Question about Panasonic Lumix DMC-FX01 Digital Camera
Flash is not working for me
Even though i have selected flash to auto still not flash at all. i think its gone bad.
PS
    Problem Solver:
  • 3 Answers
Try cleaning your battery connections
Posted on Apr 06, 2008
SOURCE:
Flash on camera not working lg viewty
hi, even i have the same problem, probably i don't think the flash doesn't work, but even i didn't know how to use it. however, the instruction manual says there are 3 options in flash, they are auto- that is it turns flash automatically on when it turns on. red eye reduction that is it says it will flash twice to reduce red eye but i never see the flash on and the flash off, that is it will not turn on and usually whenever you exit the camera the flash will default to turn off mode. you will need to switch the flash back. hope you understand.
Jan 20, 2010 | LG KU990 Viewty
Sony CYBER -shot DSC-w190 does not flash when taking picture although flash auto on
It will only flash when there is not enough available light when in AUTO flash mode.
To flash no matter what, go into the camera setting and select that choice.
Normally something like demand flash or a symbol that looks like a lightning bolt. Then it will flash every time. That does use more battery power though. By the way, I like that setting better too.
Dec 29, 2009 | Sony Cyber-shot DSC-W190 Digital Camera
SONY DSC-H50 WON'T LET ME CHANGE FLASH SETTINGS ON AUTO ADJ SETTI
Select upper jog dial on Auto (green mark) and have flash options.
you maybe changing desired selections which are preset on that particular selection.
let me know what selections you want to change on what settings?
Dec 24, 2008 | Sony Cameras
Flash will not atomatically flash/can't change flash setting
Do you see any flash error code on lcd screen? if no then...
Flash will work when camera will set on auto mode ( green mark on jog dial) and you will see flash icon on lcd screen.
Dec 12, 2008 | Cameras
Lg viewty camera flash not working
This worked for me: I turned the ISO to 800 and set the flash to "auto" - even in quite bright light the flash still goes off so I'd definitely try this. To turn the image stabiliszer off, press the "unlock" button next to the shutter on the side of the phone.
Dec 02, 2008 | LG KU990 Viewty
How do i set flash for just one flash. it goes off many times for each shot even though "auto" is selected. thank you.
Depends on the camera. Most cameras set on auto that multi flash is only to make sure that the sensor inside is getting the right amount of light. What type of camera is it?
Apr 28, 2008 | Cameras
G9 flash
My flash doesnt work either. Holding the flash button down doesnt do anything either (in program mode)
Apr 08, 2008 | Canon PowerShot G9 Digital Camera
How to switch on Auto Flash in Auto mode
Put the camera in "P" and press the flash button above the lens release. If the flash pops, than you probably just have too much light to need it when you are in auto. The flash button is not active in auto so if the xti doesn't want the flash in auto, u can't make it fire. If the flash button does not make the flash pop in "P", search this site for another post about flash not working and u will find that this could be the flash deactivation button in the hot shoe sticking. Not likely though with a new camera unless u have had a speedlite mounted alot.--
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Dec 26, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Multiple flash firing
I would double check all your settings - even though you say it is on any flash setting, it sounds like it is using the nighttime flash setting (which does 2-3 rapid fire flashes).
Just go through every setting in the camera, and make sure that everything is set how you really want it, INCLUDING the daytime/nighttime, etc.
On the CAPTURE menu, check your adaptive light setting and make sure that you don't have it tweaked in some way to make the camera think EVERY picture is a nighttime picture.
I'd also check your "EV COMPENSATION" and "WHITE BALANCE", making sure those are set to "auto".
Hope that will work for you - good luck!
Oct 12, 2007 | HP Photosmart M22 Digital Camera
Flash out of sync
I just had mine fixed by nikon and it seems as though the problem would come back every now and then. my current solution is to switch over to Manual mode and turn AF assist, AF illumination, and ISO control to "ON" and then then shoot a few shots. Then switch metering to centerweight. take a few shots, it should work correctly, then switch back to AUTO. after that, the flash should fire as normal. I just received my body back about 2 weeks ago, so i hope my "bad batch" flash unit was replaced with a known good one. if not, i don't know what to do.
Sep 18, 2006 | Nikon D50 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
132 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
