Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Receive fax to pc
Just bought a L7780 under the assumption that i can receive faxes directly to my pc, and choose to print what later. I can't figure out how to do it.
  • 3 more comments
  • Hasani Apr 17, 2008
    I can't receive my faxes in my pc. It's connecting after 55sec error message coming "unknown error occured".
    Can anyone help me?
    Thanks in Advance
  • Anonymous Apr 26, 2008
    same issue here...need to be able to do this...
  • mqriaz1 Apr 29, 2008
    mine is on a network? Should I connect it via usb?
  • Anonymous Oct 01, 2008
  • smcq May 11, 2010
    are you using usb cable or is printer on network?
This option is only available on Officejet J6400 printer from HP.
Posted on Sep 17, 2008
I just spoke to a sales person at HP who told me they do not carry any products that fax directly to PC, so I assume that the L7780 does not have this feature. The only manufacturer I can find so far that does this is Brother, and we paid over $500 for a multifunction printer from them, and the fax burned out in less than a year and a half (but after the warranty ran out). Xerox offers software that you can purchase separately that works with their multifunction printers to do this. I'm still looking...
Posted on Jun 10, 2008
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
We cannot receive faxes directly to the PC. We will receive the faxes only to the printer.
Posted on May 26, 2008
Partial print on incoming fax
Check your incoming line and settings or try to reinstall the drivers. Also, check the user manual for HP Officejet Pro L7780
Jun 25, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I have an HP L7780. We are having an issue receiving faxing. The pages are often only 1/4 complete. There is no reported error. It doesn't happen all the time.
Send a fax on this number
1-888 HP FAX ME (1-888-473-2963)
and see whether you receive a fax from hp or not whenever HP receives a fax from any number it sends back a fax to prove the functionality you can say.
the reason behind reviving the 1/4th fax can be fault at sender's end
Apr 21, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
MX310 - faxes in memory. Cartridges have been replaced. Error of low ink remains. What is the key sequence to retrieve these faxes?
Press Fax then Menu. You should see Fax Settings across the top row. Use the left/right arrows to select Memory Reference and press OK. Again use the left/right arrows to select Print Document and press OK. Select the transaction (RX) number of the fax you want to print (received faxes start at 5001) and press OK. Then choose whether you want the first page or the entire fax (yes to first page only or no for the entire fax) and press OK. To print additional faxes repeat from the Select RX number. Print the Memory List to find out which fax is which (from the list that you see under Print Document.
Then you can delete these by selecting Delete Document instead of Print Document in the above directions. Then press OK followed by Yes or No for deleting the document.
Finally press Stop/Reset to leave the menu.
I hope this helps.
Sep 24, 2010 | Canon PIXMA MX310 All-In-One Printer
I have an all in one and I can print, scan, and
On the printer press setup-->choose tools option-->under tools-->choose print a fax test page.
Find out how is the printer connected with the fax line.
Note:- Line 1 at the back of the printer should be connected directly to the wall jack of phone line.
Now Follow the instrcution below.
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, They will generate a return fax to you within five minutes confirming that they have received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Note:-The most common cause of failure is that the fax number set in the Fax Header on the machine does not match the number of the phone line connected to the fax. Also, ensure that the fax header contains the full 10-digit telephone number of the fax machine, including the area code.
May 10, 2010 | HP Officejet 4215v All-in-One Printer
Can't receive a fax
There are some settings that you need to change.
You need to turn off the following:
Error Correction Mode
Auto Reduction
to get to these options you need to go to the setup menu by pressing the setup button
then scroll to advanced fax settings and select it and you will find the options listed under it
You also need to check the fax speed under Advanced fax settings.
set it to medium.
hope this will help you :)
Aug 09, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Our new HP Oficejet Pro L7780 can send faxes but can't receive
First things first, i really want to know how things being setup in your end. Let say for example, from the walljack what is the device connected to it. Or if your using one line for both incoming calls and faxes. Or if your using a DSL also for that same phone number for faxing/incoming calls.
Those are just severa factors that affect your problems. Meanwhile, i cant give you a solution on your issue since i still dont have a clear picture on are the devices connected with each other. ALso, its really advisable that you need to use the telephone cord that came out with the box.
Thank you so much. I remain.
Apr 23, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
I have bought a 4 in 1 photocopier and wish to use the equipment to receive faxes whilst conected to the computer modem and telephone service. My fax is not connecting. Please assist Model x5495
You need to plug the copier direct to the telephone jack.
The copier will not receive any faxes as the modem on the PC is intercepting them.
If you need the PC on-line via the modem then you will need to swap out when you want to receive faxes.(or get a second line for the faxing)
If you do not use the modem on the PC for anything then leave the cable plugged into the copier.
It should automatically receive your faxes.
There will be an option somewhere for you to be able to print the fax directly or to transfer to the PC to view therefore saving paper and allowing you to make changes and fax back.
Hope this is helpful.
Please let me know if you get it to work
Apr 22, 2008 | Office Equipment & Supplies
How to print fax confirmation
from the main menu on the printer scroll down to "fax setup" or "advanced fax setup"
you have the option inside it.
thanks and regards
Feb 03, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Send fax using pc
Please perform the following steps to fax from PC.
Click windows-->Programs-->HP-->HP Solution Center
Clik on Send Fax and provide the number of the fax to be sent and proceed with the steps to resolve the issue.
Every application has the option of sending fax from the File Menu---> Print-->Select the Fax icon and click on Ok.
Jan 05, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
137 people viewed this question
Ben Johnson
