Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
LSUQ0100 jig question
Thanks for the diagnosis! Is this something I can do myself? I found the part but can;t find any information on the proceure.
Thanks again!
  • redmango Apr 05, 2008
    I'm having trouble finding this part LSUQ0100. I found it at only one store on-line and it is back ordered. Any suggestions on where I can find it?
    Thanks!
  • Anonymous Dec 11, 2008
    I have 2 spots the size of a baseball (1 green, 1 purple) will this supposed jig fix this ???
Can you tell us where you found it on backorder?
I'd like to get one too. Why does Panasonic make such **** TVs?
Posted on May 16, 2008
  • 58 Answers
The procedure information comes with the part, just follow the included directions exactly and you should be able to do it. have a good day.
Posted on Apr 03, 2008
SOURCE:
DELTA YENONING JIG 34-184 WHY DOESNT FACE COME OVER TO BLADE? I GOT 5 1/2 INCHES FROM BLADE TO SIBE OF MITER SLOT,THAT A NORMAL SLOT OR MINE FARTHER AWAY
That's a normal mitre slot distance.
You may need to re-align the jig depending on whether your saw is a left or right tilting saw.
You can download instructions for your jig that tell you how to do so here.
Otherwise, I can only say that I have had the same question, and can only think that the jig was designed with the idea that you would screw your own backing plate against the face of the jig, to hold pieces in place or back them up as they passed over the blade, and for that reason the face is so far from the blade. (But I think I was using the jig on a powermatic saw at the time.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 17, 2011 | Delta 34 - 183 Tenoning Jig
TV will not turn on
Sounds like the thermal fuse has gone bad. Sony part# 191002393. Very enexpensive part. It is located near the lamp housing from the back of the set. Once you have the new part in your hand, it will be easy to find.
Jun 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Problems with Bosch T101BR 4 Inch 10 Tooth Jig Saw Blades
Hi, The reason for a down cutting blade is to see your cut on the finished side of laminates ( which include veneers, plywoods, plastics, formica . When using an upcutting blade on laminates the smooth cut is on the bottom, which you can not see till you are done and turn the work over. Reversing the teeth allows that smooth cut to be on the top. This is usually done on smooth flat surfaces as you have found out and does not work with orbital or tight scrolls. As far as the pushing or pulling, smooth cuts in laminates require the saw doing the work at a speed that allows the teeth to cut and remove material with biting. So if you are biting, (This is a much slower process than pushing your jigsaw through regular wood) check that you are not pushing too hard and that your blade is still sharp. Good Luck to you, this should Fixya!
Mar 08, 2009 | Bosch T101BR 4 Inch 10 Tooth Jig Saw...
Phone number
The EEPROM jig is available ONLY through Panasonic's Technical Service line. A few places offer it for sale, but you still need an authorization directly from the Panasonic's engineers to get one.
The guys will ask for your company name and Panasonic account number. If you are not Panasonic Factory Service center, they cannot even talk to you. (not their fault, it's company policy)
If you are out of warranty, call Panasonic and see if they will give you a one-time concession for repair. Usually the company is pretty good about it...
Good luck, Mark
Oct 18, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Trouble ordering part LSUQ0100 JIG
You need to be an authorized panasonic service center to get that item.
Apr 10, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
PT-61LCX65 part number LSUQ0100 jig
Good Day, redmango;
Try calling 1-800-458-6053.
Good Luck, big IRISH.
Apr 07, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Trouble finding part LSUQ0100 JIG
This item is normally only on backorder for 5 days. However, not many store are able to stock this part as it needs an authorization number to order this. You can only obtain an authorization number from Panasonic Tech Support.
Apr 06, 2008 | Televison & Video
PT-61LCX65 image reversed
Per panasonic's autorized tech website5.gif it is corrupt EEPROM data. It is corrected using the following jig with included instructions on how to perform software5.gif upgrade.
Correct symptoms using part LSUQ0100 jig that comes with instructions. (operation takes 6 mins)
hope this helps.
Mar 24, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
PT-61LCX65
Per panasonic's autorized tech website it is corrupt EEPROM data. It is corrected using the following jig with included instructions on how to perform software upgrade.
Hope this helps.
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
301 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
