Question about Samsung SCH-u740 Cellular Phone
Plugging u740 into pc
On my USB cord that came with my u740 it had a tag that said "do NOT plug this device into your pc until all installation steps have been performed." what installation steps are these and how do i do them? there was no installation disc with my phone.
    Problem Solver:
  • 10 Answers
IT SAYS THAT BECAUSE IF YOU DO IT WITHOUT FIRST INSTALLING SOFTWARE YOUR COMPUTER WILL AUTOMATICALLY FIND DRIVERS FOR YOUR PHONE TO WORK WITH THE USB CABLE, THEY MIGHT NOT BE THE SAME FORMAT THE PHONE USES, GO TO SAMSUNG.COM AND FIND YOUR PHONE ON THERE AND DOWNLOAD THE DRIVERS AND THINGS.
Posted on Apr 06, 2008
Printer offline
You did not specify if printer was formerly working, the model # of the printer, or what version of Windows you are using. All this information is needed for successful troubleshooting. However, the below is general resolution for your problem:
"Offline" means your computer cannot "see" the printer as connected and powered on.
In order of things to try:
1. Turn printer OFF. Unplug USB cord from printer (or other end from computer). Wait at least 30 seconds. Plug USB cord back in. Turn printer back on. Does it still show as "offline" under Start --> Devices & Printers?
2. Try replacing the USB cord (yes, they can and do go bad).
3. Turn printer off. Unplug USB cord.
Under Windows Start --> Printers and Devices:
RIGHT click the Konica printer icon. Select "uninstall" (or "remove device") and follow through until printer is successfully UNinstalled. If there is other Konica software installed, remove it also (via Start --> Control Panel --> Add/Remove Programs -or- Programs & Features).
4. Reboot your computer. Follow manufacturer printer installation procedure, step-by-step (consult mfr website if you do not have a printed installation manual). Do not plug in USB cord or turn on printer until instructed to do so.
If all else fails:
Ignore any manufacturer installation instructions.
Do # 3 only above.
Reboot computer.
Plug in printer and connect it to computer.
Let Windows try to automatically install it (in most cases, Windows can install the "basic" print drivers, which are smaller and sometimes more stable than the fancy drivers and excess software the manufacturer wants you to install).
If still no go, you probably have a dying or dead printer. Consult manufacturer website for help.
Mar 07, 2014 | Konica Minolta Office Equipment & Supplies
HP 8250 has error 0xc18a0206
HERE IS WHAT YOU SEEK
Issue: error code appears on the printer display.
Solution:
Step one: Reset the printer
Press the On button to turn off the printer.
Unplug the power cord and universal serial bus (USB) cable from the back of the printer.
Wait 30 seconds.
Plug the power cord back into the printer.
Press the On button to turn the printer on.
If the error message does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
If the previous steps have not cleared the message, continue to the next step.
Step two: Download and install firmware update
Go to the product support page to download the update.
http://h10025.www1.hp.com/ewfrf/wc/softw...
Click Software & driver downloads.
Click on the appropriate operating system link.
Click on the Recommended update to fix long power-on cycle and error codes and follow the instructions to download the file.
After downloading is complete, disconnect all other USB devices from the PC. Make sure the product is powered ON and plugged into the USB port.
With the printer directly connected to the PC, click the downloaded file FirmwareEnable_Release.EXE.
Click Open/Run.
Click OK at the Update successful window. The error should have been cleared from the printer display.
If you get a message saying a device was not detected (see Figure 1), make sure the printer is powered ON and the USB cable is connected to both the printer and PC and try step five again.
Nov 12, 2013 | HP Photosmart 8250 InkJet Printer
I installed my leapfrog connect for my Tag reader. It says to plug in the Tag with the USB cable to the computer ( which i did) and turned it on. For some reason its not picking up so i cant go to the...
it depends on what Operating system your using, if xp then goto devices in the control panel and click on detect new devices, also check there if the usb drivers are installed, sometimes you have to install the software before plugin it in. if it's win7 then again click on devices and also check my computer when the usb is connected, and again install the software before plugin it in. best regards.
Oct 30, 2013 | LeapFrog Tag Reading System
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
Tell me the steps to install my magic jack to my laptop
When you receive your package in the mail, open it up and you will have three items: the USB plug-in device, a short USB extension cord and a telephone cord. Follow these steps for you to be able to install magic jack on your laptop.
1. Plug the device into your computer's USB port and it will automatically start downloading and installing some software that you need to be able to make calls.If the device doesn't fit in the area where your USB port is on your computer, then you can use the extension cord that was included in your package to hook up the device.
2. Another option is to use an a/c powered USB hub to plug it into. Using an a/c powered USB hub is recommended over using the extension cord, as it will save you from having some problems in the future.
3. You will also be able to visit the official website for this voip phone if you are having problems getting it to work all of the time. There are downloads available that are called "magic fixes" that will help the device work better with your computer.
4. Now all you need to do is to plug in any regular land line type phone into the device. The phone line that came with the device is best to use as it is recommended not to use a phone cord that is over 6 feet long. This is all it takes to install Magic Jack so you can start making free long distance calls.
Hope this will help...Thank you for using Fixya...
Feb 25, 2011 | Computers & Internet
Is a printer, Brother MFC-7340, and installation cd goes all the way thru, following step by step, but it comes to the point when it asks to plug in the USB to pc and then to machine, and it just stops...
Try a new usb cord, and definately try other usb ports on the computer. Make sure you're not trying to plug into an ethernet or firewire port. Test your usb connection with another device you know works.
Apr 05, 2009 | Brother MFC 7420 All-In-One Laser Printer
Computer won't recognize USB ports
If you are plugging a USB device into a different port it takes some time to recognize and install it - it re-installs for every port. There could be cable and/or port issues as well. Plug the printer into a USB port that the mouse does work on and allow several minutes for it to detect install it.
Dec 18, 2008 | Dell Dimension E521 PC Desktop
I need to install a USB cable modem driver in order to print from my Dell Inspiron 1525 laptop. I have a Hewlett Packard DeskJet 895 Cse and whenever I put the USB cord into the USB port in the modem and...
I realized that I plugged the USB cord into the wrong place near the printer. In the back of the printer there is a port for the plug. Therefore, I didn't need to install driver software because it did it for me when I plugged it in correctly. Now I can print and the problem is solved.
Aug 20, 2008 | Computers & Internet
Damaged usb port needs to be replaced on my HP Pavillion 513W computer. Need diagrams and step by step instructions
1-Shut down you pc .2-unplug the power cord.3-open the case .4-Find the usb wires trac them back to the board. 5-mark were the wires go with a marker.6-plug new usb port wires in.7-put the case back on pc.8-plug power cord in.9-turn on pc.10-plug your usb device in.
Jul 02, 2008 | Computers & Internet
Samsung SCH-u740 Cellular Phone Logo
126 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
