Question about Sega Master System Console
Bad signal on my sms 2
Hi i have a problem wit hmy old sega mastersystem 2 for some reason i cant get it to tune into the tv properly
i tryed replacing the Rc cord but it made only a little diffrance and it is still a little fuzzy what do you think the problem is.
Also make sure you have it on the right channel. Check the switch in the back.
Posted on May 07, 2009
  • 36 Answers
The RF cables for the master system are typically very thin and poorly insulated. TVs have improved a lot since 1980s, so have expectations. If it's REALLY fuzzy you could try:
- a better quality/shorter RF lead
- a better power supply (believe it or not this CAN affect the picture quality) - SMS/Megadrive/NES/SNES all use the same power supply
- make sure the cable doesnt run near any sources of interference (eg mains cable or energy saving light bulbs)
- RGB AV cable as mentioned
Posted on Oct 10, 2008
  • 167 Answers
I had the same problem, don't use rf, use an ave cable you can find them on ebay
Posted on Jul 02, 2008
When everything is connected as should be and switched on the sega does not appear to make contact with the tv set. the tv set is analogue and ha allways been used with the sega
Hi the cables are know to become faulty due to age and wear. try replacing the cable but make sure you have tried to tune it into your tv first. There are now new AV cables on the market which suits some segas see www.gameoz.com.au for a large range of accessories for these old consoles
Aug 21, 2010 | Sega Genesis Console
Hi i have a sega megadrive 2 and have only just got it out, but now have a Bush digital TV and the Sega is on (power) but I can't either locate the channel or am confused on how it connects up to the Tv to...
I think those have the old style RF connectors.A coaxial cable with a grey or black box in the connection cable.Plug the coaxial cable from outside into the RF cable.Plug the RF cable into the TV coaxial input(regular cable input).On the back of the Sega,there should be a switch for CH3 or CH 4.Put the TV on the appropriate channel.If the signal looks bad,switch the selector on the Sega and change the TV channel.If you do not have the RF cable there is a place that still sells Sega accessories,but not Sega.They must have contracted with Sega.If you need the site let me know.
Aug 02, 2010 | Sega Megadrive Black Console
Black and white Picture Sega Master System 2
Is this one of those much older Sega systems with the RF connector that plugs into the incoming cable from outside and the TV?If it is,there should be a channel selector switch on the back,CH3 or CH4.Try the other channel.If it doesn't go away,your RF connector is on it's last legs.
Good luck and game on!
Jul 26, 2010 | Sega Master System Console
Can't find the frequency for the genisis 1 sega megadrive, I have the RF converter but I've tried doing auto search and manual, just cant find it...
Hi some new TV'S may not have the frequency of these old consoles i recommend purchasing a AV cable which is can be found at http://www.gameoz.com.au/store/sega-mega-drive/mega-drive-accessories/sega-mega-drive-1-av-cable.html
No tuning in a channel and better picture Quality
Apr 24, 2010 | Sega Genesis 2 Console
Sega megadrive 1
the video cable may be damaged try cleaning out both sides
Jan 01, 2009 | Sega Genesis 2 Console
I am trying to locate a auto rf switch box for my sega master system 2
Looks as if Nesfixxa400 has never seen athe back of a Mastersystem 2, there is only an rf lead port!
so you are looking for a RF splitter
you can seach for the following
master system rf switch box
Megadrive 1 rf lead with switch box
I also remeber at a 99p shop seeing a 3 way TV switching box
search for MK-3088 on ebay (below) they are compatable
http://search.ebay.co.uk/search/search.dll?sofocus=bs&sbrftog=1&dfsp=1&catref=C6&from=R40&satitle=MK-3088+&sacat=-1%26catref%3DC6&a14=-24&a6=-24&a10244=-24&alist=a14%2Ca6%2Ca51%2Ca10244%2Ca3801&pfmode=1&reqtype=1&gcs=1132&pfid=1621&pf_query=MK-3088+&sargn=-1%26saslc%3D3&sadis=200&fpos=IG7+5BP&sabfmts=1&ga10244=10425&ftrt=1&ftrv=1&saprclo=&saprchi=&sass=&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search
Jul 01, 2008 | Sega Master System Console
With my sega megadrive11 system when tuned in only sound comes no picture
Hi Wisebear,
First It maybe your TV not tuning in properly.
to try this go to your TVs Tuning menu and select manual tuning and fine tune around the sound and see if this helps...
second it may be the lead (worn wire) and not enough signal getting through, so you need a new cable
you may just want to upgrade to a scart lead
www.retro-cache.com
sells the scart lead for Megadrive 2's and soon will be doing Megadrives 1's as well, both RGB.
Jun 27, 2008 | Sega Genesis 2 Console
Sega master system 2 setup - can't get picture
most likely problem is that your tv isn't tuned to the sega - you can fix this by going into the tv menu and tuning it manually
Mar 31, 2008 | Sega Master System Console
Sega megadrive
Try an Old School RF switch for channel 3&4 if you can find one try raido shack
Feb 07, 2008 | Sega Genesis 2 Console
Sega Master System Console Logo
573 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
