Question about Dell Inspiron 6400 Notebook
Flash Disk I can not open and format the flash disk can you please gide me Thanks Farid
  • 8 more comments
  • Anonymous Apr 03, 2008
    OK this is the bsic things that you meantioned
    When I start the format it gives me this error the windows was unable to complete the format so if you have some Idea after this please posted to me ,
    Thaks
    Farid
    hello eqbal,
    Now I can not see my flash is not visible to me ,
    Daoud
    Hello Eqbal,
    Ok it is visible on the other system ,
    one Idea Eqbal can we format this via DOS command ??
    For the rating sorry of that it was by mistake when i read caerfuly the Q you were right
    Thanks
    Daoud
    Ok , would you please send me the steps how to format it because if have forgot it hahah how to format ,
    Daoud
    OK , It gives me this message
    C:\>format f:
    Insert new disk for drive F:
    and press ENTER when ready...
    The type of the file system is RAW.
    Please use the /FS switch to specify the file system
    you wish to use on this volume.
    ok good luck , we will see on Sat ,
    Thaks alot
    Farid
  • Anonymous Apr 06, 2008
    Thanks for the support , but still flash not working might be some system file insid the flash has been deleted
    Daoud
  • Anonymous Apr 12, 2008
    Dear All,
    I have an external hardisk it has 4 patitions I want to assing a password for them , is that possible or .....??
    Thanks and Rergards
    Daoud
  • Anonymous Apr 14, 2008
    invalid media or track 0 bad -disk unisqble
  • Anonymous Aug 11, 2008
    C:\>format f:
Posted on Apr 27, 2009
  • Anonymous Apr 27, 2009
    New Friend:
    Problem Solver:
  • 10 Answers
Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
Get the two floppy (resuce disks) for PowerQuest Drive Image 2002
Connect your USB flash disk
Restart your PC and boot from the floppies
From Drive Image Click Tools then Delete Disk Partitions and choose (Disk 2 or 3 Flash)
Select the partition and click Delete
Restart
Get the two floppies (resuce disks) for (Norton/PowerQues) Partition Magic
boot with Partition Magic
Select (Disk 2 or 3 Flash)
Create NTFS Primary Partition
Restart
Set Active the Partition of (Disk 2 or 3 Flash)
Restart
I can see when I boot from Windows XP CD
D: ...GB [MBR]
Regards,
Mohamed
Posted on Oct 22, 2008
  • 74 Answers
Some of the viruses like smss.exe,killer.exe
stop formating of flash drive
simply download kaspersky or northon antivirus from tis site
www.filehippo.com
www.softpedia.com
then remove all viruses.
then u can format easily
else boot frm xp cd then format flash drive
Posted on Apr 03, 2008
  • 655 Answers
Farid you should write your problem in details, i.e. whats going on when you try to format the flash disk. To format flash disk the steps are :
1). Plug your Flash to USB port of your system.
2). Cancel if auto play window appears.
3). Double click on My Computer icon
  • The icon for your flash will be appear in the My computer window.
4). Right Click on your Flash icon and select Format from the pop-up menu appeared.
  • WARRNING: If you will select wrong disk i.e. other than your flash you will loose all the data of that disk.
So, please be aware of that.
Thanks
Iqbal
  • 5 more comments
  • Iqbal Husain
    Iqbal Husain Apr 03, 2008
    what did you done?
    • try to remove your flash from USB port and insert it again.
    • may be your flash damaged physically, in that case your system will not recognize but its rare to be damaged.
    • try to check your flash in another system.
    and see m vry unhappy with your rating. You have asked how to make format and answer that. The rating you have given to my solution means my solution is not related to your problem, Is it not.
    anyway thanks for your rating.
    Thanks
    Iqbal
  • Iqbal Husain
    hmmm it seems there is problem in your Flash.
    try on DOS and let me know whats happening..
    Thanks
    Iqbal
  • Iqbal Husain
    1). see the icon of Flash in my computer and remember it, suppose its F:
    2). Start -> Run and type CMD, if you are using Vista then type CMD in Search and press enter.
    ......Command window will be open.
    3). at command prompt type FORMAT F: and press enter
    ... format will start.
    Thanks
    Iqbal
  • Iqbal Husain
    ok tyr NTFS if not work then FAT32 if still no success then finaly try FAT.
    Thanks
  • Iqbal Husain
    See the command will be like
    FORMAT F: /FS:NTFS
    and please be sure your flash drive is F: other wise you will loose your HDD data.
    Thanks
    Iqbal
  • Iqbal Husain
    ok Farid its time to go now
    i will be here again on SAT.
    and thaks you have pull-down me from Guru to Wiz.... lol
    thanks . . gud luck
    Iqbal
  • Iqbal Husain
    Iqbal Husain Apr 06, 2008
    frind i think you have some physical problem in your flash.
    and it will not fix by software solution.
    Thanks
    Iqbal
SOURCE:
My SanDisk Cruzer 8 GB USB 2.0 Flash Drive SDCZ36-008G (new!)does not give in to formatting. Memory volume = 0, the flash drive does not open, but the operating system (Windows 7) considers that the...
Click on round windows button (on the bottom right) > right click on "computer" > manage > select disk management > if you can see the flash drive in on the right hand side right click on it > format.
Mar 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How can i fix my kingston dt101 2gb flash drive
The OS format tool will not format flash driveswhat you need is this one
http://en.kioskea.net/download/start/download-127-hp-usb-disk-storage-format-tool
Although it was produced by HP it works on any,
Jul 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My pen drive is in RAW file system, I ca'nt open or format it.
Try to get a software called parted magic. its linux based and you should easily format the pen drive.
U can also try HP USB Disk Format Tool.
May 28, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My flash disk does not format what is the problem? i put the flash in the windows xp system port it becomes recognised by the system i try to open it ,it tells me the disk is not formated do you want to...
Your flash disk has been infected by virus that is why you are unable to open the flash drive. The best thing you can do is to download a good antivirus such as MacaFee or Avira or scan the flash drive for virus.
An alternative thing you can do is to insert your flash drive into a linux operated pc such as Fedora, Ubuntu, Open Susie or Redhat and then delete all the files in the Flash drive and format it
Apr 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Thumb drive won't open or format but detected by any sytem
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 02, 2010 | Kingston 4GB Secure Digital High Capacity...
Can't format flash disk
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Nov 10, 2009 | Electronics - Others
Windows was unable to format my flash disk
It seems that the card is bad. Try to format the card on a different machine to rule out your Windows formatter.
Aug 19, 2009 | Dell Inspiron 6400 Notebook
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Flash disk displays No media in disk management.
format and see
plus try uisng on some other pc /device to confirm the defect.
u get replacement fm kingston as it has 5 yrs warranty
Jun 22, 2008 | Kingston flash memory card - 256 MB -...
Dell Inspiron 6400 Notebook Logo
2,381 people viewed this question
Ekse
Clive
Clive
Alun Cox
