Why is the pitcher So Dark?
The picture is to dark I canot get it to lighten up
    Brigadier General:
  • 6,966 Answers
If the TV is the conventional CRT type, normally, all you would need to adjust would be the brightness level and occasionally the picture (contrast).
In some instances when both settings are at the maximum but the picture is still dark indicates a hardware fault inside the TV. Often, this would be a simple resistor that has opened up in the G1 or G2 located at a squarish PCB at the rear of the CRT. This is relatively an easy repair job and low cost.
The worst possible scenario, this could possibly be a major component failure such as the tube itself or some other part(s).
Should you venture a DIY, you would need familiarity with electronic components and circuitry, use of a DVM and a soldering iron as well as access to a service manual or at the very least a schematic diagram. Should you be uncomfortable going this route, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 03, 2008
SOURCE:
How do I lighten a dark picture
Hi Richard,
Please try reducing the contrast a little and increasing the brightness till the dark shots are clear. Please also check the back light setting. It should not be too low.This should make all the dark scenes clearly visible if it only a setting problem. In case the overall brightness has reduced, please consult a local TV Tech.
Aug 11, 2015 | Sharp Aquos Televison & Video
My tv screen is to dark how do I lighten the picture
If your TV has already fully adjusted in brightness set up?, and there will be no good picture results?...try to adjust the "SCREEN-Screw" at the flyback slowly. If the picture still dark'?. the picture tube has need to rejuvenate.
Oct 24, 2014 | JVC Televison & Video
Tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Mar 06, 2010 | Televison & Video
Colors trail behind motion in picture...color too dark
replace T-con board ( top centre of lcd panel ) lvds cable plugs into this
Jun 06, 2009 | Sony BRAVIA KDL52XBR2 Television
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
Scans slides too dark.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
Hope this helps.
Nov 11, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Too dark
This IS an inverter issue. You need a new inverter. Open the LCD and find the inverter model number and search Ebay.
-CharlyV
Dec 28, 2007 | CTX S762A 17" LCD Monitor
Dark picture
@ 6 years old I'd be willing to bet that it's time to replace the lamp. They lose brightness over time so that could be what the problem is.
Dec 14, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Ekse
