Question about Sony VAIO PCV-V200G PC Desktop
Help Please!!! I leave for iraq friday and i'm having issues with my vaio!
I have a sony vaio, i have tried resetting all of the default settings. ans it still won't let me view internet pages, i am connected to the internet, and the signal strength is excelent, what do i do..... best buy said that they would have to keep it, but i don't have that much time.
-Thanks
    Sergeant:
    Champion:
  • 293 Answers
Check your internet explorer settings, the proxy server in the lan setting should be uncheck.
or better use other browser eg. mozilla netscape etc...
Posted on Apr 03, 2008
SOURCE:
Bios fw140e reset vgn vergine
Follow these steps to access the BIOS on a VAIO computer.
WARNING: Other than resetting the BIOS to the default values, making changes to the BIOS is an advanced procedure that can produce unintended results if not done properly. For instance, if you set a Machine Password and later forget that password, it will require advanced technical support and possibly service to regain access to the computer.
  1. Turn off the computer.IMPORTANT: If you are having difficulty accessing the BIOS, or are doing so as a step in troubleshooting an issue, it is recommended that you remove all media or any peripheral devices connected to the computer before trying to access the BIOS.
  2. Restart the computer.
  3. At the black VAIO logo screen, press the F2 key.
If you are accessing the BIOS as a step in troubleshooting an issue, you may need to reset the BIOS to the default settings. While the exact steps will vary slightly based on the version of the BIOS installed on the computer, these general steps will allow you to reset the BIOS to the factory default values:
  1. In the Setup Utility window, use the arrow key to select Exit.
  2. At the Exit screen, press the down arrow key to select Get Default Values, and then press the Enter key.
  3. At the Get Default Values prompt, use the arrow keys to select Yes, and then press the Enter key.
  4. At the Exit screen, with Exit Setup selected, press the Enter key.
  5. At the Exit prompt, use the arrow keys to select Yes, and then press the Enter key.
  6. The computer will restart.
Reference: How to reset the BIOS to the default settings
Oct 24, 2013 | Sony VAIO VGN-FW140E/W Laptop
Describe your VAIO E Series 2.26GHz Intel Core i3-350M Notebook - VPCEA23EN Problem WHEN I SWITCH IT ON IT SAYS OPERATING SYSTEM NOT FOUND
Hi.
Based on the information you have provided it seems that the issue might be due to the Operating System files.
Hence, as a first step, it would be better to reset the BIOS to its default values.
Please follow the steps mentioned in the below link to reset the BIOS:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C94679
After performing the BIOS reset, please reset the Computer for the settings to take effect.
Performing the BIOS reset should resolve the issue.
If the issue still persists even after performing a BIOS reset, it is required to restore the Computer to the Factory settings.
Restoring the Computer to the Factory settings will re-install the Operating System and delete all the Data in the Computer..
Hence, it is required to backup all the important Data before re-installing the Operating System.
Please follow the steps mentioned in the below link to restore the Computer to the Factory settings:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1008013
Hope this helps.
Please feel free to contact for further assistance.
Aug 10, 2011 | Sony VAIO E Series 2.26GHz Intel Core...
Os system not found,i cant boot windows
Hi khanaboki1,
This issue may occur if the Computer is not detecting the Internal Hard Disk Drive in it. Resetting the BIOS to the default values should fix the issue.
To reset the BIOS to the default values, please restart the Computer, press and hold the F2 Key. This will take you the BIOS Utility Window, there, please press the F9 Key to load the default values then F10 to save and exit. After that, please try restarting the Computer to check if the issue is fixed.
If the issue is not fixed, please try disconnecting all the external devices connecected to the Computer. Also, please confirm if the Hard Disk Drive is listed in the BIOS main window.
If the issue still persists, you may need to perform the System Recovery in the Computer to fix the issue. In that case, you can try accessing the Recovery Partition in the Computer to perform the System Recovery. To access the Recovery Partition, press and hold the F10 Key while restarting the Computer. This will launch the VAIO Recovery Wizard. There, please click "Proceed with System Recovery" and then you can select the "Restore C: Drive" option to re-install the Operating System in the Computer. Performing the Restore C: Drive will erase all the User Data in the Computer and restore it back to the factory settings.
Hope this helps.
Good Luck!
Please let me know if you have any further questions or require any further assistance.
Thanks for using FixYa.
Dec 16, 2010 | Sony VAIO GRZ660 Notebook
VAIO VGNFJ270 NEEDS PASSWORD!!! HELPPP
  • Restart your Sony Vaio computer.
  • Press the "F2" key to enter the BIOS.
  • Use the arrow keys to highlight the "Load BIOS Defaults" menu option. Select it by pressing "Enter."
  • Highlight "Load BIOS Defaults" again and hit "Enter." This will reset all of the settings of your Vaio's BIOS back to their original factory defaults. You can now select "Save Changes and Exit" to exit the BIOS.
  • Dec 09, 2010 | Sony VAIO VGN-FJ270/B Notebook
    Hi, When I switch my laptop (Sony Vaio, Model: PCG-7Q1M) on. I receive an message stating, "Operating System not found". The laptop was dropped a few days ago. The laptop attempts to read from...
    Hi.
    Based on the information you have provided, it seems that the issue might be due to the Hard Drive.
    As you have mentioned that the Notebook was dropped, this might have caused a Physical damage to the Hard Drive.
    Hence, the Computer might not be detecting the Hard Drive.
    As the issue might be Hardware related, it would be better to get the Unit examined at the Sony Authorized Service Center.
    Before sending the Unit to the Service Center, you may try resetting the BIOS to its default values.
    If the issue still persists even after performing the BIOS reset, then you may get the examined at the Sony Service Center.
    You may initiate the Service by filling the required details in the below link:
    https://eservice.sony.com/webrma/web/index.do
    Hope this helps.
    Please feel free to contact for further information and assistance.
    Nov 22, 2010 | Sony VAIO Notebook
    My sony vaio VGN-CS22GH laptop shuts doen by itself randomly. Please help
    The issue may be due to any recent hardwrae or software changes and also due to any virus.
    1. Remove any recently added hardware/software.
    2. Try to boot the computer in safe mode. Press F8 button soon after restarting the computer to enter the advance boot option and select safe mode to boot computer in safe mode.
    3. If issue persists even in safe mode, perform a system restore to an earlier time or date when the computer was working as expected. Performing system restore will not delete any data from the computer.
    4. Reset BIOS to default values. (Press the F2 key after restarting the computer to enter and access BIOS).
    5. Press F3 and F4 keys to reset the BIOS. or press the right arrow key until you reach the exit menu, then select the load BIOS default option.
    6. Then, select the Yes option when promted, save the settings and select yes option. restart computer and check.
    7. If still persists, perform a system recovery using the VAIO Care Software or the F10 recovery partition.
    Note: ensure to backup any important data before perfoming system recovery. System recovery will erase all the data presnt in the computer.
    Nov 07, 2010 | Sony VAIO Notebook
    My sony vaio desktop with all the icons shifted to the left
    If there is nothing wrong with your monitor, you should have a menu button on the monitor , open it and reset it to factory defaults. Also right click on your desktop, select properties and make sure you have your resolution set correctly, try changing it and see if that helps.
    Oct 02, 2009 | Sony VAIO PCV-W600G PC Desktop
    Sony Vaio FX-410 BIOS Password
    NO click and no spark,no shock. Only very low voltage. Their is only two contacts points on the battery holder one for the center of the battery and one for the side. Touch the paper clip to the two points.
    Jan 17, 2009 | Dell Latitude C400 Notebook
    Sony VAIO PCV-V200G PC Desktop Logo
    79 people viewed this question
    Top Sony Computers & Internet Experts
    Ekse
    Alun Cox
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
