Question about Canon PIXMA MP530 All-In-One InkJet Printer
Scanner error message. 3rd and last canon for us!!!!
Any ideas???  first it kept saying we were out of ink which wasnt true... now beeping and the error message "SCANNER ERROR"  price per print on these is very high when u factorhow little they are used and how much they are to buy and fill with ink, then they just dont work.  3 faulty canons-weve had enough!
  • toastymango Apr 04, 2008
    thanks steveb, its not actually a scanner issue...nothing works at all-every button pressed gives about5 short quick beeps...like its frozen, but the message says 'scanner error' copy light and error light (and one other) flashing all the time too.   never canon again!!
    are the scanner drivers in the multi or the computer?
  • hoochy121 Jul 03, 2008
    scanner is not comunicating with computer ? works with other laptop ?
    tried reinstalling drivers etc. but keeps saying error 2,115,0 check scanner is plugged in etc....any ideas?
    Novelist:
  • 159 Answers
Unfortunately (and in common with a lot of other 'all-in-ones') the Scanner will refuse to work unless the printer is fully operational (or at least has Ink).
See if it will perform a photo-copy .. if so, then it's the driver software .. about all I can suggest is re-install the scanner drivers.
Posted on Apr 03, 2008
Cannon Printer mx320 error 5200 wont' restart
Error 5200 unfortunately is a Print head overheat error. Whatever you try to do to fix it will not work unless you replace the print and the main logic board. These two parts HAVE to be replaced as a pair to get the machine to work. However the costs are often more than the machine is worth. To be honest i would scrap it and by another. Its quite an uncommon fault but have seen it before (I am a Canon engineer)
May 08, 2012 | Canon PIXMA MX320 Color USB InkJet Printer
Canon printer problem
Scanner not work because printer need recognized both cartridges.In your case color cartridge is defective.Replace it and the message will disappear.
Sep 13, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Canon MP210 Third Party Ink Canon Does Not Work!
When the error message comes up, try pressing the "stop/reset" button and holding it down for at least 5 seconds. This works when I get an error message with compatible cartridges (only my error message says the ink is empty - and I know it isn't)
Jul 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error message "E02507 No Y ink cartridge"
eplace ink tank with correct 1. trust me. i work for the company
Apr 15, 2009 | Canon imagePROGRAF W8400 InkJet Printer
Error message code 2,140,0
I had a similar problem (error Code:2,140,2) in Canon PIXMA MP250 all-in-one, and it was solved when I replaced both ink cartridges which were in low ink (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Mar 16, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Error ##343 and it didn't print anything Orange light below screen has been flashing, screen message "Waste Ink Nearly Full". No idea where waste ink container is kept? Have changed cartridges. Now saying...
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
hope it helps
cheers
Jun 09, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Ink cartridge problem
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Mar 18, 2008 | Lexmark X6150 All-In-One InkJet Printer
Canon BJC 85 printer
PRINTER BEEPS (5) TIMES, ERRORS
Nov 29, 2007 | Canon BJC-85 InkJet Printer
U071
sometimes when you change your ink it doesnt register.hold down the stop/reset button and it will bypass that
Aug 23, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
439 people viewed this question
old marine
old marine
