Question about Refrigerators
The water dispenser is constantly dripping - Refrigerators
  • Anonymous May 14, 2008
    same problem - was told to hold down button 2 minutes off and on - didn't work. problem has only gotten worse over the last few months
  • 109 Answers
Hello; your water valve is bad, it;s a dual valve located in the back where the water line comes in to the unit. this is a non-serviceable item and must ne replaced. you can do it yourself, just order the part from your local appliance parts store,(you'll need model, and brand name when ordering.)
Posted on Apr 03, 2008
Why is the water dispenser constantly dripping?
If the water is coming from the water dispenser itself then most likely you have a water valve that bis going bad and it will only get worse.
Jul 13, 2015 | GE Refrigerators
Frigidaire water dispenser drips constantly. I have been told there is a main water valve and a second valve for the water dispenser. Where is it and how to replace?
if you are referring to the cold water on the door , then there is a solenoid valve on the bottom back left side of fridge, you will see two there , one is for ice maker and one is for water on door , most times it's a good idea to replace both of them , also there should be a filter inside fridge on bottom middle (cartridge) this should be changed monthly to maintain fresh taste and keep foreign objects out of tubes
Jun 01, 2015 | Frigidaire Refrigerators
Water dispenser drips after use but doesn't shut off completely and drips constantly.
Most likely the water inlet regulator (water valve) is faulty (like a leaky faucet) need to replace the water valve.
Jan 30, 2014 | Samsung RF26XAERS
Water is constantly driping from the dispenser area
Water dripping from a water dispenser is caused by a leaky water inlet valve which is on the back where the water supply is connected. It needs to be replaced.
Aug 24, 2011 | Whirlpool Refrigerators
Water constantly dripping from water dispenser in fridge
first try to run about a gallon of water through the dispenser to clear any air in the lines that compesses and forces out the water, if that does not work try changing the water valve
Aug 19, 2011 | Kenmore 65812
Water dispenser in the freezer door has a constant slow drip, how do I fix it?
You will need to replace the water valve. It is located in the back rear of refrigerator. If it is leaking by then you will see drip. Before you replace valve make sure the water pressure of water supply is proper. The valves will not seal properly without proper pressure.
Nov 24, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Drips at water dispenser GE PSC23MGSA BB
If it's a constant drip then you need a new water valve.
Jan 03, 2009 | GE Profile Energy Star PSC25MGS Side by...
Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Oct 05, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Water dispenser
I HAVE THE SAME PROBLEM WITH THE WATER CONSTANTLY DRIPPING FROM THE DISPENSER, I REPLACED THE HOSE AND THAT DIDN'T DO IT. ANY SOLUTIONS?
Aug 24, 2008 | Kenmore 53642 / 53644 Side by Side...
Whirlpool side-by-side refrigerator - 2 problems
I would suggest that you get a certified person to come out and look at it you very well could have bent the doors in the move.
but... if you want to do it yourself.
click here for a walkthrough
for your drip:
Flush air from the water system the first time it is used and after replacing the filter. Air trapped in the water line or filter may slowly travel through the coiled water reservoir to the dispenser, pushing any water ahead of it. This can cause the dispenser to drip. Water needs to completely fill the lines for all air to be cleared.
  • Use a sturdy container to press and hold the water dispenser bar for 5 seconds, then release it for 5 seconds. Repeat until the water begins to flow. Once the water begins to flow, continue pressing and releasing the dispenser bar (5 seconds on, 5 seconds off) for an additional 2 minutes. Repeat if dripping starts again because air can re-enter from the water supply.
  • As air is cleared from the system, water may spurt from the water dispenser.
  • Make sure the refrigerator is connected to a cold water supply.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Jan 26, 2008 | Refrigerators
Refrigerators Logo
801 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
