Washing Machine LG WD-8013F
Washing machine will not work. I believe it is a door lock error. Although the door is closed, the temperature and 'options' lights are on when you go to start a cycle. You can also open the door once you select a wash program, even though it is normally locked.
Regards
Brett
    Sergeant:
  • 351 Answers
It may be the lock but this model is known for board faults,take of the top panel and remove the control panel and see if the board is burnt.there was a recall on some of these machines a while ago in australia not sure where you live
Posted on Apr 03, 2008
Lg washing machine wf-sp950g de ( door error )
Hi Azlan.
de Door Error usually shows when the door lock either won't undo...OR The machine won't start after the door is closed.
Both these situations probably mean that the door 'Interlock' is faulty.
The interlock is the part of the door lock which prevents you from opening the door while the machine is working.
It's part of the electrical circuit and should only be serviced by a qualified technician.
Good luck
Nomess
Feb 04, 2015 | LG Washing Machines
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Apr 08, 2014 | LG WD-1280FHD Front Load Washer
Hi there My frontloader washing machine display
LG washing machines indicating error code CL may have the child lock activated. Try holding down the temperature and eco/rapid options together to turn off child lock.
Mar 08, 2011 | LG WD-1280FHD Front Load Washer
I have a LG WD - 1049C front loader washing machine showing the DE error have emptied out the washing machine and it still comes up, partner bought a new door latch and installed it but the DE is still...
DE error does mean the door latch,but there are three parts that could cause the error code.If you have changed the door lock already then the main p.c.b/computer board has failed and not registering the door lock but there is a 5-10% chance it's the wiring connecting the two parts together.So basically you need to change the main p.c.b & if that doesn't work it needs to be rewired.unless you know how to use a multi-meter then you could test the wiring for a definate answer.THANKS ECO KIZZA
Feb 18, 2011 | LG WD-1045FH Front Load Washer
I do not know how to undo the child lock on my LG intellowasher Model no.WD-8013F
The Child Lock can be activated and deactivated by pressing and holding both the Temp button and the right Option button simultaneously for 3 seconds as shown below.
Let us know if this procedure fails to deactivate the Child Lock feature for further troubleshooting and repair advice.
Aug 23, 2010 | LG Washing Machines
Lg intellowasher wd-8013f is very noisy
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
May 09, 2010 | Washing Machines
Fe MEANING
It typically means that one of the water valves (that opens and closes to let the appropriate amount of water into the machine) is not functioning properly. It is frequently accompanied by a continuous flow of water into the machine (although with the drain pump also running you won't necessarily see any water building up inside the drum.) I believe the letters actually stand for "Fill Error."
Mar 17, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Washing Machines Logo
552 people viewed this question
Top Washing Machines Experts
