FixYa.com
Tags:
Denon AVR588 7.1 Channels Receiver
Denon AVR 588 7.1-- Sound setup questions (by 2 users)
posted by CJW1949 on Apr 03, 2008
I have messed with the settings for quite a while now but with no evident success.
I do not get a tone from speakers when in Setup. I do get audio through the speakers when I use the radio tuner -- so the speakers are connected and working.
When I try to run a PS3 either as a game or dvd player using HDMI cable into the receiver and another HDMI into my Panasonic plasma tv I only get sound via the speaker in my tv.... not through the speakers via the 588. What on earth am I doing wrong? The picture displays as 1080p so the HDMI is certainly passing the picture correctly.
I also have a satellite dish feeding through component cables (red,white,yellow) into the receiver and from there via the same type of cables into my tv. No luck at all.
My Sony DVD recorder is linked into my satellite receiver with component (red,white,yellow)and also into the Denon via composite (heavy cable with red,blue,green markings) for video and red,white for audio. Also no success.
I have also tried using optical cable from PS3 into the Denon (both input one and 2).
Please help me sort this out or my "buyer's remorse" will see the unit go back to the dealer.
In l
Comment by CJW1949, posted on Apr 17, 2008
As the original poster, I would like to end this thread--- I gave up on the Denon--- for all its array of connectors on the back and its specs, the thing was just impossible for me to demystify and configure. I returned it to the store (although I gave the sales staff another chance to talk me through the process- they had no slight clue of what to do). I replaced it with a Harman Kardon AVR 146. Its manual makes sense! The website is actually helpful. I got most things going in good time. I can work on the nuances over time and get it just right.
As I asked this question -- here is my solution! I returned the Denon and replaced it with a Harman/kardon AVR 146. I could not demystify the Denon-- the manual was useless to me and their website was even worse! I gave the electronics store another chance to talk me through my problems but they had no slight clue of what to do.
The AVR 146 may not have everything the Denon boasted of but it did have a reasonable manual. Careful reading was actually helpful in solving any problems I had. I still have a rat's nest of cables behind my tv-- but now I am actually able to watch it and enjoy my sound system. My advice to others in the same position--- Ditch the Denon.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by squintpew, posted on Apr 09, 2008
I Have the same Problems.
Solution #1
posted on Apr 16, 2008
Not Rated (0)
t_hutch
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This reciever does not decode the audio through HDMI, the HDMI ports are simply a pass-through. To get audio you need to connect an optical audio cable from the PS3 to the reciever also. I figured this out after 2 hours of trying to get audio from the HDMI cable. Here is a link that shows the different audio formats supported through HDMI by the different Denon models. It looks like the AVR-788 is the lowest model that supports audio through HDMI. Hope that helps.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Receivers problems?
Get static sound when I watch...
The denon is hooked to my... Answer This...
Get static sound when i watch...
The denon is hooked to my ps3,... Answer This...
Denon AVR-588 Sound Delay
hello, I'm using Denon AVR 588... Answer This...
same issue
any other suggestions? i am... Answer This...
Bass ant Treble adjustment
With tone defeat off. How do I... Answer This...
Repair Service
Find Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
