Question about Nokia N70 Cellular Phone
Nokia N70 wont acknowledge memory card?
I recently got a Nokia N70,got its memory card a few days later.The problem im having is i insert the memory card in the slot (tried both sides) but the phone wont acknowledge its there.
I go into the memory file on the menu & it just says "no memory card inserted"?
Please Help
T.I.A
  • faroogoo Apr 03, 2008
    Wouldnt accept it at first but after turning it off & back on a few times this morning it just started working.
    Thanks for your advice though Raysagem im going to save it anyway because i think it'l come in handy.
  • Thx_nb May 11, 2010
    which memory card do you have? type and size...
    President:
  • 1,017 Answers
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
provider.
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
slot and are not compatible with this device. Using an
incompatible memory card may damage the memory card
as well as the device, and data stored on the incompatible
card may be corrupted.
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
card
. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
Posted on Apr 03, 2008
Im using a nokia N70 it doesnt want to take a memory card although its inserted
hi, its not that your does not want to take a memory card...its very possible for it to insert perfectly but the problem could be that of compactibility...its is possible the memory card you have inserted is not compactible with your phone.
cheers
Feb 16, 2011 | Nokia Cell Phones
I want toformat micro sd 1gb memory which is used in mobile
If i am right, micro sd card isn't compatible with Nokia N70. I think you are using it on another mobile handset, if it's nokia, follow these steps; Go to "File Manager" highlight the "Memory Card" select "Option" scroll down and again select "Format" then "Ok". You'll be presented with a warning message, select "Yes". It'll take few minutes. Or if you have a card reader, insert the memory card in the card reader and connect it to the computer, Right click on the memory card and select "format". Good luck. Thanks for using FixYa.
Jun 10, 2010 | Nokia N70 Cellular Phone
My nokia phone N70 can not access my memory card, the battery get flat quick while my memory card is inserted into the memory space it keep telling me NO MEMORY CARD INSERTED,
format memory card with FAT16 / FAT32 then try it.
keep in mind it is supported by ur cell means some phone support upto 2 GB..
Apr 07, 2010 | Nokia N70 Smartphone
On my Nokia N70, my phone memory card is not accsesible . Even it shows " No Memory Card inserted " on my Mobile after inserting it into phone and when i connect it to computer it does not shows memory...
first connect your memory card to a card reader and check wehther it is recognising...if no,sorry to tell you this, your memory card is currupted. formating is the only one way to get bak your memory card...hope this will helps you...thank you...
Oct 15, 2009 | Nokia N70 Cellular Phone
Memory card is not read + nokia N70
hello
for this open your cell phone in a safe mode by pressing the pencil button on cellphone
once the phone is up pleae reinser the card , it will read it
Mar 24, 2009 | Nokia N70 Cellular Phone
Nokia N70 Insert sim card problem.......
i can solve this
if you want to format your memory follow this:
menu>tools>memory>then press options>from the list select format mem.card.
Dec 30, 2008 | Nokia N70 Cellular Phone
My nokia n70 memory card show corrupted memory card.
replace with a new memory card...this might be faulty...
Dec 01, 2008 | Nokia N70 Cellular Phone
To unlock n70 's memory card
im using a nokia n70 phone, my problem is ,when im playing mp3 music ... memory card corrupted appears... can you help?
Jul 05, 2008 | Nokia N70 Cellular Phone
Crappy nokia n70
To format a memory card on the N70:
Menu/Tools/Memory card,open it, Options, scroll down to Format memory card.
May 23, 2008 | Nokia N70 Cellular Phone
When i insert mmc card MU13 in my cellphone N70 it says memory card corrupted. In pc I can't format pc says no card inserted. Pls give me a solution, there is no way to format. Muhsin
To format your memory card:
Menu/Tools/Memory card/Options then Format memory card.
"I don't want to achieve immortality through my work, I want to achieve it through not dying."
May 06, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
543 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
