Question about Toshiba Satellite 2805-S603 Notebook
When ac is plugged in the power light blink & notebook unresponsive
My ac post broke and i currently have the adapter spliced and soldered to the board.. but even before i Frankenstein'ed it in this fashion... the power light blink & notebook unresponsive when the ac is plugged in. it also wont charge my battery. when ac is not live.. the notebook works using battry power, but being the battery is LOW it shuts down after a few seconds. and plugging in ac causes it to overide battery power and shut down.
??????????????????????? HELP ME PLEASE...
    Genius:
  • 1,027 Answers
Sounds like your ac adapter (brick) is bad and not supplying correct voltage/amperage.
Posted on Apr 03, 2008
    Sergeant:
    Champion:
  • 221 Answers
Contact Service Center.
Amilio laptop not charging in spite of new charger
please measure the output for your charger,normally they have 19.5 vdc exactly, if they do not measure the adapter is faulty, repair or replace.If the output is o.k the battery can be faulty. Use the software diagnostic coming with the computer, restart the computer HOLD the key f2 or esc depending of your computer model, and make the diagnostic.try again and see what is the result, if the battery is o.k or faulty.God bless you
Apr 05, 2013 | Fujitsu Computers & Internet
I have acer aspire 5334. AC adapter plugged in but won't charge. Lights not showing on laptop and battery icon not showing its plugged in. Adapter rectangle box led light is on!! Is it charger, battery or...
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
Dec 10, 2012 | Computers & Internet
Why my pc presario x1000 power and lamp lights blink and the batteries can not be on my pc
I fix these laptops as a side business and sell refurbished ones on ebay...I've seen the problem you describe but I'd need to know more about how fast they are blinking, etc. When all the lights flash about 2-3 times per second, I've found it to be a motherboard issue normally caused by a faulty power jack. That can be fixed but it means disassembling the complete laptop down to the motherboard and either re-soldering or replacing the jack. If you have access to a charged battery, disconnect the AC adapter and try to get it to boot cleanly from the battery. This will tell you if the problem is at the jack or someplace else. Post your results and we'll go from here.
Jun 09, 2012 | Compaq Presario X1000 Notebook
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
Mar 19, 2012 | ASUS (X83Vb-X2) PC Notebook
Broke off my ac power supply nipple on the inside of my laptop where can I get a new one to solder on
Hi, if the Notebook is still under Warranty it is not recommended to remove and solder the Notebook with a Female DC Input socket of the Notebook. Although the DC input socket is available in any near by Electronic repair shop, please repair only if the Notebook Warranty is expired.
Mar 29, 2011 | Gateway MD7820u Laptop AC Power Adapter...
The pc not turn on, no power
It might be an issue with the adapter, the battery or the AC jack on the motherboard. First up see if your AC adapter's power LED comes on when plugged into a power source. If it does, then check if the Lights at the front of the laptop indicate that the adpater is plugged in. If they light up then it means that the laptop's battery is faulty and needs to be replaced. If the lights dont light up then it means that the AC adapter jack on the laptop has bad solder joints and/or damaged. It is located at the underside of the motherboard where the AC adapter is plugged in. You will need to take the laptop apart and re-solder/replace the jack.
Let me know if you need more help,
Sai.
Jan 05, 2010 | Toshiba Satellite A135-S2276 Notebook
Blinking yellow light on Acer Aspire
You can find the broken piece on line to purchase,This can be repalced by soldering it to the motherboard.You will need to find someone to replace this probably a tv repair technician who is good at soldering small circiut boards.You can also purchase the motherboard and replace it
Good luck
Sep 28, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer extensa 4420 won't start
I had problems getting an Acer Extensa 4420 to boot or to enter bios. It would never complete the post. After taking it apart, changing the CMOS battery and making several other adjustments I read that a faulty DVD would cause the problem. I removed the DVD and it went right into Windows VISTA. So I put the DVD back in and had the same problems over again. The issue is a faulty DVD and has nothing to do with the motherboard, or the CMOS battery, or any of those other complex issues. It is simply a faulty DVD that refused to allow POST to proceed.
Jul 08, 2009 | Dell Inspiron 6000 Notebook
Toshiba Satellite A105 no power
try looking at the DC input. My brother's 1st laptop had that same problem. All we need to do is solder it. Remember-1st dc connection, not the one on the MB.
Jul 30, 2008 | Toshiba Satellite A105 Notebook
I need help with power problem
You are correct about the DC plug on the 1100, they are well known for the problem you posted. It could be one of two things, the solder points where the DC jack is soldered to the motherboard could have "cold solder joints" and re flowing the solder will fix it. Or the DC jack itself is faulty (the more common issue with these Inspirons) in which case almost all PC service shops will insist that the Mother Board has to be replaced (Not worth replacing), but you can obtain the jack for a reasonable fee and either replace it yourself (if you are very good at desodering and soldering, It's surface mounted, and not through hole which through hole is a lot easier to do), or open the laptop remove the Mother Board and take it in to a reputable electronics shop and have them use their state of the art equipment to replace the faulty jack for a reasonable fee.
Good luck.
Feb 26, 2008 | Dell Inspiron 1100 Notebook
Toshiba Satellite 2805-S603 Notebook Logo
151 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
