BIOS setup won't allow me to set the system time and date for Asus m2n-sli deluxe motherboard.
My suggestion would be to replace the motherboard, where replacement of the battery doesn't help and the time/date display on BIOS setup is "frozen" (m/b manufacturing defect?) and cannot be changed. If anyone can offer an alternative solution, pleade do so. Thanks.
Posted on Apr 03, 2008
    Sergeant:
    Champion:
  • 277 Answers
Check your cmos battery... replace a new one
    Problem Solver:
  • 17 Answers
Dear friend
u try system date with windows time and date and then trun off yr pc and put off yr power cable for 10 20 sec then plug on power then try if system date still not work then changer for Mother boad BETTRY it's 2032 number bettry try this one
thanks for using fixya
jo_chinmay
Need audio installer asus m2n-sli deluxe
If it is: M2N - SLI Deluxe:
http://www.asus.com/product.aspx?P_ID=szSFtrap7crpBaQE
if: M2N - SLI Deluxe/Wireless Edition
http://www.asus.com/product.aspx?P_ID=0jMy2X8lKstYRvev
select your OS
Aug 06, 2010 | ASUS M2N-SLI Deluxe Motherboard
Boot up problems on an Asus M2N-SLI Deluxe motherboard
Try reseating the power cable to your HDD and also the data cable to and from your motherboard. If no joy - then it sounds to me like a power supply unit failure
Dec 03, 2009 | ASUS M2N-SLI Deluxe Motherboard
BIOS voltage settings for ASUS M2N-SLI Deluxe 570 SLI chip set.
Hi glen909nwi,
Here's the configuration for that board. If your trying to overclock, you'll want to go with a higher setting.
CPUChiosei HT Voltace 11.20 VI
Allows you to set the pocessorhipset HyperTranspoit voltage.
Configuration options: [1 .20V] [1 .25VJ 11 .30V] [1 .35VJ [+1 .40V1 [+1 .45V] [+1 50V]
Chtoset Core Vo#aae f1.40V1
Allows you to set the dlipset core voltage.
Configuration options: [1 .40V1 [1 .50V] [1 .60V]
Ctitpset Slan&w Core Vo?taoe 11.40 VI
Allows you to set the diipset standby coe voltage.
Configuration options: [1 .40V] [1 .6OVJ
CIhVsef Fi-E Voitaae 11.50 VI
Allows you to set the dlipset PCI Express voltage.
Configuration options: [1 .50V1 [1 .55V1 [1 .60V] [1 .65V] [1 .70V1
CPU Vcore Offset Voltage fDisabdJ
Allows you to csable or set the processo vCore offset voltage.
Configuration options: [Disabled] [Offset lOO.OnIV]
ASUS M2N-SU Deluxe
Oct 21, 2009 | ASUS M2N-SLI Deluxe Motherboard
Need m2n sli drivers..help?
Your SLI drivers as you mentioned were installed when your chipset drivers were installed. (NVIDIA nForce CK804 Chipset Driver).
If you use 1 PCI-E graphics card the bios will need to be adjusted to [Auto].
Using 2 PCI-E graphics cards you must install the EZ selector card correctly. See page 4-20 section 4.4 Adjust; SLI Configuration. Than see section 4.4.6 in your manual
Open the Asus link below if you need drivers for your M2N-E SLI;
http://www.asus.com/Search.aspx?SearchKey=M2N-E%20SLI
This may seem a bit tricky but its not. First time around the bios settings using SLI graphics cards will appears tough but you'll get it.
Cheers!
Mike
Oct 16, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus m2n sli deluxe sli 1 is 16 and 2 is 8 how to work 8 8
THIS MAY BE THREE WAYS ONE IS THREW THE BOIS
AND
JUMPERS ON THE MOTHERBOARD
VEDIO CARD
AND
SOFTWARE DRIVEN FOR THE MOTHERBOARD AND VEDIO CARD
THE MONITOR TOO [DRIVERS]
PROPERTIES, ADVANCE SETTINGS
IF YOU NEED MORE INFO PLEASE CONTACT THREW THE WEB SITE
ROD
Feb 05, 2009 | ASUS M2N-SLI Deluxe Motherboard
M2N-SLI Motherboard issue.
Hi
If your computer was ok before you changed parameters in Bios then it is Bios fault:
Re inter Bios and Try to reset it to default.
If you can not get into Bios anymore  the problem is serious:
You must reflash Bios or reset Cmos ,and it could be vga or may be the wifi if you have one onboard.
see if you have a hardware store nearby and let someone fix it
if you .
It seems to be a common problem on all Asus Motherboards:
bios,vga,post etc...
Dec 12, 2008 | ASUS AI Lifestylestyle M2N-SLI Deluxe...
Setting up SATA
You need to enter the bios. Use the M2N-E SLI manual to help make some changes. Start up the PC & begin to press the Delete key every two seconds. Doing this will open the bios. Open you're manual to page 4-29. All four SATA's should be set to Disable. Save & exit the bios. The SATA drives will still function but you should no longer get the screen to setup a RAID.
Enjoy!
Mike
May 30, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Second display not working
hi check for the BIOS settings for having both the cards work ..if not then try interchanging the card & slots with each other to check if one of it is faulty?
Bye Let me know
Dec 15, 2007 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Asus m2n-e sli Cpu changed settings on boots up
I could not find BIOS ver. 1302 for the M2N-E Mb. What I do know: Your dual core 4200 showing up as "unknown". Asus says:
This is because the BIOS does not have the relative CPU uCode to support this processor. Please simply update your BIOS to version 0902 or later to resolve this problem.
BIOS 0902 can be downloaded from the link below:
http://dlsvr01.asus.com/pub/ASUS/mb/socketAM2/M2N-E%20SLI/0902.zip
Once you cpu shows up correctly, chances are that your over clocking will work and the bios will stop sending you back to change your settings.
Dec 11, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
