Question about Sony PlayStation Portable (PSP) Console
Help plzz i upgraded my psp and after the upgrade i cannot find the games i used the usb and plug into my computer.i saw the games were there but the psp is not showing anything i can't play a game and any software i download could not be start plz help me and tell me how to correct this problem
If its downloaded games,u gotta have an iso folder on ur mem card and its better to use ur psp in the transfer...plug it into ur computer and put it on usb mode,then open the psp to the iso folder and just drag and drop the file...or copy and paste it..mine works that way
Posted on Apr 05, 2008
SOURCE:
HOW TO UPFRADE THE PSP?
Hello. It is very simple do to this. You should only follow my steps:
First of all, you have to download a file name called EBOOT.PBP (psp upgrade) which is located HERE
Save it on your desktop and do not rename the file.
Plug in your USB cable and go to your PSP's System Settings and on the second from the top press X on USB CONNECT. Go to "My Computer" and click on Removable disk. Here it should be a folder named PSP followed by a subfolder called GAME. Enter this folder, create a new folder and name it UPDATE (in caps without spaces). In the folder you have just created, move (copy - paste) EBOOT.PBP here from your desktop. Also, if there is no GAME folder, you have to create it in the folder "PSP". Be carefully! Remove your hardware and fully charge your PSP and plug it on the wall. Go to Games Area and choose Memory Stick by pressing X. You will see now PSP Update version
*. **. Press PSP Update version *. ** (it will only clear your screen for a couple seconds). Press Start if you want to upgrade. Go to User Agreement and start the upgrade process. While it's started, do not touch your PSP. Leave it somewhere until the upgrade is done.
I hope I helped you!
May 21, 2011 | Sony PlayStation Portable (PSP) Console
Up grade
The process of upgrading comes with a few essential requirements. If you are looking to upgrade using the services of the PC then you must have prerequisites like, a PSP with a battery pack, a minimum of 20 MB of free space on the Memory Stick, and a good Internet connection. You can also use a USB cable instead of the memory stick. Once you download the upgrade on the PC, the next step would be to transfer the firmware upgrade onto the PSP. This can be done using the USB cable or the memory stick. Users must insert the cable of the Memory stick in the PSP and start updating. For this, users are required to select the appropriate option from the home menu and then press the required button to start upgrading. At times, the whole process will get confusing, if you have not differentiated the various folders on the memory stick or the PC. The best way to avoid this is by storing the downloaded firmware in an aptly named folder.
A word of caution: Store the data in the correct location. If not, then there is a chance that the PSP system will not identify the data that is updated. Also, make sure that the battery is fully charged before use. Furthermore, an AC adaptor must connect the PSP to an electricity point. While upgrading the PSP, there must be no stoppages in the process. If the upgrade stops midway, it might just damage the PSP.
Upgrading you existing PSP is very easy. A person with a limited knowledge of using a PC can accomplish this task successfully. It is of paramount importance that you upgrade the PSP on a regular basis. As new games with better graphics enter the market, you must make your PSP compatible for the same But, this is not restricted to games alone. Videos, and music demand better picture and sound quality respectively. This can only be achieved by getting new and better upgrades for your PSP.
Dec 22, 2010 | Sony PlayStation Portable Slim Black...
After i download the game Digimon World 2 how do i put it in the PSP????
you need to connect your psp to your computer using usb cable and transfer it to ISO folder. But be sure you upgraded to custom firmware like gen-c to be able to play games otherwise it will not load or not playable.
Dec 12, 2010 | Sony PlayStation Portable (PSP) Console
How to upgrade a psp unit slim version
connect to a WiFi access point and select system update from the settings menu. if you do not have access to a WiFi connection you may connect your psp to your computer via USB and download the firmware upgrade from sony's website. Hope this Helped! Remember to Rate!
Aug 23, 2010 | Sony PlayStation Portable (PSP) Console
How can i update the firmware of my psp in firmware 6.00
  1. Get the firmware upgrade data. You can get one on the official PSP website[1]. When clicking Download Now, remember to Save it, not open it. The file name should be EBOOT.PBP Save somehwhere where you can access it easily e.g. Desktop, My Documents, C:\. 180px-psp_619.jpg magnify-clip.png
  2. Plug in your USB cable that you have bought or had to your PC or Computer (same thing). On your PSP you should go to System Settings and on the 2nd from the top press (X) on USB Connect. On your computer it should say something like New Hardware detected USB Mass Storage Device. In My Computer there should be something named "Removable Disk"
  3. Click on the Removable Disk and inside there might (might not be) be a folder named "PSP". Click on the PSP folder to go inside of it and inside the PSP there might be a subfolder named "GAME".
  4. Inside the GAMES folder, create a new folder and name it UPDATE in caps, no spaces. Inside that UPDATE folder drag and drop that EBOOT.PBP that you downloaded earlier.
    • If the PSP folder and GAME folder are not there, you can just create them. Remember that the folder name MUST be in CAPITAL LETTERS and the the GAMES folder is INSIDE the PSP folder, don't mess this up or your PSP will ignore your folders
  5. "Safely Remove Hardware" -- this should be in your Icon Bar on the Right side of your start bar.
  6. Fully charge your PSP and plug it into the wall. Go to the Games Area; there should be an Icon that says Memory Stick Choose that by Pressing "X" and you'll see PSP Update Version *.** (* meaning what version you've downloaded onto your PSP).
  7. Press PSP Update Version *.**, It'll clear the screen for a few seconds and come back on saying "PSP System Software Version *.**" It has a "Start" option or says that you already have that version. Press the Start if you want to upgrade.
  8. Go through the User Agreement and start the upgrade Process. When it starts, remember not to even touch that PSP. Just leave it alone on the floor, desk , chair, etc.
[edit]Steps-Method 2
  1. Go to network update, under Settings.
  2. The PSP searches for possible updates.
  3. When the updates come, bypass all agreements etc. by pressing X button.
  4. Let it update in peace.
[edit]Steps-Method 3
  1. Make sure you have a UMD inserted.
  2. Go to game and choose PSP update.
Oct 28, 2009 | Sony PlayStation Portable (PSP) Slim...
HI,IF YOU ARE READING THIS THEN ANSWER MY QUESTION ON [email protected] Q-HAS PSP-3004 UPGRADER IS AVALIBLE OR NO???
i saw that there is a upgrade for psp 3000.try to ask someone if they tried upgrading their 3004 with the upgrade for psp 3000
Oct 01, 2009 | Video Game Consoles & Games
Psp
You just connect the psp to your computer using a usb cable.Then create a folder in your Memory Stick Duo named “PSP“, under this folder, create a sub-folder named “GAME“, under this sub-folder, create another sub-folder named “UPDATE” (Note: all folders name must be CAPITALIZED).Download the PSP 5.51 update file via this link: http://du01.psp.update.playstation.org/update/psp/image/us/2009_0611_148d2a024741df54eacabbc79d9f3014/EBOOT.PBP.Save the file as “EBOOT.PBP” to your desktop then inside the UPDATE folder copy the EBOOT.PBP.Then go to games>memory stick and hit the x button there should be an game press x again to upgrade.The udpate process will take about 10 minutes.Thats all.
Aug 22, 2009 | Sony PlayStation Portable (PSP) Console
I cant play games in psp after i upgrade in to 5.51
All official games should run in newest updates, try updating the GAMES.
Jul 20, 2009 | Sony PlayStation Portable (PSP) Console
Games not showing
Sounds like you had homebrew or similar firmware to play images (copied games) from your memory stick. Now that you have upgraded your firmware to an official Sony release these are no longer supported.
Mar 04, 2008 | Sony PlayStation Portable (PSP) Console
Games not showing
the file wont fit? maybe the higher vertion of your upgrade cant read the game, , ,try to downgrade it if it works
Mar 01, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
44 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
