Question about ASUS M2N-MX Motherboard
Turbo C is not running.
I have a problem with this board while using Turbo C.
when i start Turbo C, Black screen come...Turbo C is not starting...
  • 1 more comment
  • mahesh_10_ju Oct 06, 2008
    same problem i am facing ASUS M2N-MX mother board
  • donald anup Nov 29, 2008
    the problem is it is asking for 16 bit colour info
  • raku306363s May 11, 2010
    use another graphic card
  • 76 Answers
Sir
First Give full details about *********** Board for exam: 845 gvsr , Asus, Gigabyte, Mercury,
ok any way i think command is running Proparly or not working telme ? id : uday_uday2004@rediffmail.com
see this command : go 2 run type cmd next give path your soft ware whare is thair for : ex: c:\turboc2\tc c:\turboc\tc
your folder name give mustend shoud folder Name (turboc2 or turboc) ok
byy good luck ----vote for me --------
Posted on Apr 03, 2008
Facing
Posted on Oct 06, 2008
Misfiring cylinder 3 & 4
Sounds like a bad turbo to me. When you "kick it in", the engine falters and you get black smoke for a while. What is probably happening is that the turbo is leaking oil into the intake air stream, putting it into the cylinders with the fuel/air mix and causing one of two issues. Either the oil is inhibiting the combustion process, causing the falter and the resulting poor ignition, plus the oil, is giving black smoke, OR, the oil in the cylinders is fouling the plug momentarily, resulting in the fuel/oil being passed into the exhaust stream, burned in the catalytic converter and exits as black smoke. If it runs OK except when under turbo load, have that thing checked out ASAP. And, as far as the light staying on, most faults will set permanently after they occur three or more times within a certain period of time. This is ti ensure that intermittent faults won't cause false setting of the light.
Feb 11, 2016 | 2004 Chrysler PT Cruiser
2002 Duramax with high miles, 335k. Truck was running fine then on the way out of the driveway heard a loud "pop", engine lost power but continued to run. Now, I hear a turbo whine I didnt hear before when...
Start at the turbo and check for loose or blown air lines . Check the intercooler for cracks. The turbo whine is normal but you would not be hearing it as the turbo is controlled to vary the amount of boost needed for the throttle setting. If you have to use starting fluid to start a diesel then it is time to consider a re-ring and bearings for the engine.
Sep 23, 2013 | 2001 Chevrolet Silverado 2500HD
Landrover discovery 1998 td300 down on power
black smoke is an indication of not enough air for the fuel setting
that is from either a air leak in the intercooler or split pipes from the turbo to the manufold
turbo units will have up/down movement as there is clearance in the bushes but as indications are that the turbine is not spinning free enough I would be having the turbo serviced or replaced
Jul 04, 2017 | Land Rover 14 x 56 Cars & Trucks
About a year ago out of the blue, my laptop screen started turning off but the computer was still running. It has Windows Vista and Ubuntu. The problem was that the screen would start up normally and then...
it sounds like a mother board or graphic card problem
get a proper diagnosis from a computer repair shop but technology is improving every day and laptops are getting lighter and faster so after getting the diagnosis and quote a replacement may be the option to consider
Mar 13, 2017 | Everex StepNote SA2053T Notebook
Do not start up, black screen
I'll asume something for this one it might help. Make sure your laptop is completely turned off [No fans turn, screen black, no hard drive light]. When you then press the power button, immediately keep pressing the F8 button on your keyboard. It should then actually display two options after a while :
*Delete restore/resume point and start windows
*Resume restore/resume point
Select 'Delete restore point' and the unit should boot up fine again.
I had a unit that was basically turbo-booting into windows, but the restore point was corrupt and it always seemed it had a 'blank screen' problem.
You can also try to access the BIOS by pressing F2 as soon as the unit starts up to see if you can actually access the BIOS.
If that all doesn't help I suggest reseating RAM.
May 23, 2010 | Acer Aspire 9800 Notebook
On start up bit like exhaust blown near air box
If you have a Turbo charged engine the gaskets on the turbo are probably the culpirt. If you can lift and support the car on jack stands. Remove the lower shield from the car and inspect the turbo. You may have to remove the right frount wheel and any sheilds in the wheel well to see the turbo. The Turbo seals require relitivly high engine RPMs to seal properly. The Turbo starts to work about 1500RPM. Is it Gasoline or Diesel? The Variable vane turbos used in most USA,VW's after 1999 will start to work slightly earlier. The type of engine oil you are using, is it up to WV specifications could also be a factor. Not all synthetic oils are alike.
Upon inspection look fordark grey/black sooty deposits indicating where your leak is comming from.
Oct 10, 2009 | 2006 Volkswagen Jetta
I have got a Toshiba Equium A200 series that won't bootup
if the fan is not running continuously then its the fan ans board problem.because the board is getting hot and fan is not running so the board is getting overheated and the machine is nor working.and if the power light is ON and fan is running but only the screen is black/blank then its the problem of inverterboard.the cost of new board is $25 get it replaced fromn near by laptop repair center. thanks.
Aug 30, 2009 | Computers & Internet
Runs rough then clears up &runs great
found waste gate on turbo sticking freed up ok now
Sep 21, 2008 | 1991 Volvo 940
ABOUT TURBO C++
Vista doesn't support full screen mode while operating Turbo C++,
and its also doesn't support graphics(bgi) while operating it.
There are lots of compatibility problems with Vista --
I have Vista Home Premium and have warning when I start VC++ 2005 Express!
I just tried running tc.exe and did not get the warning message you reported.
Although it would only run in the small window.
Your best bet is to download either VC++ 2005 Express or Dev-C++.
They both run full-screen.
Sep 10, 2008 | Computers & Internet
How to run turbo C editor in full screen in windows vista
HERE is the simple trick :To use Turbo C++ IDE in windows 7 or in Vista; For those who wants to learn C/C++ just uninstall your "Graphics driver "
For that Computers->properties->device manager->Display Adapters->graphics driver version u have uninstall that...And after log off Run your "C:\\TC\\BIN\\TC.exe".it will open in full screen...
for more visit www.hackersorigin.com
or
forum.hackersorigin.com
Mar 22, 2008 | Computers & Internet
ASUS M2N-MX Motherboard Logo
786 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
