Question about Acer AL1916W 19" LCD Monitor
Problems with monitor Acer AL1916w
I cannot find the right resolution for the Acer monitor AL1916. The text looks flat. Help
  • Anonymous May 11, 2010
    Are you running XP or Vista?
    Problem Solver:
  • 5 Answers
I'm using the Al1916W and it looks great at 1440 x 990. Make sure you have the latest Screen card drivers installed.
Posted on Apr 23, 2008
SOURCE:
How to change monitor aspect ratio for acer AL1916
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between width and height of (in your case) your monitor.
Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
Oct 22, 2013 | Acer AL1916 A (Black, Silver) 19 inch LCD...
How do i set the monitor so the text and icons appear clean and crisp?
go to acer website and download driver for monitor or graphics monitor. Make sure you download AL 1916W and NOT AL1916. Make sure after, you set your resolution to 1440 x 900. That should do the trick.
Feb 03, 2011 | Acer AL1916W 19" LCD Monitor
ACER LCD monitor has no power.
It is probably the inverter which powers the backlight. It should say inverter right on it.
Feb 08, 2010 | Acer AL1916B 19" LCD Monitor
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Acer Monitor Display of text and image is not sharp
This might seem obvious, but is your video card output set to the native resolution on the monitor? If not, it will look fuzzy. Try 1680x1050, if you don't know the monitors native resolution.
No need to use anything higher than a 60hz refresh rate either.
Mar 29, 2008 | Acer AL2216WBD LCD Monitor
Annoying Nuisance on the monitor
Run your system in 'Safe Mode'. Go to Display settings and set lowest possible resolution. Then restart computer and run windows again in normal mode. Should have normal screen. If this will not work - then under safe mode uninstall graphic card. Then run windows with standard ones and in LOWEST possible resolution install drivers again. I have had it many times and it made swear first time.
Oct 28, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
436 people viewed this question
Ekse
Alun Cox
