I can not set up my printer to my computer to print
  • jenniferposa Jan 16, 2009
    I don't have the cd drivers to install the printer for Tally T9114 do you know where I can get them?
  • 133 Answers
Firstly u need to have the drivers for the printer, i.e the printer came with a cd written drivers, u need to install them in your computer.
if u do not have a driver cd, let me know the make and model of your printer.
Posted on Apr 03, 2008
SOURCE:
Computer says paper jam in printer but printer will make copies
Welcome to the ever popular-widely experienced world of:
PAPER SIZE MISMATCH!!!
YES! That wonderful world where unbeknownst to you but knownst to us (OK I watch Spaceballs WAY TOO MUCH) When you are sending a print job, somehow the paper size setting has been changed. Either in the printer itself, or in the print properties settings in your OS.
Double-check those paper size settings and try to print. If it still happens, try resetting the print settings in the printer back to factory default. Make sure you print out the printer configuration before resetting in case you need to reinstall those settings.
Nov 06, 2013 | HP PSC 1401 All-In-One Printer
Sharp MX-2610N printer can't set-up the print job (for labels from by pass tray) from my desktop computer.
Some documents like word override the settings... you need to change/save within your document you are printing. page layout and then page set up
Sep 16, 2012 | Sharp MX-2300N Color Copier
My printer is not responding to when i ask to print something.
If the printer is not printing, check the cables connecting the printer and the computer. Make sure it is properly connected. Check the settings on your computer if printer is set as a default printer and try printing a test page from the driver page. To do this open printer and faxes, right click on the printer >properties and click the button print test page.
If you are able to print a test page, check the settings of your application and make that the correct printer is selected.
For further assistance, please contact Lexmark Technical Support
Jan 05, 2011 | Lexmark E260 Laser Printer
HP DESJET 694C - NO LONGER PRINTS IN COLOR - TRIED SEVERAL CARTRIDGES, CLEANED PINS, ALIGNED AND REALIGNED - NO CHANGE.
Did you checked Printer Settings? May be option is check Marked that "Always print in Gray Scale" if yes then remove check mark.
Disconnect printer from computer and Try to press resume copy or start print button for 5 seconds to start Test Print directly from printer. it prints in color then there definaly a setting problen in your computer printer settings.
Last Option is to check or replace print head.
Mar 09, 2010 | HP Office Equipment & Supplies
When printing duplex the even pages print portrait and the odd pages print landscape...
This could be a setting on the printer, in the driver on your computer, or the document you are printing.
First, try printing a different document and see if the problem persists.
Reset the printer to factory default settings, also referred to as a cold reset. HP has instructions on their website here: HP LaserJet 2300 Printer Series Resetting the Printer Cold Reset
You can also go into the printer driver on your computer and reset settings there, or uninstall and reinstall the printer.
Sep 08, 2009 | HP LaserJet P3005 Printer
Slow Printing color/b&w
are the settings on the computer console program (properties of printer that pops up before you print) set to the best quality? reduce it
May 27, 2009 | Canon BubbleJet i560 InkJet Printer
Bad ESC Seq
The ‘Bad Esc Seq’ message on the MT645 indicates the printer is not recognizing some of the commands it receives in the data from the host computer system. These commends are sent in the format of Escape Commands Sequences hence the ‘Bad Esc Seg’ error message displayed on the printer.
There can be a number of reasons for the printer displaying the ‘Bad Esc Seq’ error.
The first thing that it may be worth doing would be to power the printer off then disconnect the printer from the computer system. Once the printer has been disconnected from the computer system power the printer back on again. If the ‘Bad Esc’ Seq’ message is seen when the printer is disconnected from the computer system this would tend to indicate there is a fault with the printer.
If the printer powers on OK and does not display any errors when it is disconnected from the computer system it is possible that one of two things is happening.
The first thing is that a print job has been sent to the printer using the wrong printer driver on the computer system, this will send data to the printer that it does not recognize. If this is the case the print job on the computer system would need to be cancelled and resent using a printer driver suitable for the MT645.
The other thing that may have happened is that the Emulation setting on the printer may have for some reason changed so the printer not longer matches the set up on the computer system. You may need to change the emulation setting on the MT661 so it matches the host computer system set up. The printer may need to be set to either Epson or IBM emulation depending on the computer system set up.
The Current emulation setting on the printer can be found by printing a configuration page, this can be done in the following way;
Put the printer OFFLINE
Press the MODE button
Press the DOWN ARROW until HELP is displayed
Press ENTER
The printer will print out a configuration page showing the current settings, this will include the Emulation setting. This can be checked to ensure it matches the computer system set up, or change to ensure the emulation is correct for your application.
If you are printing from Windows try printing using the Generic Text only printer driver, this will not send escape commands to the printer, so should print correctly. If you still see the Bad Esc Seq message I would recommend having a look into the connectivity between he printer and the computer system.
May 22, 2009 | Tally MT645 Printer
Error on print both sides
The problem is from your computer not the printer. but then try to text print the print on it own.
Nov 26, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Oct 18, 2008 | HP LaserJet 2430dtn Printer
Paper wont load
Please check the following items:
Check item 1:
The cable may not be securely connected between a printer and a computer, or be about to be unconnected.
Check that the cable is securely inserted into the ports of the printer and the computer respectively.
If a USB hub is used, connect the printer and the computer directly.
Check item 2:
Print jobs may be queued.
Delete the print jobs queued in the computer. How to delete the accumulated and queued documents in the computer (Windows)
Check item 3:
The computer settings may not be corrected.
Check the computer settings. How to confirm the computer settings (Windows)
Jan 14, 2008 | Canon PIXMA iP90 Mobile Printer
Open Questions:
50 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
