Question about Compaq Presario R3000Z Notebook
Monitor ont boot up
My pc sounds like it boots up and everythings fine but no video output from 2 vid cards ad the internall ne ideas thanx
    Novelist:
    Champion:
  • 236 Answers
What do you mean 2Video cards? It doesn't post POST messages? of no video on Windows? please need more info to help you
Posted on Apr 03, 2008
I put the card on my PC and connect de monitor to the card (VGA). when system boot, the speaker of the board sounds beep, like everything is good, but no video. And yet the card plugging in the board, but...
Hello friend,
Please i think you card is not acceptable by the system, or have you checked another card on the system to see if it displays the same thing. And when you remove the card the system boots normal without any error. So check on the card make a change on it.
Jul 04, 2011 | Creative Labs 3D Blaster 4 Titanium 4200...
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
Jun 12, 2010 | Dell PowerEdge 1600...
Monitor (no signal) after replacing mother board and CPU
try only connect Monitor and keyboard, and check for booting (disconnect all the rest (HDD, CD DRIVE, Sound Card, Network Card, ....) then try connect one by one and always off to change hardware config.
If dont work with monitor and keyboard, try reset bios(jumper),check again, then replace memory modules (must be compatible to new motherboard), evan dont work, send back the motherboard for defective motherboard.
Jan 14, 2010 | Gateway Intel (El Paso 2) Motherboard P4...
I have hooked everything up and the monitor shows " no signal".
are you using the onboard? video... or a seperate vid card? if it was working and then suddenly quit? the onboard vid chip is out! cant replace that either try adding a seperate vid card and reboot
Jan 13, 2010 | E-Machines eMachines Desktop PC
Monitor comes on a boot then goes black
check video card it may be going out
Jul 08, 2009 | Computers & Internet
I was trying to hook up 3 monitors on my dell optiplrx gx620 with a new video card- then i put 2 video card hoping to get 3rd monitor working ---now i dont get any display and alarm sounds when i turn on...
Take out the two last cards you added and boot again.
Then turn it off and insert only one card at the time to find which one is the faulty.
Good Luck!!!
Mar 12, 2009 | IBM NetVista PC Desktop
Monitor stays black until boot up to Desktop
you use a graphics card as your main output?
and you have onboard graphics output too that you dont use?
if so then you will have to plug your monitor lead into the onboard output socket to see bios. i think you need to go into bios and change which device starts from boot.
it sounds like you have the onboard graphics as your boot device and windows using the graphics card.
Feb 26, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
No display at post
There are a few things that can cause no display on the monitor.
That single beep means POST = Power On Self Test. Post has tested everything on you're board to be good.
The cable between video card & monitor may be bad or not connected correctly (Swap out the cable as last resort).
2. You're monitor is defective, try swapping it with known working monitor.
3. You're video card is not functioning.
Lastly, when you reset the system cmos/bios everything went back to default. This means you're bios is now using the onboard PCI video graphics. Remove you're radeon 9600 video card. Try booting the system. You should see display again. The only way to test you're radeon would be to boot to the bios & set bios to boot using the AGP radeon. You need to change Init Display First to AGP & not PCI. If you loose video than you know you're AGP card is bad. Reset the cmos/bios before adding another AGP card or you will not get display. This setting is on pg 3-5. Integrated Peripherals. If you need you're manual you can download it from this link: http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Good Luck!
Mike
Jun 06, 2008 | Power Color RADEON 9600 (128 MB) Graphic...
MONITOR GOES BLANK
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
Aug 19, 2007 | Dell Dimension 4600 PC Desktop
Compaq Presario R3000Z Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
