Question about Thomson 21DC320 21" TV
Thomson 21MT62IN/21MT8DGX gives 2 beep sound
While trying to start the set it gies 2 beep sounds and does not start.It does not show the red indicator also.after switching off for more than 30 min's and then starting on,the tv set again gives same beeps.What should i do to correct it ? can you please tell me?
  • tg_johnson Nov 29, 2008
    when i switch the tele on the red light comes on and instead of going green it goes to orange, which it has never done before. it flashes and makes clicking noises and you get a flash of light in the corners of the screen. what can this be
  • sathibabu May 11, 2010
    Showing 2" less height at the top of the Screen for the Model no.
2 Suggested Answers
SOURCE:
SOURCE: THOMSON - QUADRA 21''(21MT62IN)
were you able to get the problem solved Even I have the same problem
Posted on Jun 19, 2010
Thomson 52RW65ES makes beep sound when plugged in. does not work
This indicates a motherboard issue, remove main battery and test, next sub out the ram one at a time testing as you go, if none of these work, the next step is to have a pro evaluate the product.
Apr 01, 2012 | Computers & Internet
I have changed my motherboad from america megatrades to asrock fsb1600 nand after isntaliing the windows 7 premium i get a no audio output deice is installed and a red cross at the speaker icon.I now have...
hi, i think you might have to enable it in your bios set up, as the system boots up, press either DEL or F2, this will then give you access to your bios set up, using your instruction book, navigate to where the ON BOARD DEVICES ( or what ever your book or bios says it is located ) then see if it is enabled...
Aug 09, 2010 | Computers & Internet
Cannot get PS 3 menu anymore. Shows 480p on
Ok this should problebly work if the ps3 is on but the red light is on(NOT GREEN) hold your finger on the on button untill is turns red again do the same but this time there will be a beeping sound and a nother one but the 2 one will make 2 sounds nou take your finger of a screen will apear say restore system about 2 times and that should work but plzzz rate me......I think this will work.
Jan 15, 2010 | Sony Playstation 3 (PS3) Console
Getting red light and continuously beep sound to my UPS(Frontech)
hi
If it is showing the red light and continuous beep it shows that the battery is completely gone.
You can buy a battery and replace it by yourself.
Or get it to a professional to change the battery.
you need not replace the whole UPS its just a battery problem.
Thank you
Aug 10, 2009 | Compaq R1500 ( 295459-001 ) UPS...
Thompson 52jw643 is stuck in standby, when switch on red led appears, changes to yellow for approx 1-2 sec, sounds like trying to start and reverts to red. sometimes flashes red once. any help greatfully...
I have a similar problem with Thomson 52JW643 S in that it takes at least 12 to 16 attempts before it eventually turns on very very annoying !!!!!!! turns from red to yellow to green then back to red and then same again until she feels like switching on then perfect picture sound and quality ??????? can any one advise please
Jun 27, 2009 | Thomson Televison & Video
CPU power problem
Check whether all connection are good and take out any CDs in the tray. I guess this must be a SMPS problem.
May 11, 2009 | E-Machines (T2958) PC Desktop
HP Proliant ML370 Server: Very Urgent Please
Open the system cover and check whether any LEDs showing amber or Red colour
Oct 29, 2008 | HP Compaq ProLiant ML530 Server
V3 fx steering wheel for PS2
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 Here are all of the instructions enjoy. clip_image001.gif
To adjust the V3 Racing Wheel 2's sensitivity follow the instructions below. ( 3 preset sensitivity selections )
1. Press and hold the SET button for about 1 second to enter the "FUNCTION SETUP MODE", the MODE LED indicator will start blinking and two "beeps" will be heard.
2. Press the direction on the digital/analog directional pad and SELECT button that corresponds to the setting you desire. Directional pad UP and SELECT will give you high sensitivity. Directional pad LEFT/RIGHT and SELECT will give you medium sensitivity. Directional pad DOWN and SELECT will give you low sensitivity.
3. After selecting one of the above sensitivity options you will hear 2 "beeps" letting you know that the wheel has been programmed. For Customizable Sensitivity follow the directions below.
2. Rotate (either left or right with the wheel ) and then hold the wheel to the specific angle desired.
3. Press the SET button again, two "beeps" will sound to indicate the completion of the setting
To reset the the V3 Racing Wheel 2 to it's factory default settings press and hold START, L1 and L2 buttons in until you here two "beeps".
To change between Digital and Analog modes follow the directions below.
2. Press the SQUARE and SELECT buttons to set the wheel to DIGITAL, or the O and SELECT buttons for ANALOG. Two beeps will sound and the MODE LED will stop blinking letting you know that the mode has been selected.
By default GRAN TURISMO 3 A-SPEC uses the X and Square button for gas and brake. To reassign these functions to the pedals on your racing wheel:
1. Go to the options menu in Gran Turismo.
2. Select key configuration. (The picture of the Game Pad.)
3. Scroll down to Acceleration
4. Press Right on the D-pad (11x) until Analog Up is selected for the Right Analog Stick
5. Now go down to Brakes
6. Press Right on the D-pad (10x) until Analog Down is selected for the Right Analog Stick.
7. Press the X Button to confirm your changes and then press the Triangle button to return to the main menu
8. The gas and brake functions for the game will now be set to pedals on your wheel.
Sep 10, 2008 | Cables Unlimited InterAct Racing Wheel V3...
Sep 08, 2008 | Thomson 21DC320 21" TV
Power edge 2600 sever shows problem
i replaced one of the hard drives in my poweredge. how do i get it to copy from the good hard drive?
Jan 28, 2008 | Dell PowerEdge 2600 Server
Thomson 21DC320 21" TV Logo
64 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
