Question about Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon Rebel Ti Broken Back Door Latch
I found a place that sells replacement parts (inexpensive, too - yah!): http://www.bocaphoto.com/products/new/canon/canonacc.htm. Can the repair be done at home? I tried to get the back off, took out 6 screws, but couldn't get the main piece inside the door to come out in order to get to where the broken latch is. How do you do that? Or should I take it to a professional?
  • 1 more comment
  • snappy nik May 06, 2008
    a local repair shop wants 35-40 to fix mine. its a $5 part... let me know if you try to do it yourself. i want to fix mine myself too.. but can find NOTHING online to help.. its like you have to be part of a secret society to know how to fix it i guess.. haha..
  • Thanks4help May 23, 2008
    I ended up buying the replacement part from Canon http://www.usa.canon.com/consumer/contro... because it was cheaper (part was under $2, plus s/h = $7.97). I needed it repaired quickly, so I took my camera to a local camera shop, which cost $35 to get it fixed. It's really frustrating that Canon even charges for this faulty part! They should be replacing it for free & making them metal!! I had a client lined up to photograph, when I realized my camera was broke : ( Thanks for the helpful advice, MF! I'll certainly try that next time = )
  • kendalesachi Dec 21, 2008
    I have a EOS Rebel Ti 300V. Its back cover is not closing. Its not closing with or without a film. I tried to tape the cover so film reloads but no luck.
Hello;
There is one more screw hidden under the pressure plate, push it down and slide it towards the hinge to remove it. Welcome to the secret society! MF
Posted on May 22, 2008
SOURCE:
How can I get repair parts for my eos elan 7 Canon film door?
Remove front cover to get to latch. Be careful not to touch the flash circuit as it can have a nasty 300 volt shock.
Canon parts phone number: 732-521-7230. They used to take credit cards, not sure if they still do. They are really good about ordering by description.
Jun 11, 2014 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Battery door latch broken
look for a Canon eos 300D battery door (they are the same camera just came out in different countries) or buy of ebay a cheap broken 300D and salvage the parts that way.
Mar 21, 2013 | Canon Eos Digital Rebel Ds6041 6.3 Mp...
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
How to replace the door latch on a canon rebel eos ti
The cameras film door has a very small phillips head screw inside the battery doors hinge. Its a pain to take out & replace if you hands are shakey for this screw is so small. Also installing the replacement hinge would be a little harder to install tha removing the broken one.
I hope this information will help you. A camera shop should be able to do it for free if you maybe purchase some items there. Most shops which are very small and privately owned shops will do this for you
Mar 03, 2009 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Digital rebel EOS 300D
Once the CF access door is open, just push the small square button that will be below the card. That moves it out enough to pull it out. When putting a different card in, take care not to just jam it in as you could bend the pins.
Aug 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Fitting replacement film door release catch
I suggest you bring the camera to the Canon service rep in your area and for a few dollars you let them do it. This way, if there is any damage they are responsible.
I don't know the answer for your particular model, but in many of these cameras it is possible to easily do colaterol damage when changing parts.
Jerry G.
Apr 09, 2008 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Replacement Film Door for Rebel Ti
You should be able to get that part direct from Canon USA. Here is their info: For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
Jan 08, 2008 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Film door latch is loose
My crystal ball tells me that you are referring to you vintage 1939 Pentax SLR camera! Is that correct?
May 12, 2017 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon EOS Rebel Ti / 300V 35mm SLR Camera Logo
997 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Canon Photography Expert? Answer questions, earn points and help others
