Question about ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 - what parts i'm looking for?
Hello everyone.
It is starting with hissing sound, then smell coming ... and continued to be working fine. Of course - troubleshooting started immediately and founded that transformer T1 has burning spot, big one.
Info from this parts tell me nothing.
What replacement i need?
Thank you!
  • viperkorn Jun 11, 2008
    Funny I have the same problem wonder if everyone else who got one lost theres the same way. could not find any replacement parts hope you had better luck.
  • UriLyt Sep 28, 2008
    Thank you everyone for your time and solutions!
    I send e-mail to ViewSonic and they sended to me a replacement - whole new unit.
    P/N № B - 00002481.
    Working perfect! With delinery all about 50 bucks.
    Have a great day!
    Problem Solver:
  • 6 Answers
PSU- Board, Rev.C
Item: B-PS-0204-0076
Compatible with: VX710 VX910 VX912 VX924
(This item has been discontinued and not available to order.)
Please order B-00002481 instead. Your Price: US$45.00 Each
Posted on May 17, 2008
How did you remove the transformer? I was having intermittent display. Then 3 sec power light blinking. Now dead. I replace both C664 capacitors, since one looked bulged and had a brown spot on top.
easy to remove and replace those without solder.
But the monitor is still dead.
Posted on Nov 24, 2008
    Problem Solver:
  • 45 Answers
By the way, C664 and the one beside it seems to be bulding out. You should replace that while your replacing the transformer. That might be the cause of the burnout.
Posted on Sep 28, 2008
  • 975 Answers
Thats an inverter transformer ,mostly cause by a dry solder around this area ,but judging by your photos , a new replacement is due. try accessing the homepage for VIEWSONIC , FOR ASSISTANCE . click here : . hope its helpful
Posted on Apr 22, 2008
Rpm go down and almost stalls when brake
sounds like you have a vacum leak does it run fine before applying brake? if so you may have a brake booster leaking start the car put your head down under dash by steering column push brake pedal and listen for a hissing sound if present then you brake booster is bad if not have someone apply brake open hood and listen for hissing sound coming from vacum lines you should be able to locate this by sound good luck
Dec 06, 2013 | Hummer Vehicle Parts & Accessories
The freezer in my mini fridge started making a hissing sound today something stabbed the bottom of it whats going on is it safe to use ?
From what you are saying the evaporator got punctured. The hissing was the freon coming out of the unit. The unit will not cool even if it was plugged in.
Apr 22, 2011 | Refrigerators
I changed the thermostat and put in a new radiator on my 99 hyundai elantra. It drove fine i guess for about a week, but then started overheating again and stopped on me! Any suggestions? I smelled some...
You have some kind of a leak in the cooling systemDo you smell antifreeze when your inside the vehicle dose the heat work alright It may also be an engine vacuum leak you need to start it look under the hood and listen to where the hissing noise is comeing from if its cooling you should see antifreeze see if the floor is wet inside it could be the heater core and check vacuum lines for splits cracks on disconnected lines Ycould check to see if the radiator is holding pressure take a towel and turn the cap see if its under pressure but its going to be hot don;t get burned
Nov 16, 2010 | 1998 Hyundai Elantra
Hi: I just installed Frigidaire gas range and have a couple questions. 1. 2 surface burners each have flame too high on only half the burner. it shoots up pretty high. How can I adjust this? 2....
Hi. There is an adjustment screw on each burner. Just make tiny adjustments until you are happy with it. Regarding the gas hiss, yes that is normal.
3 thumbs up please. Thanks, Joe
Oct 15, 2010 | Kitchen Ranges
your control board fuse could be faulty or the board itself could be bad,check the continuity of the new ignitor to verify its good, then for voltage on wires of ignitor at start-up of dryer
Sep 25, 2009 | Dryers
Peugeot 306 won`t start off ignition
check your glow plugs they may be damaged or dirty
May 25, 2009 | 1991 Peugeot 405
Bad sounds, bad smells from 94 ford explorer
Sounds like you may have a vacuum line off or ruptured going to the EGR valve. The burning smell is probably the catalytic converter. When the engine runs rich you will get a sulfur smell that smells sort of like rotten eggs.
Mar 15, 2009 | 1994 Ford Explorer Limited
Gas fumes
chech the fuel pressure regulator,its black incolor and has a vacuum line to it.It will be in the fuel rail.start the van and pull off the vacuun line, if fuel comes out its bad.
Feb 01, 2009 | 1999 Oldsmobile Alero
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Sony kp-41s3u 50" hissing sound
sounds like high voltage arcing,caution
Oct 28, 2007 | Sony KP-41T65 41" Rear Projection...
ViewSonic VX910 19" LCD Monitor Logo
1,218 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
