54 flat screen tv zenith
The television will not turn back on, we shut it off came home turned it on will not go back on its only a few years old
  • 109 Answers
First verify power to the outlet, second, you'll have to remove the back, and where the power cord comes in to the first board there will be a fuse, check it.
Posted on Apr 03, 2008
SOURCE:
My 55inch LG 3D smart tv is not working properly. When you turn the tv on the LG home screen comes on for a few seconds, and then the screen goes black. What is causing this
it's set to the wrong input device ? the one you currently have it pointed to has no input
also it's possible that cable plugged into current input channel has gone bad or become disconnected from it's source
Hdmi cables are unfortunately famous for this as they have no Lock device to keep them inserted into ports
most TV's nowdays shut off if not provided an input for a few minutes
Jun 01, 2015 | LG 55LM6700
My Zenith 52 inch flat screen will automatically shut off after 1-2 mins of turning it on... why?
some tvs have a menu where you can controll that there should be a menu button on your remote try doing that and switching the automatic shutoff to off
Feb 22, 2013 | Zenith Televison & Video
I turn on my tv and it immediatly shuts off
I have a big box flat screen tv that after you cut it on it cuts back off and then you cannot cut it back on
Sep 22, 2009 | Samsung PCL545R 54" Rear Projection...
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
TV Turns green and shuts off and less than 5 seconds.
In that TV its usually a bad picture tube. The green element of the tube is shorting.
Mar 13, 2009 | Zenith D32D51 32" TV
After a few minutes picture shrinks to single line on screen and then powers off
Since the set works initially, there are likely poor solder connections at the vertical IC. If this is not addressed soon, the IC will fail and need to be replaced. The vertical IC is a small flat IC with about 11 pins or so that may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace teh IC. Feel free to post the marking here so I can verify you have the correct one.
Dan
Jul 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is snowy/dark
update: Well, we ended up calling the repair man and we had a bad Y-sustain board and also a bad Z-sustain board. According to the guy who fixed it, it was due to over use of the TV and using main power button instead of shutting off through the cable remote. 650.00 later and a few weeks later, we now have a fixed plasma. No real suggestions on how to get more life out of the new boards.
Sep 12, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
Top Televison & Video Experts
Ekse
