Smartlock code i have a phillip/magnavox tv and some channels are coming up blocked. i have turned off all of the "smartlock" settings and i have no channels blocked. how would i reset the tv for a code? it says please enter code. i never had this problem before and i had this tv for about 7 years. i dont think i still have the book. please help even my soaps get blocked sometimes!!!! Got a used TV from a friend and there are a number of channels that are blocked. The original owner does not remember the access code. Is there a method to master reset this SmartLock thing or is the TV a throwaway just because of this channel lock? What a waste!
  • bunty2 Jun 06, 2008
    i have locked sign on tv screen
  • christy esquibel Oct 18, 2008
    I have the same problem! help please! all of the sudden all my channels have a block that reads "PROGRAM BLOCKED DUE TO U.S. PGTV TV-PG RATING STSTEM". The television is asking for a 6 character password needless to say i have no clue what this password is. Any suggestions?
I used the following that I found on a site that compiles v-chip reset solutions:
Philips and Magnavox:
Philips sets use a four digit code to control the v-chip. The override code
for Philip sets is 0711, although it may say "Incorrect code" the first time
to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To
use it hit the MENU key to get to the menus. Go up or down until you reach
AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow"
key on the remote. Enter the override code, and enter it a second time if it
says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right
arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to
MASTER DISABLE and press the "right arrow" key so that it says "MASTER
DISABLE ON". The v-chip is now reset.
Posted on Apr 03, 2008
Anyone know what the code is to get my tv unlocked?
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Jul 05, 2012 | Philips Magnavox 27MS343S 27" TV
Cant unlock tv because the code 319753 mute is no longer working
Hello
OK.
Aug 01, 2011 | Philips 20PT6441 20" TV
Hi my TV has a picture of a padlock and i cant unlock it tried to use remote it wont work it is a magnavox 29inch
hi,
For unlocking you tv you have to reset its v-chip. Do the following for the same.
ok
Apr 11, 2011 | Philips Magnavox 20MT133S 20" TV
I bought a used TV with an existing access code. I don't know the code and some channels are blocked. How do I disable the code? or reset it?
Hello
First disabel the lock and re-enter your own lock code. For this do the following.
OK.
Jan 10, 2011 | Philips Magnavox TS3260C 32" TV
Need code for tv remote to operate tv by the remote
Hello
You cannot change Parental
Control settings without
knowing the secret code. If
your code changes, someone
else has altered it and possibly
viewed blocked channels. Yet try the following procedure:-
Philips sets uses a four digit code to contro the V-Chip. The override code for Philips set is " 0711 "
OK.
Dec 28, 2010 | Philips Magnavox 27MS343S 27" TV
El tv dice blocked by autolock channel blocking access code
Hello
Your TV is locked I thinks.
Read this well before you proceed
although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code , and enter a second time it it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, goto BLOCK, and push the "right arrow" key. Go to Blocking Options and press "right arrow" key. Goto master disable and press the right arrow key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Dec 04, 2010 | Philips Magnavox 27MS343S 27" TV
I have accidentally turned the child lock on and then turned of the tv and when i switch it back on it comes up locked on the screen and none of the buttons respond and i do not have the remote controll...
Get a Magnavox (or Philips, same company) brand universal remote and try this. I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set), so I don't know if really a solution.
Philips sets use 0711 as the override code to defeat parent lock. You may need to enter the code twice if it says "invalid code" the first time.
Using the remote control:
Press the MENU key. Scroll up or down until you reach AUTOLOCK or SMARTLOCK. Press the "right arrow" key. Enter code 0711. Enter it again if it says invalid code.
Once in the AUTOLOCK or SMARTLOCK menu:
Scroll to BLOCK. Press the "right arrow" key. Scroll to BLOCKING OPTIONS. Press the "right arrow" key. Scroll to MASTER DISABLE. Press the "right arrow" key. This should unlock the parental control.
Hope this works for you. Thanks for using Fixya!
Mar 12, 2010 | Philips 28PW6305 28" TV
Smartlock on Magnavox TV
Chek in the back of the tv if there is a tiny button, probalbly that you have to use a ball pen to hit it, that says "RESET". press and hold it for 10 seconds an release it.
Nov 05, 2008 | Philips Magnavox TS3260C 32" TV
Phillips/magnavox smart series
I have a Smart Series 32" Phillips-Magnovox TV I bought april '99. Around July 4 weekend 2008 it decided it just does not want to come on any more! Was working just fine before that...I can not find my manual. Any suggestions?
Thanks,
cely
ceorunner@aol.com
Mar 04, 2008 | Philips Magnavox 27MS343S 27" TV
Smartlock code
1.Press MENU to show the on-screen menu. 2. Press VOL+ or VOL- to highlight SET. 3. Press CH+ or CH- to highlight PARENTAL CONTROL. 4. Press VOL+ or VOL- to display the SECRET CODE screen. 5. Press VOL+ (on the remote) and the CH+ button on the front of the TV at the same time. 6. Press the Number buttons to enter a four-digit code. The code will appear on the screen as you enter it. The code "0000" is the default of the TV. If you have not set up a code previously,then "0000" is the code.You cannot use "0000" after you set your own code (unless you reset the code to "0000"). 7. Press MENU to save the code.
Oct 10, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
480 people viewed this question
Top Televison & Video Experts
Electro Med Services...
