Washing Machine Fuse Keeps Blowing Off !!
I have a Whirlpool W/Mc - front loading type. Recently, i found the fuse (13 ~ 15 Amps) keeps blowing off when the timer rotating knob gets to a perticular position. Until then the water suction pump works normally to fill the drum to the required level, the drum rotates too & fro with normal operation, the timer motor also keeps operating until the knob rotates to a perticular position. What could be the reason for this overload?? I have checked for any mechanical frictions in the rotation of the water suction pump, main motor rotating the drum and the drain pump - which were all found to be normal and free.
Could i get a solution please??
Kind Regards,
Suresh
[email protected]
    Sergeant:
  • 351 Answers
Check for earth leakage and a water leak.is the heating element ok
Posted on Apr 03, 2008
SOURCE:
Keeps blowing fuses
Try using higher Amps fuse.
Oct 13, 2014 | Washing Machines
My washing machine keeps blowing the fuse when I turn it on after about 10 seconds , any ideas
If washing machine aging, that possible damage heating element. Necessary so- check Drain and hit of water on electronics.
Mar 07, 2014 | Indesit W 123 Front Load Washer
Our whirlpool awm5145/5 washing machine is blowing fuses where it's plugged in usually and it won't work in the plugs on the same wall but when we plug it in a different wall it will work fine?
This sounds like an overload from the Ring circuit house wiring...Most rings here in u.k. are 32 amp.this should be okay for small oven /Micowave/ kettle / if the washing machine is running at 3000watts or 12 amps and a kettle is also the same total load is 24 amps.....If the machine blows the breaker/or fuse on its own I suggest looking at the wiring on the supply socket or better still contact an Electrician......
Feb 24, 2011 | Whirlpool AWM5145/2 Front Load Washer
My washing machine keeps shutting down and blowing a fuse.
You must have a short circuit ,try disconnecting things start with the heater element, disconnect one wire see if it still blows...next try motor plug, until the fault clears at least this tells you what the problem part is.....
Apr 11, 2010 | LG WM-2077C Front Load Washer
Keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Mar 09, 2009 | Whirlpool LGV4634JQ Gas Dryer
Maytag stackable washer top loader
try replacing entire lid switch assy, come ith new fuse!
Oct 31, 2008 | LG WM2077CW Laundry XL Front Load...
Fuse keeps blowing
This is probably a water heater problem  Try operating on the lowest temp  eg.15C If it goes through the cycle then its more than likely your water heater  You will need a refit
Jun 01, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
384 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
