Question about Xtant A3001 Car Audio Amplifier
Lanxar VW12D no sound after excess play
Running two 12 Lanxar DVC's in enclosed box. 4000 watt 286 VIBE amp. 2 ohm stable. Had voice coils bridged and amp bridged. Thinking this is 1 ohm load.? After losing one sub, removed subwoofers bridged on amp and ran as stereo. Switched 10 gauge wire, one sub plays with same wire, the other doesn't. I hear the scratching noise if I run the speaker wire over the terminal but nothing else. Sub doesn't even sound blown.
Left fuse was blown. Replaced. Same problem. Only thing I haven't done is replace the 60 amp fuse under the hood.
The other subwoofer works fine off the same channel as the one that didn't. Verified channels are fine. What else can I check?
  • 3 more comments
  • Dalynn Turner Apr 03, 2008
    Hazardsneon:
    "Sub doesn't even sound blown" aka: can't hear the cone unraveled; like the sound of someone shaking something; I guess is how you describe it.
    I read somewhere to hook the subwoofer up to a battery and it should pop if it is still good. I haven't had a chance to try it though. I do have a multimeter though. Not very fluent in it's use though.
    We are in a massive thunderstorm area, so it may be a couple days before I get to test the voice coils. Uggghhh...
  • Dalynn Turner Apr 06, 2008
    Hazardsneon:
    I was able to unlock the voice coil after tapping the + and - on the battery terminal. Later found out that both subs work. Yay! Further diagnosis, I found if I switched the RCA cables around on the RCA jacks the opposite channel on the amp would work. So looks like I have a ground wire on the RCA connector that has lost connection. Is there any way I can replace the connector. Can't afford 40 to $50 pair of RCA's LOL! Also I have two 4 ohm Dual Voice Coils. I believe my sub locked up when I was running the sub's at 1 ohm (could be wrong). I had sub's wired in parallel and bridged on amp. Amp is only 2 ohm stereo stable. Believe I burned RCA connector which caused 30 amp fuse on amp to blow... Am I correct?
  • Dalynn Turner Apr 11, 2008
    Hazardsneon:
    Hmmm..? I ran my subs in parallel and unbridged the amp. Not sure what the diff. is though.? I bought a pair of home audio Gold Series plated RCA's for $15. Sound great on amp! Radio Shack paid me $10 to take them off their shelf LOL! Hense... They were originally $25 ;) I didn't know you could hook up Home audio RCA's on car audio though. That's awesome!
    I thought I had blown the fuse... But I didn't *weird*. I replaced it, because I thought that's why the left channel wasn't working. The ground on the connector had burned, so I think the sub got locked up when the RCA connector fried. You know how you hook up the RCA's and the sub's start working. I was thinking along those lines. On to new problems. LOL! Now I don't have any sound on my EQ Pro Audio class. What Gives?!
  • Dalynn Turner Apr 14, 2008
    Andrew a.k.a. Hazardsneon:
    I have a American Pro Bass Machine Power Equalizer V.S. 1471 that I bought from a liquidation sale. Pretty standard spec's.
    7 BAND ACTIVE GRAPHIC EQUALIZER WITH VARIABLE SUBWOOFER/FADER CONTROL, 4 CHANNEL OUTPUT, 50W MAX POWER
    7 BAND PASSIVE EQ
    SUBWOOFER VARIABLE FREQUENCY CONTROL
    SUBWOOFER PRE-AMP LINE OUT
    SUBWOOFER LEVEL CONTROL
    4 SPEAKER HOOK-UP
    HIGH & LOW LEVEL INPUT
    DUAL LED LEVEL METER DISPLAY (R & L)
    FADER/VOLUME CONTROL
    POWER ON/OFF SWITCH
    BYPASS SWITCH
    HALF DIN MOUNTING
    DUAL COLOR FACE ILLUMINATION
    CD JACK INPUT
    Picture at:
    http://www.americanproaudio.com/accessor...
    Didn't see a gain on the back anywhere though.
    Let me make sure I'm getting this right. The low level input goes to the headunit. Output goes to the amp, right? I didn't get any sound from the amp preouts either on the EQ.
    I wasn't able to get power at first, because I had a bad ground. So I hooked it up straight to the battery and it lit up. So I went back and got it to power up with the headunit, now I don't even get a scratching noise from the 3-ways when connected to the EQ. I opened it up. Looks like I might have burned a resistor or transistor, ( I see a brown spot) but I don't understand the mechanics behind system boards. If you want I'll write a post so you can get credit for this. You can email me at [email protected] if you would rather, but I definitely appreciate the help =)
    Hazardsneon:
    Any way you can make me a wiring diagram for a 4 ohm load? When I look at all the diagrams on the internet they don't show you how to wire it outside the box LOL!
    Novelist:
  • 100 Answers
I'm not understanding what you mean by the "Sub doesn't even sound blown" if it doesn't play at all. One thing you can check is if you gently push in on the cone you shouldn't hear anything, if you hear a scratching noise and can feel resistance then you have a problem. If you have an OHM meter, you can check the voice coil impedance, it is a down and dirty way of checking to see if it is good or not. Measure all of the voice coils that you have and they should all read about the same, not necessarily exactly the same but pretty close. This test should tell you a lot. If it seems to test out fine there is something wrong else where. Let me know if you need more help.
-Andrew Hawkins
Posted on Apr 03, 2008
  • 1 more comment
  • Andrew Hawkins
    Andrew Hawkins Apr 04, 2008
    Well when you hook the speaker up to the battery. make sure you hold one wire on and only tap the other. Do not hold it on or you will probably wreck the sub. With the multimeter, just set it to OHMs and in the smallest OHM setting. Best of luck.
    -Andrew Hawkins
  • Andrew Hawkins
    Andrew Hawkins Apr 07, 2008
    In my experience I would say that the RCAs and the blown fuse are coincidental. To fix the RCAs you could go to a radio shack and they would have an RCA jack that you could solder on. Or, they do make relatively inexpensive new RCAs that are good quality. For the blown fuse, it was because you are presenting a 1 OHM load on a 2 OHM stable amp. What you need to do is wire each sub in series and then in parallel at the amp. So at each speaker you should have 8 OHMs then at the amp you will have 4 OHMs. Unfortunately, this is the best you could do with this amp/sub combination, with out blowing fuses or possibly the amp. Good luck man.
    -Andrew Hawkins
  • Andrew Hawkins
    Andrew Hawkins Apr 11, 2008
    I'm happy you got your system working again. I just looked at the specs on the amp and you will get the most out of it if you wire the voice coils in series, the subs in parallel and bridge the amp. The spec that told me was 1x4000 watts at 4 ohms bridged. The way you currently have it, you will get 2x1650 watts and 2 ohms. Believe me, in this case you would want to go in that direction. So, what is the exact model of the EQ? and what exactly does it do or not do? I remember one time I had an EQ that had an AUX input and I thought it was burned out, but I found out it had a gain on the back that was turned all the way down. Let me know.
    -Andrew Hawkins
SOURCE:
Do you bridge a 850.4 four channel amp when it is 2 ohm stable and ur subs are wired up as series/ parallel and there 2 ohm dual voice coil speakers
If you wire 2 ohm dvc speaker parallel that would give you a 1 ohm load. If your amp is only 2 ohm stable that would not work. You would have to wire the speaker in series giving you a 4 ohm load. Then you can bridge the 4 channels into 2 with each speaker running at 4 ohms.
If you want to run a 2 ohm load use all 4 channels on amp and speakers. No need to bridge.
For 2 ohm DVC:
Parallel = connect both + and - together. = 1 ohm
Series = connect + from 1 channel to - from the other channel. = 4 ohm.
Jul 06, 2014 | Car Audio & Video
Can someone please show me how to wire my subs to amp.. i have a 2600 watt planet audio 2 channel amp (2 ohm stable) and my subs are soundstream tarantulas t4 12s 900/1800 watts total. they are 1 ohm subs...
for your subs and amp the best way would be for the speakers to be wired in series1ch (mono or bridged)to have a 4 ohm load to your amp stable at 2 ohms
see pic for wiring diagram for 2 1 ohm dvc subs wired in series.
you will need more than one speaker wire for wiring the subwoofers coils(positive & negative terminals) together
hope this helps :~)
Mar 03, 2014 | Car Audio & Video
I have two different sets of hook ups on my Power Aucoustik 10" Sub. Do I hook up both sides?
Depending on the PA FUBAR you have. The voice coil on those subs are DVC. Dual Voice Coil. You need to know a couple things. What kind of amp are you going to run on it. And what is the resistance (OHM) rating of each voice coil. MY two 12's are dual 4 ohm. Meaning that there are essentially 4 speakers to hook up. My amp currently is not 2 ohm stable in bridged. So what I did is run each speaker in parallel (red2red,black2black) then run to the box terminal. So now the dual 4 ohm voice coils are basically 2 ohm. I have 2 speakers. Now I hook the box up in series. To bring the now two 2 ohm speakers into one 4 ohm speaker. This is called series/parallel setup. My amp sees this box as 1 channel @ 4ohms. The downfall to this is the output of the amp is divided up into each speaker. So instead of sending all 1400 watts to one sub. I will send 700 to each sub. But here is a catch. even though each speaker is half the total wattage it will still be 3db louder. Meaning it will be as loud as 1 sub running 1400 watts. To conclude i need to know how many of those subs you are going to run on the amp.. And the model number of the amp so I can match up your wiring.
Jun 06, 2011 | Power Acoustik FUBAR-12W Car Subwoofer
Need help wiring 2 ohm L7's optimally please!
It depends on how long you plan on running your amp when you listen to your music. If you like it loud for a long time, I would kep our speaker load at 2 ohms to keep your amp cooler. If its for car audio competitions where it wont play for so long, ! ohm would give you higher output but heat up your amp faster. Are the subs 2 ohms at each voice coil or 4 ohms? Bridge your voice coils together in parallel then bridge the 2 speakers together in series. That should work fine for you.
Feb 24, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a 2500 watt legacy ice amp and im tryin to hook it up to two 900 watt rms soundstreams daul voice coils whats the best way
If you amp is 1 ohm stable you can run + to +, - to - on each voice coil. Wire them into the box. Run +'s to +'s on amp, - to - on amp
Other wise. If it is a 2 ohm stable amp, you run two 4 ohm dual voice coils to the amp + -, + -
If the subwoofers are 2 ohm, run + - on only one voice coil to the box for each and run + -, +- for 2 ohm load on amp or + - bridged for 1 ohm load.
I hope that makes sense.
Dec 03, 2009 | Legacy Audio ICE LA798 Car Audio Amplifier
To get the most power what is the best way to connect paraelle or
run them straight and dont use the cross over. One speak on right channel and the other on other channel. Then turn up amp settings 7/8 the way up and control the rest from your dvd/cd player. I recommend some monster cable which is very thick. Ground the amp directly to trunk bolts but make sure to scrape the paint off or the connection will be bad. You can also use a cap which will send battery pulses to amp much quicker.
Nov 19, 2009 | Lanzar VIBE286 Car Audio Amplifier
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Want to bridge 2 channel amp to push single 4 ohm dvc sub
Hello k_rabbit89,
A 4 ohm DVC sub can be wired in series like you described for an 8 ohm load or the voice coils can be wired in parallel for a 2 ohm load.
If your 2-channel amp isn't stable down to 2 ohms when the channels are bridged (most 2-channel amps are only stable to 4 ohms when bridged), you do not want the voice coils paralleled. The amp will overheat, go into protection mode, and eventually fail completely. A sub with 2 ohm voice coils would be a better fit. That way, you could series the coils for a 4 ohm load and the amp would operate OK with the channels bridged into that load.
But anyway, for the best power from THAT amp to THAT sub, your best wiring solution would be to wire each voice coil to a separate channel. The problem with that is that the signal to each coil needs to be EXACTLY the same or you will have one coil trying to move the cone out while the other one tries to move it in. You can closely approximate identical signals on the output side by using the same input to both channels. Do this by using only one RCA connection (either right or left channel) from your head unit and split it with a "Y" cable.
Hope this helps.
Sep 12, 2009 | Car Audio & Video
Amps on woofers are fine just won't hit
your probably making your amp run to low ohms if its a 2 channel amp bridged to one channel you can probably only run it at four ohms
Also seeing as your subs are 2ohm dvc you can't wire them individually to 2ohm and use each channel separately. So i'd recommend buying a 2ohm stable monoblock or running it at four ohms. a 1400 watt amp'll still pound at 4ohms and it'll extend your amp's life span
Aug 29, 2009 | Pioneer GM-7200M Car Audio Amplifier
2 ohm speakers wont work on a lanzar max pro 4000 watt
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
Xtant A3001 Car Audio Amplifier Logo
200 people viewed this question
Top Xtant Car Audio & Video Experts
Eric Sutherland
Tom Chichester
FastHarley
FastHarley
Are you a Xtant Car Audio and Video Expert? Answer questions, earn points and help others
