Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Western Digital My Book... Problem
I disconnected it incorrectly like you described, seems i lost the partition, how did you get the data back? 250GB WD essential
  • alex perucho Apr 05, 2008
    I unpluged my 250 gig essential edition and now the only thing that is on is the green light No noise or nothing shows in my pc .I get a messahge that says can not detect network or F: DRIVE, I have tons of work in it what should I do? .
  • 106 Answers
1. YOUR EXTERNAL HARD DRIVE CASING WHICH HOST IDE TO USB CONVERTER HAS GONE UNSERVICEABLE, YOU CAN GET THAT FROM MARKET, ITS CHEAP, REMOVE THE OLD ONE AND ATTCH THE NEW ONE AND RECONNECT TO USB.
2. IN MARKET THERE IS IDE TO USB COVERTERS ARE ALSO AVAILABLE, U CAN TRY THAT ALSO, IT WILL ALSO COST SAME.
Posted on Apr 05, 2008
SOURCE:
Lost data
Easy Drive Data recovery would of been my first pick!
Oct 25, 2012 | Western Digital 250GB MyBook External USB...
Western digital my book data recovery
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. So really, you need to act quickly.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
May 08, 2012 | Computers & Internet
Lost pictures
Depending on the exact failure, you have a couple of options. A friend of mine had a similar drive with important photos an it turned out the drive itself was OK, the enclosure had failed. I removed the drive from the enclosure, and connected it to another system with a drive adapter, and recovered the data.
If the actual HDD in the enclosure failed, you can contact a data recovery company like www.drivesavers.com and get an estimate on data recovery (Generally very expensive, just depends on the importance of the data)
May 25, 2010 | Western Digital WD Passport 250GB Portable...
My external hard drive icon does not appear on my desktop. I am running mac os 10.5. I used disk utility. The icon appears, but my only option is to erase the disk along with the data on it. How do I...
Try the drive on a windows machine and a Linux machine. It depends on the drive has been formatted. If ex fat or fat then it should be read on a mac ok. If NTFS or Fat 32 then a windows machine should see it.
Dec 30, 2017 | Western Digital 250GB My Book Pro-External...
Accidentally disconnected external HD while moving files
have the files been deleted from the laptop? if not i would simply do a fresh format on the external and re migrate data. if they are then you can get software such as undelete or recover my files to restore your deleted data off of your laptop drive.
Dec 09, 2009 | Western Digital My Book Essential 1TB...
Same WD Passport problem as By sowhatbks on Oct 06, 2009
I'm afraid your data is most likely gone. The drive volume label "My Book" is not there because the partition is corrupt or it was deleted. You can try to recover the data with a bootable disk utility but this seldom works. I would delete the partition, run a WD utility to check the disk, (You can download it from WD web site) Then, if the disk tests ok, create a new partition and format it.
Oct 16, 2009 | Western Digital 250GB MyBook External USB...
If i re creat partition my data in disk is lose ? which is placed in other drives...
If you have your data in other drives then you do not loose anything. Only this drive data will be lost as the whole disk is formatted after partitioning.
Sep 20, 2009 | Western Digital 250GB MyBook External USB...
HDD data recovery
most hard drives have that erie only 2 partitians at a time this is with your computer how it can handle since you made three particians there is a chance that it only allows partitions of only 2
say for instance you have a celeron your comp would only allow what you memmory can give you this would knock out the 2 partician when created the 3rd partician
not enough memmory to fill all 3 partitians
safe end to this particians in long run can hurt your comp more than help it i suggest buying another hdd to make your back ups or get a portable pull out system hdd this ensures your files are as easy to get as putting in a new hard drive
hope this gave some insite
Apr 29, 2008 | Computers & Internet
Is there a way to recover lost data from my Western Digital My Book??
Yes, there is a way to recover lost data from a WD drive.
Best regards!
Jan 06, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
209 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
