Please tell me how to check ink levels on my HP D5360 Printer.
    Genius:
  • 2,785 Answers
Checking ink levels
  1. In the HP Solution Center, click Settings , and then click Printer Toolbox .
    NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box , click the Features tab, and then click Printer Services . The Printer Toolbox appears.
  2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear.
Posted on Apr 03, 2008
2 Suggested Answers
pagebor
  • 2785 Answers
SOURCE: I have an HP D5360
you have to install the software first to see the ink level.If the soft ware is installed then follow the following
Checking ink levels
I have just loaded both color and black cartridges into my HP photosmart D5360 and the ! buttong and On/off button are flashing. The message on the printer screen is "Print cartridge(s) missing or not...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Sep 27, 2010 | HP Photosmart D5360 Printer
HOW DO i CHECK INK LEVEL AND DO ALIGNMENT?
Near the bottom of this page are instructions for aligning cartridges.
Click here for instructions on checking ink levels.
I am an HP employee. I do not represent HP on this site.
May 27, 2010 | HP Photosmart D5360 InkJet Printer
HP Photosmart C3180 Printer keeps saying check printer cartaridge I have new ink cartiridges
If you have just replaced them make sure you have pealed off the protective film from the contacts on the cartridges, also make sure you run the wizard for replacing them so that it realigns the printer heads and then it might recognize that they are new.
Sep 12, 2009 | HP Photosmart D5360 InkJet Printer
HP D5360
Have you tried running the head cleaning in the maintenance section of your print driver? If the lines are clogged it will not print anything, also if ctg has just been changed make sure all packing has been removed. lots of times there is clear tape covering the bottom of ctg so it doesn't dry out when in package. Running the cleaning tool a few times forces in thru the lines and the print head. Usually under the properties of driver, (right click driver and select properties) then find maintanence tab.
Hope that helps
TankMurdock
Dec 09, 2008 | HP Photosmart D5360 Printer
I have an HP D5360 Printer. Please tell me how to see ink cartridge content levels.
Checking ink levels
Apr 03, 2008 | Office Equipment & Supplies
Ink level
1. First go to your HP Solutions Center (for a PC it's START --> PROGRAMS --> HP --> HP Solutions Center
2. Once that comes up click on SETTINGS --> STATUS --> VIEW INK LEVELS
3. To set your computer up to automatically tell you the ink levels everytime you print, then click CONFIGURATION and check the box that says "Display Ink Status Window", click the APPLY button.
Mar 19, 2008 | HP Photosmart C3180 All-In-One InkJet...
Ink level problem
are you refilling your cartridges? if so, there are two contacts on the print head that connect to the printer program that estimate ink usage and what's left. go to a site that deals with hp printers and they'll explain to you on how to reset your software for ink usage.
Nov 04, 2007 | Heating & Cooling
481 people viewed this question
jasbo
jasbo
