HD MAXTOR Y120L0
Hi there, any one knows how to set the JUMPERS for a Maxtor HD, to it RUN in SAFE MODE......???.' So I can retrive the data.
I´ll appreciate nay help......Thanks
  • Goodstuff Apr 05, 2008
    Hi Terry, thanks for the TIP, BUT THIS is not the problem, I don´t wanT to run the SYSTEM in the SAFE MODE,,,, I want TO PUT THE HD IN SAFE MODE,,,AND THIS IS done by the JUMPERS in the HD,,as they DO in the factory....The setting of the JUMPERS is a well KEPPED SECRET by the manufacterer,
    I am still asking if any one out there KNOWS how to DO THAT...I´ll appreciate the help....
    Regards
    Goodstuff
    Sergeant:
  • 349 Answers
When booting the pc ,press F8 until you get a menu up ,then select safe mode and press enter.
this will let you run windows in safe mode.
as there are no jumper setting on the hard drive for it to boot up into safe mode, as that is a software function within windows,
if in fact you are able to go into safe mode ,the problem is not the hard drive but the operating system,so restore the pc to an earlier time.
good luck, let me know how it goes
Terry
Posted on Apr 03, 2008
I have an old maxtor 2 drive that i'm trying to slave
Hi!
Just follow the jumper settings in the picture diagram below:
I hope it helps..
Thank you for reaching Fixya.
Apr 11, 2010 | Maxtor Hard Drive
HARD DRIVE STALLS TRYING TO LODE WINDOWS XT PRO
Can you go in safe mode?You might want to retrive your data and replace the drive as it might be failing.
Oct 04, 2009 | Maxtor Hard Drive
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Setting Maxtor HD as Slave.
Howdy,
First "easy" one I've had in hours....
Just pull the J50 pin out of the jumper block and PRESTO it'll be a slave the OFF position literally reffers to having the J50 pin off of the hard drive. Just a note though, I highly recommend using a peice of scotch tape to affix the pin to a nearby surface cause there a real pain to find if and when you need em again.
Chris,
Armor-IT
Apr 23, 2009 | Maxtor DiamondMax 60 (33073U4) 30.7 GB...
Have maxtor 40gb hd want to add 2nd WD hd in DEll dim8200
(if both drives on the same cable):
Your boot drive goes at the end of the primary data cable.
Your second drive goes on the middle connection of the same cable.
The red stripe on the data cable needs to be closest to the power connection (red stripe to pin 1).
The jumper on the boot drive set to master.
The jumper on the second drive set to slave.
Look in the BIOS to make sure it sees both harddrives.
Boot the system.. it will need to be partitioned and formatted if not already..
Regards..
Apr 04, 2009 | Dell Dimension PC Desktop
HD Maxtor model 91360Ua
Hi fkjedi,
Most Maxtor drives all use the same configuration, but HERE a link to explain and show you how to configure each drive. You can print it out and save this for future use.
Thanks
Please leave a rating based on this solution!
Mark
Mar 28, 2009 | Maxtor Hard Drive
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Your solution
That depends on the type of HD you have...Mine is a Maxtor 3 1/2" ATA 60 gig...On Maxtor's web site you can print the jumper settings for the type and style of the the HD you have...A side note on Maxtor's ATA HD's, the jumper setting for 'Master' on all styles would be the last VERTICAL pin setting on the LEFT.
I'm sure if you have another type (Seagate,etc.) they will have setting's on their web-site.
Don't worry if you get it wrong you won't damage the HD, it just won't work.
Hope this helps!
Jul 31, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Maxtor 40gb hard drive as master
Hi, Below is an image of a Maxtor 3.5 HD settings as shown on the actual HD. If you are connecting 2 of them in a single IDE flat cable/strip, one must be master and the other must be slave. Jumper settings on the left is for master, the second is for slave. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Computers & Internet Logo
255 people viewed this question
David Payne
David Payne
