Question about Canon FAXPHONE L80 Laser
Can't receive and send fax
I am using a VOIP for Fax for almost a year now; everything is working perfectly until I replaced my old router.
Hope somebody could help me fix this problem.
  • 82 Answers
Check to see if your phone line is plugged into correct slot marked with an " L " or line on your fax. and that you are getting a dial note from your fax by selecting the speaker button or by connecting a phone into the other slot on your fax marked by a phone and listen for a dial tone.
Thank You,
Mikey
Posted on Apr 06, 2008
8860 wont send or recieve fax on cable modem
Fax machines usually only work over regular phone lines, not through digital cable or DSL systems. If your phone is a VOIP phone, it is a digital system and your fax will not work. It needs to be plugged into the Plain Old Telephone System (POTS) which is an analog system.
May 05, 2012 | Xerox Office Equipment & Supplies
I own a Canon Pixma MP530 all-in-one fax,copier, printer,scanner. I cannot send or receive faxes since I switched my Comcast voip phone line from my office to my home phone, along with my MP530. The fax...
First try one step. The line which you have connected with the Fax, unplug any other phone from that line.
Call that number and see whether it rings or you get a fax tone.
Sep 13, 2008 | Office Equipment & Supplies
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
How do I change the setting in order to use fax on voip line?
Hi
The data transmitted during a voice call and a fax transmission are converted to digital pulses in the same way, so sending is not the problem. The problem is at the receiving end. A receiving fax device has to be set to pick up the call before the voice call device, as it is the prompt of the fax transmission signal that makes the receiving fax switch from send or idle to receive mode.
So, if you are faxing over the internet the intended recipient's setup is a complicating factor.
Since faxing to landline fax machines via VOIP would incur a charge, you might consider a cheaper software solution such as eFax (www.efax.com), which enables the receiver to receive the fax as a PDF document attached to an e-mail.
I hope this helps
Aug 26, 2011 | Ricoh AC104 All-In-One Laser Printer
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
My Dell Photo 964 All-In-One won't receive faxes, but can send them just fine. All other features are alright. Spoke to Vonage (our phone service) for 2 hours troubleshooting and sending test faxes, and it...
First check a couple of obvious things:
Sometimes the presence or absence of a (DSL) filter on the line can affect fax reception.
Also check to make sure you have not enabled Fax Blocking.
Otherwise, I can only offer some information HP provides for support of VoIP fax setups, available by clicking here., and hardware setup options available here. Whether it is even remotely useful in your situation you'll have to judge.
You know there is also a Dell Forum where users
can pose questions and exchange answers. Have you checked to see if there are solutions posted there? Dell Forum 964fax error
I'm afraid I am not familiar with that particular machine or Vonage...sorry I couldn't offer anything more...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | Dell Photo 964 All-In-One InkJet Printer
Voip phone is workin properly but when i try to send fax it shows comm error
Make sure the same dial tone you can talk on is plugged into your fax machine. Try plugging a plain old telephone into the wall jack your fax is plugged into. Until you hear dialtone in that jack, don't bother troubleshooting the fax any more.
Dec 17, 2008 | Computers & Internet
Can't receive or send fax
Unfortunately Voip communication protocols are usually not fax friendly. I was able to send fax from older fax machine (when the only plugged in to the router was my Viop box. But new Canon Faxes are using some new communication, that seems to be even more difficult to fax over Voip. It also depends what kind of set up is on reciever end. Try to find out what kind of protocol are you using (ask you provider) and if there is any option in using different protocl, that may be able to transmit fax signal.
Dec 16, 2008 | Canon MX310 Office All-In-One Printer
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Drops connection after connect, sends 2-3 pages
The fall-back required for transmission over VOIP is not available on this machine. It is a service mode function and can only be set by a technician. However, VOIP is so iffy for transmission that you may require fall-back to 4800 or even 2400. I have found that forcing fall-back more than 2 steps doesn't work.Also the Line equalisation can't be set as there is only 3 settings, 1.8;3.6; and 7.2 Km. Who knows how far to set VOIP, could be 3000KM. I had more success using a very old fax machine sending at 2400BPS that I could set the dip switches. Takes all sorts of changes to have success and then next time you try, it's changed again.
Feb 15, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Canon FAXPHONE L80 Laser Logo
66 people viewed this question
old marine
old marine
