necessary to try a different USB port on thecomputer. Additionally, you may need to disconnect other USB devices,temporarily, in order to determine if a conflict exists. .
  1. Disconnectone end of the cable and then reseat it ensuring the cable is firmlyseated into the USB port. If the USB cable is plugged into a hubinstead of directly into the computer, try connecting the USB cabledirectly into the computer.
  2. Repeat step one to reseat the cable on the other end.
  3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  4. Make sure the correct USB cable type is being used.
  5. Incorrect (A to A) USB Cable
    Correct (A to B) USB Cable
3. A device attached to the computer is blocking communication If you have more than one device connected to your computer, thenit is possible that some other device is blocking proper communication.
  1. Check to see if there are any devices (other than USB keyboards or mice) connected to the computer.
  2. Disconnect the device(s) and restart the computer.
  3. Once the computer has restarted, attempt your process again.
4. Press the ON/OFF button to power on the device. The device has an <ON/OFF> button.
  1. Connect the power cord from the device to the electrical source.
  2. Press the <ON/OFF> button.
  3. Wait until the device has completed its cycling process before submitting a job request or completing installation.
5. USBSCAN.SYS USBSCAN.SYS is a Windows system fileand required by the scan driver. If the system file is missing, anerror message will appear while installing the scan driver or willappear when attempting to scan. Search for this file and direct theinstallation to the appropriate path.
Search USBSCAN.SYS file on Windows XP:
  1. Click 'Start', 'Search' and select 'For Files or Folders'.
  2. At 'Search Results' window, type usbscan.sys in 'Search for files or folders named' field.
  3. At 'Look in' drop-down menu, confirm your computer's hard drive is selected. In most cases, C: is the computer's hard drive.
  4. Click 'More advanced options' link.
  5. Confirm checkmarks appear beside 'Search system folders', 'Search hidden files and folders and 'Search folders'.
  6. Click 'Search' button.
  7. Once search has completed and if the file does not exist, download a copy of usbscan.sys from here (Right click and select ‘Save Target As’).
    1. Ifthe file exists and a message appears while installing the scan driver,direct the installer to the appropriate path. For example,C:WINDOWSsystem32drivers.
  8. Close the 'Search Results' window.
Search USBSCAN.SYS file on Windows Vista:
  1. Click the Start button.
  2. Inthe Start Search box of the Start menu, type 'usbscan.sys' (without thesingle quotes) and then press 'Enter' on the keyboard.
  3. Once search has completed and if the file does not exist, consult the computer manufacturer.
Uninstall and Reinstall the Driver If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them. Caution:Uninstalling means deleting software, such as MP drivers, from thecomputer. Once the software has been deleted the unit cannot be usedthrough the computer until the software has been reinstalled.
Note:Login as a user with Administrator privileges to uninstall onWindowsXP/2000. Turn off any programs running in the background, suchas antivirus programs and firewalls before begining.
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
6. Reinstall the Drivers
Use the CD-ROM that came with your printer or download from canon website.
Sep 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My scaner is not working . Error Scan.Msi file missing
I have reinstalled software for my HP Officejet 7310 printer and in the final stages I get a 1706 error indicating I am missing a file called "scan.msi". Any suggestions?
Sep 02, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
We have lost our installation cd for our printed hp deskjet f2180 and need to install it onto a new computer
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=fi&dlc=fi&product=3177562
use this link & choose your OS
Aug 25, 2008 | Sony VAIO VGN-AR230G Notebook
145 people viewed this question
k24674
jasbo
jasbo
