Question about Samsung DLP HL-P5663W 56" TV
46" Samsung DLP Lines & Freeze up
46" Samsung DLP, 2 years old. The symptoms vary from:
Picture freezes.
Color is all distorted.
Can't turn TV off, need to unplug it.
5 evenly spaced wide vertical bars. Each bar is made up of 7 narrower
bars.
Model # HLR4667WAX/XAA
  • Nickandlisa Apr 12, 2008
    I am having the same exact issues. have you gotten anywhere yet? Also does the TV internal menu still work. Mine still does , it's just the incoming image that looks bad.
    Genius:
  • Samsung Master
  • 1,689 Answers
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Posted on May 06, 2008
  • walooway Dec 29, 2010
    How do you change a color wheel I would like to do it myself and save $$$ I've changed 3 lamp,one door switch and now I need a color wheel turn it on and it makes a whinning sound was told it was the color wheel b4 this last lamp change it glass grinding sound musta damaged wheel also.. thanks walooway@Bellsouth.net
My Samsung HLR5667W DLP won't come on. Lamp lite blinking
Feel better now?
Tried a new lamp or is it now very old and damaged the main board?
Sep 20, 2017 | Samsung HLR5667W 56" Rear Projection HDTV
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung 46 DLP picture freezes and then....
common problem on samsung. bad DMD BOARD. these are modules located on light-engine. there very proud of this little jewel. usually parts cost 400-500.00 dollars for the shop. after mark-up & labor don't be shocked at 600.00-700.00 repair bill. this is of coarse for dmd replacement. 85-90%. if logic board, est. 400-500.00 repair. mch
Mar 09, 2009 | Samsung DLP HL-P5663W 56" TV
Picture is psychedelic
the dmd board assy has failed possibly
Jun 12, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP R-4664_W
stll have picture?....is colors distored.. sound like a color wheel problem.. the colorwheel is a motor anything that moves eventally wears out.
Nov 17, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-R5667W
Color Wheel problem.. to generate colors on a dlp the light is shine through a motorized wheel. that has different color filters on it. this is a motor and anthing that moves will eventally wear out. i just replaced the color wheel on a samsung today. standard for this to go out in about that time. i believed our shop charged 250 to put a new one in. Willie@FORDTV.COM
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
640 people viewed this question
Henry  Thomas
Henry Thomas
