Question about HP Pavilion dv8000z Notebook
HP Pavilion DV8000 Laptop USB problem
I plugged a motorola cell phone into the usb port. and computer froze now my usb ports do not work properly, My usb mouse lights up but does not work or recognize. My 500 Gb usb conected drive starts up and says i may be using usb 1.1 but I cant get into drive. I have reloaded the windows xp pro + service pack 2 files and the application and hardware drivers disk I recieved with the computer. I've also tried updating through hp and windows XP. Is hadware fried or can i fix this? Please help me!
  • 1 more comment
  • scottsdamack Apr 19, 2008
    I just gave that a shot right now and that didnt seem to do it.
    thank you for suggestion, I'm happy to have any extra ideas come in.
  • pasnby3844 Dec 02, 2008
    Same problem here. The USB was working fine and just quit. All checks report everything is O.K.
  • Anonymous Mar 19, 2014
    I bought it used so I don't have boot flash drive
Did you try reloading the BIOS drivers?
Posted on Apr 14, 2008
Hello i want to use my motorola w270 to connect to an internet over pc i have installed motorola phone tools v4.5 as well as v5.0 but both version is unable to detect my phone. So please suggest me how i...
Try to plug your phone to other USB port in your PC I will recommend to plug it at the USB port at the back of your CPU. USB supply of power at the back of the CPU is sufficient to make your device function properly so it may be able to detect by the system..mostly device can't recognize by the system because they didn't function properly specially if they are plugged in a USB port who don't have enough supply of power to make them work properly..Hope it may help you..
Jul 11, 2011 | Motorola Mobility W270 Cell Phone
Hp pavilion a610y Describe your hp pavilion a610y usb port Problem: Message tells me to unplug my highspeed device from my slow usb port on my zboard keyboard and plug it into one of 6 unused usb ports in...
It is referring to the USB ports on the back of your computer near where your keyboard plugs in. The front ones must be USB 1.1 which will cause this error.
Apr 01, 2011 | HP Pavilion A610y PC Desktop
W385 not charging off computer
you have to give more detail to your question to get a better diagnosis.
(1) have you charged from this USB port before?
(2) Are you using a laptop?
There are 2 basic types of USB ports. powered and non-powered.
Sometimes you have to go into your computer settings and tell the computer this USB port you want powered.
The reason I asked if you are trying to charge using a laptop is because most laptop USB ports or non-powered because It will drain the battery down too fast.
if this is the case you can look into buying a powered USB hub which you can plug into your non-powered port you should be able to then charge this way.
good luck hope this helps.
Mar 26, 2010 | Motorola Mobility W385 Cellular Phone
One USB port outlet of my laptop is not working.
Interestingly some USB ports can not power all accessories that are plugged in to it. Try another port, if that works you're still in business. I believe that unit has at least 4 ports to use.
Jan 06, 2010 | HP Pavilion dv9700t Notebook PC
Cannot connect to computer
FIRST OF ALL, NEVER EVER PLUG IT INTO THE COMPUTER WHILE ITS ON. ALWAYS TURN THE PHONE OFF BEFORE HAND. AS FAR AS YOUR COMPUTER NOT RECOGNIZING THE USB CABLE, IT MAY ACTUALLY BE YOUR COMPUTER. AFTER ALL IF IT WAS THE CABLE, YOUR PHONE WOULDN'T CHARGE SINCE IT IS THE SAME CABLE FOR CHARGING AND USB CONNECTIONS. MY COMPUTER HAS HAD TROUBLE SEVERAL TIMES WHEN PLUGGING IN NEW OR DIFFERENT DEVICES INTO THE PORT. TO CHECK THE USB PORT ON YOUR COMPUTER.... GO TO CONTROL PANEL, THEN DEVICE MANAGER. DOUBLE CLICK UNIVERSAL SERIAL BUS CONTROLLERS. IF ANY OF THEM ARENT WORKING PROPERLY THERE WILL BE A YELLOW TRIANGLE WITH AN EXCLAMTION POINT BESIDE THE UNFUNCTIONING USB. IF IT IS NOT FUNCTIONING YOU WILL HAVE TO UPDATE THE DRIVER. IF YOUR PORTS, DRIVERS ETC DONT SHOW THE YELLOW TRIANGLE, THEY ARE WORKING. TRY PLUGGING THE PHONE INTO A DIFFERENT PORT UNTIL YOU FIND ONE THAT WILL ACCEPT IT. I HAVE A LAPTOP AND MY PHONE ISNT RECOGNIZED IN THE SAME USB PORT (ON THE RIGHT SIDE OF THE COMPUTER) THAT I USE FOR MY PRINTER. I USE A DIFFERENT PORT FOR MY CELL PHONE. IF YOUR COMPUTER IS OLDER , THE USB PORT MAY NOT BE HIGH SPEED. OLDER COMPUTERS HAVE USB PORTS WITH A SPEED OF 1x OR A MIX OF PORTS WITH 1x AND 2.O (2.0 IS HIGHSPEED 1x IS NOT). I HOPE THIS HELPS!!!
Jun 23, 2009 | Dual Electronics CECT P168 Cellular Phone
How about this Pavilion dv8000 Battery for HP Laptop Battery?
You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
Jun 02, 2009 | HP Computers & Internet
My usb port does not respond on my HP laptop
Hello there.
I understand that you are unable to use the USB port of your computer.
To isolate the issue try performing these steps.
1) Check whether the device is working fine.
2) Check with other USB ports to the same Notebook.
3) If these steps do not work then you can do this.
a) If your Notebook is under warranty you can send it to free repair ( Contact HP.com for more information)
b) If it is not under warranty then check for the repair cost from HP.com chat support.
Feb 14, 2009 | HP Pavilion dv9000z Notebook
Problem
I have discovered that some of the usb cables that connect to your phone and your computer do not all work. At one time I had to try 3 different cables before finding one that worked on my phone and computer.
I also learned that if I could not get my computer to acknowledge that the USB was being used by my cell phone I would shut down my computer and then try a different USB port. Sometimes it made a difference.
I have heard that when you first use a program with a specific USB port it is best to always use the same USB port if you can remember which one you used in the first time for that program.
As for losing your CD. I am figuring that this is the CD for Motorola Tools??? If it is you can do a search online for Motorola Tools Free Download... I hope I have helped.
Jan 14, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Wil not connect to my Motorola vm9 cell phone
try othrer usb port of your computer.
allport check if same problem.then check if u have other u sb device when u connect it pproper working or not.if othe rusb device is also not work then may be your usb connection to mother bord are rong.
or on bord usb are not working properly.
try all usb port for checking.
also front and back usb port.
Nov 27, 2008 | Jabra A320s Bluetooth Wireless Adapter
HP Pavilion dv8000z Notebook Logo
914 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
