Question about SAMTRON 55V 15" CRT Monitor
13pins "from the inside monitor" "to the VGA 15 pins connector
Good day,
I have a Samsung monitor. The model is Magic Monitor CKB5237G(D).
my problem is that the "15pins VGA" connector to the AGP card was accidentally cut & now missing, but I recently bought a new 15pins VGA connector. Unfortunately I don't know how to connect this 15pins to the 13 pins connector, as shown in the photo.
Picture of the cable without the regular 15pins VGA connector
[IMG]http://i2.photobucket.com/albums/y20/nktc/litrato-0062.jpg[/IMG]
[IMG]http://i2.photobucket.com/albums/y20/nktc/litrato-0063.jpg[/IMG]
Do you have the solution for the pin assignments.
pins13 to the pins15 vga
which pins from the 13 pins should connect to the pins to the 15 pins vga.
Tnx.
you may also email me at [email protected] regarding this info. Tnx again
Hai dear,
i checked your problem and found that you open the cover of monitor and you find the two jack of data cable in main pcb and neck card( 2 connector of data cable).plz you cut the connector of data cable and you will find 8 wires in connector.related red(invild extra ground),green(invild extra ground),blue(invild extra ground),black gnd,white,orange,gold(extra gnd) and now you cut the red wire, you will find two wires.so you refix the main red wire pin no-1 of connector and red gnd pin no-6,green main wire pin no-2 and green gnd pin no-7,main blue wire pin no-3 and blue gnd pin no-8.check for the horizental sync and vertical sync wire you should go in main pcb which invild the other connector. there is present in print, h- sync(two wire of h- sync main wire in pin no-13 and other pin no-5) and ver.-sync wire in pin no-14.first you will check the whose h-sync and vert-sync in color and now finally other wires will fix any pin of connector.
Posted on Apr 24, 2008
SOURCE:
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
Missing adapter or plug in connection to 15 balance mointor model 2015
The Balance CM2015 monitor uses a VGA connector,
http://www.ebay.com/ctg/Balance-CM2015-15-LCD-Monitor-Black-/52125929
(The above is for reference only. Not advertising)
A VGA connector is also referred to as a 15-pin D-Sub connector,
http://en.wikipedia.org/wiki/VGA_connector
This is information on a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If this is the monitor cable you have, you need this type of adapter,
http://www.directron.com/dviadapter.html
Now LOOK closely.
This adapter has male pins that stick out, and go into a female VGA connector on the monitor. The DVI side of this adapter has socket holes, for a male DVI cable.
IF, your monitor has a male VGA connector on it, and the DVI cable you have has socket holes, you need this adapter,
http://www.directron.com/dvitovga.html
If your monitor cable is not a DVI cable, post back with the style it is.
If nothing else post how many pins are in the connector on the cable, and how they are arranged.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 27, 2012 | Computers & Internet
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
13pins "from the monitor" "to 15 pins VGA connector"
You will have wires of 7 colours. Solder it as per the data below...
White 7
Red 6
Black 10
Yellow 9
Blue 12
Green 1
Brown 13
The pins are numbered as follows
4 3 2 1
8 7 6 5
12 11 10 9
13
Apr 02, 2008 | SAMTRON 55V 15" CRT Monitor
Missing VGA Cable for LCD Monitor - Help?
It should be 15 pin connector VGA .It should work.
Apr 02, 2008 | Computers & Internet
No 9 pin video socket
Most video cards use a 15 pin VGA connector.
There is also a 9 pin VGA connector, but they are a lot less common - I'm guessing this is what you have.
Is the video cable hard-wired into your monitor or is it connected via a plug? If it's a plug, is that a 15 or 9 pin? If it's a 15 pin, then all you need to do is buy a new 15-15pin VGA cable.
If it's hard-wired, you'll need to buy some sort of adapter. These are available and don't cost much either, but you might need to try a more specialist computer store to find one.
Hope this helps!
Matt
Feb 29, 2008 | Dell Dim.9150 Pentium D 820 Dual...
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
598 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Ekse
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
