Question about Microsoft Xbox 360 Console
Xbox360 wont boot on first attempt after setting for a hour
Hello when i power on my 360 i get a green light but nothing on screen then i turn off and right back on and it works great.
  • Anonymous Apr 04, 2008
    it blicks red a lot
  • Anonymous May 11, 2010
    help me
    Sergeant:
    Champion:
  • 427 Answers
If it works fine, then I wouldnt think anything of it, but If you want, you can see if your console is under warranty and have it repaired.
Posted on Apr 04, 2008
SOURCE:
My xbox360 (the new one which comes with kinnect), no longer works. I turned it on this morning (4/16/11) and the green light turned red and all these different languages showed up on the screen. A E68...
E68: Voltage Error... This error means that the Xbox 360 has insufficent power to function properly. This can be caused by an error in the hard drive or the fans that make them **** up too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If that doesn't solve it, then you need to call Microsoft. They will repair it for you if it is still under warranty.
Apr 16, 2011 | Microsoft Xbox 360 Console
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Feb 11, 2011 | Computers & Internet
My 360 has 3 rings the rings are red and it wont turn on
The three red lights mean that your XBOX360 is experiencing hardware failure. This is caused by overheating of your XBOX. Contact Microsoft and have them fix the problem. They have given free extended warranty for three red light problems. If you have bought your xbox360 within 3 years, you're in luck.. They will fix your console for free...
Mar 13, 2010 | Microsoft Xbox 360 White Console
My xbox360 controller acts like its attempting to sync and then does nothing but blink on both ends I just hooked it back up for the first time in a year or so..When i attempted to sync the controller the...
I had a similar issue with the XBOX 360 Wireless controller. It blinked slow when it was turned on and when synced, the XBOX got the signal, the controller got the signal, but after the full flashes of both, the console ring stayed dark and the controller kept on blinking.
I managed to get it connected by powering the console on using the "XBOX" button on the controller and then pressed the connect button just as the console was opening up the user interface, apparently the console is looking for controllers when it's just getting up and running and syncs better at that point.
Hope this helped!
Sep 20, 2009 | Microsoft Xbox 360 Controller
After RRoD fix, hangs at splash screen and no front lights
ya appliyng thermal past does little if
nothing for the problem your discribing.
did you heat up the G.P.U. and keep
the C.P.U.cool wth the fan till you got
two reds? if that the case there may
be more diconects under the G.P.U
It is fixable but you need specail equipent
that will compress both sides of
the chip as you heat it to around
320c that will fix problem boards like
yours 90% of the time
Rob
Sep 15, 2009 | Microsoft Xbox 360 Console
Xbox360 tray ejects itself
The only thing i can think of is that something is stuck in the tray. Sorry about your luck
Apr 30, 2009 | Microsoft Premium System for Xbox 360
Whats Wrong With My Xbox 360?
it has to be on the wrong plug in ins or on HDTV. if you need more help my email is: [email protected] i got one on christmas to i sorta like SOFTLY boped it and it booted up. sorry bout it
Dec 27, 2008 | Microsoft Xbox 360 Elite Console
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Xbox360
well it seems that your xbox is well and truely broken. contact microsoft and tell them whats happened and if you have done nothing wrong to cause your 360 to break then they will repair/ replace your xbox for free
Jan 05, 2008 | Microsoft Xbox 360 Console
No ring of light no red nor green and controllers wont connect
i assume you mean wirelss controllers, if so, on the front of the console there is a round connect button marked '>>',( to the right of the memory port 2) press and release this and there is a little pairing connect button on the controller at the front press this, then the lights should then circulate and stop in either the upper left or upper right segments. you can view here if you prefer illustrations http://www.xbox.com/en-US/support/systemsetup/xbox360/console/wirelesscontroller.htm
Jul 10, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
