Just puchased grundig LCD TV,model glcd2205whtdv, tuned the tv stations in okay. But every 3 minutes the LCD display goes off, sound is still there. Use the remote to turn unit off then turn on again, works okay for another 3 minutes then display goes off again. Help
    Brigadier General:
  • 6,966 Answers
Initially it would appear that you have either a LCD screen problem or your CCF Lamps goes out. Of the two I would suspect more the CCF Lamp which could be the lamp themselves, the inverter that powers the lamps or the logic circuitry that deactivates the lamp.
Additionally, this would be heat related or even possibly a loose connection somewhere in amongst the areas above mentioned.
Considering that the unit is new and presumably under warranty, perhaps your best bet would be to call it in for service by their authorized service personnel. Any diagnostic/corrective action would require that the back of the unit be opened for a look & see which of course would void your warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 03, 2008
  • Louie  Role
    Louie Role Apr 20, 2008
    Hi again,
    Glad to be of some assistance and appreciate the rating. Likewise appreciate your other comment.
    Cheers.
How do I tune a Grundig TV/DVD with no remote? Is it a combination of buttons on the front panel? Thanks
Get a pen and a piece of paper.
If I remember correctly, each button has a bizarre symbol next to it.
Draw the buttons on the paper and draw the symbol that appears beside each button.
With the TV on, press the first button and note what it does. Press it a second time to see if that progresses to something further or cancels the operation.
Repeat this for the other buttons.
I seem to remember a vertical green line appearing on Grundig sets which indicated that the tuning was activated. Look for buttons such as > or >> or < or << that suggest scanning for channels. Make sure you can pick up analogue TV signals in your area.
It also helps if you have a VCR or DVD recorder which is already tuned and you can tune the TV to that signal.
Jan 06, 2015 | Grundig 15 in. LCD TV/DVD Combo
How do set default AM & FM stations? Every time I turn on the radio I have select the station I want.
When you turn on the radio or select a wave band the display shows the last frequency you tuned in. That gives you 3 frequencies: One for the AM nd, one for the FM band (and maybe 3 for SW.
That does not look like much but there is nothing you can do about it. Sorry. It does not have Autamatic Tuning System, nor memory locations to store favorites stations. The portable Grundig/Eton such as the G5, G3, G8 have a plethora of memory locations and ATS.
Dec 28, 2010 | Grundig S350 AM/FM/SW Radio
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Lcd problem
Unplugging the television for about fifteen minutes or so, then plugging it in again.
Dec 26, 2009 | Grundig GU19WDT 19 in. LCD TV
Can't pick up any stations
Some Grundig models have a history of poor front end design where just a bit of static electricity will wipe out tuning. Serious flaw.
Aug 10, 2009 | Grundig YB 400PE AM/FM/SW Radio
Grundig GU22DVD - Manual Instruction & cancel PIN Code
Please i have this Grundig lcd tv,model number GU22DVD,how to enter service mode to change sound standard PAL I toPAL BG,help me.
May 14, 2009 | Grundig GU19WDT 19 in. LCD TV
Vcr won't record tv
You have to plug the antenna to the VCR, in the "Antenna IN" plug, from there it goes to the "TV OUT".
You use the VCR to tune the TV and choose record according to your VCR model.
Hope That Helps!
Jan 26, 2008 | Televison & Video
HOW TO TUNE GRUNDIG 14" TV
for tune your grundig you must use remote control
May 09, 2007 | Grundig GF70-600 TV
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
