The picture on my 32" philips CRT is green. The set is 4 years old and I assume the tube is faulty. Is there any adjustment I can make or what would be the repair cost of a new tube, including fiting?
    Brigadier General:
  • 6,966 Answers
Hello father,
Though it is possible that the tube is defective as you pointed out, may I offer an alternative diagnosis? Most CRT type TVs are driven by three (3) transistors located in a squarish PCB at the very rear of the picture tube. Each transistor is responsible to drive the red, blue and green guns of the CRT. If the green drive transistor is defective, the symptom you have described would also be the result. It is even possible that the transistor is not defective but any of its pins/terminals might have developed a cold solder.
Should this be the case, then the repair would be relatively easy (replace or re-solder as required) and comparatively low cost.
Should you venture a DIY, please be reminded of safety procedures/precautions when working with high voltages. Should you be uncomfortable going this route, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 03, 2008
6ya staff
SOURCE:
I own a Quasar SP-3235 32" TV. It has a slight green tint after 10 years of use. How can I adjust the color screens on this set? Is it a function of the remote like Sony TVs or do I need to remove
I would open it first and look, a lot of those had both the screen and drive controls on the PCB at the end of the picture tube, at least look there first.
You are dead on in looking for the screen controls, if you find one it should only be a tiny adjustment due to age and the Crt changing a bit.
Dec 13, 2012 | Quasar SP-3235 32" TV
Have a 27 " JVC
Hi ,
welcome to Fixya, it sounds like you may have a weak CRT (picture tube)
If the TV is over 6 years old that may be the case.
There are RED, Blue and Green color balance adjustments that you can try .
referencing the exact model one could see how it adjusts.
hope this helps
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Mar 11, 2011 | Televison & Video
The tv is at least 17 years old.The blinking red light blinks 5 times ,then the tv picture goes off . The voice is still on
Five blinks is the error code for an AKB (auto kine bias) error. What this means is that the set isn't able to balance the three color guns (red, green and blue) of the picture tube properly, and it's blanking out the screen.
To get the proper colors, the signals for the three colors need to be balanced, and Sony sets have circuitry to do this automatically. Other brands don't, and when they go out of balance you see a picture that starts to show tinting or colors that are off. As the picture tube ages, it gets harder to adjust the balance until finally the AKB circuit can't anymore, and poof, the picture goes away. With a 17-year-old tube, it's not surprising.
There isn't anything that can be done to fix the picture tube, it would need to be replaced. But the cost of the tube and the work required to get it set up after installation makes it completely uneconomical to repair this TV. A new picture tube is nearly $200. Then special tools are required to set the tube up (a process called convergence), so you'd need to find someone to put it in, and possibly pay to have the old one disposed of. A new 32-inch LCD set is around $350 now. Treat yourself to a new one.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Colors going bad on my tv?
The picture tubes in Zenith sets (I assume it's a Zenith since you posted this with a Zenith heading, although it's also true for any set this old) were only expected to last around 7 years. Your description makes it sound like you are missing green, or that the green is just way low. This is a common sign of a bad picture tube. There are other possible causes, but tube failure is the most likely. The low replacement cost for small TV sets makes repairing this one uneconomical.
Get rid of the set and treat yourself to a new one.
Jan 25, 2010 | Zenith SY2068DT TV
Display color changed from green/ white now to Red and blue?
Hi and welcome to FixYa,
Your described problem is as you suspected, the green is missing. This is a common failure and is technically an easy/quick repair. Almost always, the culprit would be a cold solder or a faulty color drive transistor/IC. They would be located on the small squarish PCB (printed circuit board) at the very rear of the tube. Of course, worst case scenario would be a faulty CRT (picture tube), but that would be least likely.
Corrective measure would then be initially re-soldering above describe solder joints and/or replacing faulty transistor/IC.
Good luck and thank you for using FixYa.
Feb 21, 2009 | JVC AV-27530 27" TV
Phillips TV Sometimes Come's On No problem and Then Not sometimes with Green blinking light
I HAVE LOST THE TOP PORTION OF MY SCREEN, APPROX 2 1/2". IS THERE AN EASY WAY OF REPAIRING?
Oct 13, 2008 | Philips 32PT6441/37 32" TV
Out of focus tv picture
if you have already adjusted the focus pot on the line o/p transformer (a small transformer with a lead that has a plastic cap attached , and is typically clamped onto the top of the crt/tube BE CAREFUL DONT TOUCH CAP WHEN TV ON VERY HIGH VOLTAGES)
also could be your crt/tube is bad if so then scrap/recycle
cheers
Jun 16, 2008 | Toshiba Televison & Video
How do I decrease the amount of green in the picture?
Unfortunately this model has a bad CRT. If is 3-4 years old and the greenish picture is in all inputs, for sure the picture tube is gone. If the picture is green only in component input check the connections for the blue and red cables.
Dec 26, 2007 | JVC AV-27230 27" TV
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
32" Toshiba television Mod. 3357DB
If im not mistaking I remember the toshiba 32" to have an on screen alighnment in the sevice menu.. and I would not recomend that anyone without the proper manual and tools to fool with these adj as I've seen in the past that a set had to be completely redone even the tuner alighnments after someone went in and tryed to adj the set., Now the green tinge you speak of is the CRT getting weak The best way to ajust this would be to see if on the picture tube pc board on the end of the Picture tube if it has any little control on it ? if it does look for the green drive and put on a b&w Picture. slowlty turn down the green drive control untill the pic look almost B&W and you probably wont be able to get perfact grey scale as the crt is weak . If theres no controls on the crt pcb then your gonna need a service alighnment manual and adj the green drive that way. Good Luck
Apr 24, 2006 | Toshiba 32A60 32" TV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
