Question about Insignia D300a PC Desktop
Restore I was using my restore disc an now wen I turn my pc on nouthing happens. The lighs come on to show it is on but nouthing shows on the screen.
  • Pixiyqween May 17, 2008
    i hear the fan kick on . but that is about it. an it will not let me use the disc again. nope no splash screen. an it will not let me use the insignia disc again
  • Anonymous May 11, 2010
    Hmm...this could be a number of things... Do you even hear the hard drive boot, is the fan in the computer running? You don't see anything? No insignia splash screen? Are you able to use the recovery disk again?
    Problem Solver:
  • 13 Answers
The fact that you don't see the insignia splash screen tells me it's not looking good for your computer.
- Have you tried another working monitor with your computer? It could be your monitor died.
- Where is your monitor plugged in on your computer? To the mainboard or a graphics card? It could by your onboard graphics or graphics card has died. Try switching, if possible.
- Have you tried reseting your BIOS? You'll need to open your computer case and look for 3 small metal pins with a connector connecting to two of those pins (it should be on the lower-right hand of the motherboard when you open your case). However, depending on your computer ability, I would generally hold this off.
Unfortunately, without actually being there and without the proper equipment, there's not much I can do. If none of the above helps, then you'll need to open your computer case, and do some equipment checks, however this is only for people who have built computers before and know what they're doing. If you can get a friend thats knowledgeable in building computers to take a look at your computer, then definitely go that route.
All I can do is direct you to the product specifications of your motherboard (the D400a has a D845GVSR motherboard)
http://support.intel.com/support/motherboards/desktop/D845GVSR/
Click "Manual" under System resources and download your language version of choice. Good luck.
Posted on May 18, 2008
  • Anonymous May 18, 2008
    I meant D300a, but this also applied to D400a too.
SOURCE:
My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
This could be your HDD, failed. Work through, the troubleshooting procedures.
Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 14, 2010 | Acer Aspire 4315 Notebook
I can start it up fine, but when i log in,it shows my backround, then the taskbar shows up, finally the programs show up, then the whole screen goes only to the backround. and that same thing happens
Startup PC, press F8 at instant of turn on... choose Safe Mode. when you are asked if you want safe desktop or system restore choose restore, when you get to the restore menu, choose a date BEFORE you had problems there may only be one or two to choose from. just follow the instructions and you should be back to working with all that behind you.
Mar 01, 2010 | E-Machines eMachines Desktop PC
Philips freevents laptop will turn on but show a black screen
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back. If that doesn't work get back to me...
Feb 22, 2010 | Computers & Internet
My iphone 3gs willnot on and not show me the apple logo
Instead of trying to update when you connect to iTunes you should try to restore the phone completely.
You can find the restore button in the lower right hand corner of your screen. If iTunes asks if you want to update click cancel. You just want to restore.
If it is still not turning on after it reappears in iTunes you should take it to Apple if it is still under warranty they will exchange it for you.
Feb 05, 2010 | Apple iPhone 3G
MY WINDOWS XP INSTALLATION IS WORKING FINE, BUT WHEN I TRY TO REINSTALL IT, MY PC SHUTS DOWN WITHOUT ANY MESSAGE.
go to 1 start button click go to 2 all programs go 3 accessorys 4 in accessorys go down to 5 system tolls in system tools shows a window of more options 6 go to system restore and click on it a window pops out says restore my computer to a ealyer time its checkd 7 click next in the bottom then a callender shows 8 click it on wish date you think your computer was working fine yopu go on the dark blue dates and click or you can even go on top of callender in the sides it shows other months like november or dicember get a date and 9 click next in the bottom your computer will restart if your working on something save work computer will turn restart if it say files saving wait untill it stops in the 10 progress bar the you click endnow the computer will restart wen it turn back dont any keys will it turns on the pc it goes in your desktop icons window shows a screen say restore susesful 11 down the screen click ok and your done if its the same that it was before you can try again this steps please leave a good ratete me thanks
Oct 20, 2009 | HP Compaq nx6125 Notebook
HP dv9700 was working fine. Re booted after it froze and now it's super slow. 20 min for password screen to come up. HELP!!
If it is extremely slow, then what has happened it alot of windows has corrupted. If you have your recovery disc, the simplest method is to stick in the first disc and reboot to it.
Fix the boot sector with it.
Aug 09, 2009 | HP Pavilion dv9700t Notebook PC
0xd000001e and subsequent black screen
The easiest way is to hit F10 right after the Acer splash screen. This will take you into recovery mode on the laptop. Then just do the Reset to Factory Default. This will put everything back to the way it was when you purchase the laptop. It does this from the recovery partition.
Jun 02, 2009 | Acer Aspire 3680 PC Notebook
Wont boot up and cant use restore
It sounds like a virus or spyware corrupted both your windows restore points and your partition...Do you have the discs that came with your system? I am afraid you'll have to manually restore.
Apr 13, 2009 | Acer Aspire 5100 Notebook
Restore my dell dimension 5150
disable all integrated devices, change boot sequence to cd drive & then try to reinstall....
Jul 03, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
E machines restore disc
hit f11 when computer is starting up..it will take you to the restore menu...do a complete system restore from the restore partition.. as far as the restore discs goes, when you pop that in, the computer will boot from the cd and take you to the restore menu...do a complete system restore..after formatting the hard drive.it will show a bunch of files..be patient and let it complete the process...
Feb 23, 2008 | E-Machines eMachines Desktop PC
Insignia D300a PC Desktop Logo
173 people viewed this question
Top Insignia Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Joaquim Martins
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
