Question about Intel Motherboard
Msi7235 motherboard Having problems with blue screen computer shutting down checked out every thing except mother board could this be the priblem
  • iggulden Apr 05, 2008
    It started 2months ago got worse delete a lot of add ons not dropping out as much can now work for about 1hour before i have problems anything to do with switching in to programs does not help
  • Dave MacPhee
    Dave MacPhee May 11, 2010
    did this just start?? did you add any new hardware lately?
  • 236 Answers
If the solution provided by map9966 does not work.. I think your hard-drive may be failing. Try replacing it with a new one.
Posted on Apr 06, 2008
    President:
  • 2,351 Answers
Hi iggulden, I suggest you back up your personal data. Get it off the primary hard drive. While your windows is still running.
When you’re finished, find the Mfg's name of your hard drive & S/N. Go to the Mfg's web site & download their software tools for checking the hard drive/testing & setting up the drive for a fresh install of windows. Most Mfg's have software to create a bootable floppy disk & or a bootable CD. (I doubt your troubles are from the motherboard just by your description). After running the Mfg's software & a fresh install of windows your system will run much better. Give it a try before you attack your motherboard.
Good Luck! Take your time.
Have more questions, feel free to ask.
Mike
Posted on Apr 05, 2008
I have a K52f that I had to replace the dc board on. Now it will not turn unless I pull the CMOS battery out. Once it booted up it is fine, except the screen is so dim I can barely see it. I can reboot or...
your mother boards was defective already. look in your MB if thre is some blotted caps in your Bourds. and if they are present in your MB it is necessary to change your MB for the safety of your data. in near future
Jul 12, 2017 | Intel Motherboard
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
Blue screen appers and shut down by itself
your boot files are corrupted please repair your operating system backup your data and plan to reinstall a fresh version of operating system. endeavor to scan your system for virus affections.
Jun 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Sir every time I open my PC there's a blue screen appearing then it shuts down but sometimes when I log in it's OK and if I open any program the blue screen appears again then will shut down. What would I...
Hello my friend, regarding your problem do you have installed program or driver software lately before this blue screen appear? i guess the problem here is more on the memory dumping of your computer. either the latest installed software is not functioning will or  u have a memory device problem either to much heat or cause by some circuit problem that made the memory device problematic. the worst case here is to replace memory but for now try to check first if the memory is running well and stay in its standard cooling temperature. Or you can reprogram your computer.
No vedio
swap monitors if monitor is same dell brand then its the monitor. otherwise you can buy a Video card PROVIDED that you can disable from setup the MOBO video card, and install drivers, also speaking of drivers try uninstalling the video and monitor drivers first !! the do mon swap, finally new vid card .
funky things can happen to drivers, esp improper shutting down windows like flip a power switch or not having a UPS and computer shuts down during a power outage or storm. seen this happen as well.
Apr 26, 2009 | Intel D946GZIS Motherboard
Problem of blue screen error messege
you have installed the inf setup or not, install all the updated drivers of your motherboad
Oct 03, 2008 | Intel D102GGC2 Motherboard
Dell Dimension 310 PC.
many things could lead to yr problems. from viruses to hardware problems like ram, hard drives, mother board even missing files in windows dir could even cause inproper shut down.
so yu troubleshoot first by bringing out the mother board check for swollen capacitors then possible change the power pack with a diff one and trhen monitor the behaviour again.
thank u
May 29, 2008 | Computers & Internet
Blue screen
unistall recently installed hardware or software and try otherwise format the system and reinstall operating system it work ok, till the same problem if you have two rams remove one ram and check
Mar 26, 2008 | EPoX EP-8KHA+ Motherboard
Computer shuts down y by itself
remove ur power supply socket from the mother board short the pin green and black in the connector if the smps start no problen with the power supply then the problems lies with ur mother board wiring or fault in your mother board if your mother board has secondry power fix it correctly to mother board sock et with has 4 pin if its not working cousult a chiplel engineer the fault lies in the power supply of the motherboard
Dec 02, 2007 | EliteGroup 945GZT-M (V1.0) Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
