Question about Dell Inspiron 8500 Notebook
Dell inspiron 8500
I boot up into windows xp home edition and i boot up successfully and then all the text in the display are in coding.. no english or unicode. I dont know what to do especially since its not in english, so how do i fix it. also the display drivers must be corrupt.. doesnt show display properly. so.. yah please help me
  • Dell Master
  • 13,433 Answers
Could you possibly take a picture of the laptop screen?
Posted on Apr 03, 2008
Im in need of a password for a dell laptop inspiron 8500 windows xp PLEASE
Go to www.ebay.com Type: administrator password you should be presented with a list of sellers, choose the one that handles Dell, better chance of success.
Apr 11, 2012 | Dell Inspiron 8500 Notebook
Dell computor message on a black screen windows root \system 32\hal.dill what do I do
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
May 16, 2011 | Dell Microsoft Windows XP Home Edition
Tried to start my dell inspiron 1521 laptop, and invalid partition type on a black screen came up and will not load windows. i have window xp home edition, x65 on it. this is the first time it's happened...
Is this system in dual boot mode?I guess the primery OS has failed due to which you are facing this issue.Try doing a factory image restore or try a repair installation of windows XP
Dec 26, 2010 | Dell Inspiron 1521 Laptop
Dell Inspiron 530s/531s desktop, Win. Xp home...Windows stops responding at the ''Loading Personal Settings'' cannot boot in safe mode.
try to boot in "Last good known configuration settings" by restarting your pc and then press F8 before windows appear and then select the boot option i mention above. if this not work since you said that it can't boot to safe mode, your other option is to repair the windows or else reformat it. when you repair the windows you must have windows xp home edition cd installer, you load it to your cd/dvd rom and then restart your pc and press F2 or DEL button before windows appear in order to go to setup bios settings. in bios settings, you choose boot order setup and setup first priority to cd/dvd and press F10 by saving the changes and then press any key when you see the prompt so that it can boot up to windows xp home cd installer and then follow screen instruction that you arrive to windows repair option.
Mar 27, 2010 | Dell Inspiron 530 Desktop Computer
Installed a rangeplus adapter on dell 1000 inspiron xp sp3 home
See if you can go into safe mode by hitting the F8 key right after the dell splash screen and right before the XP splash screen comes up. If you can get into safe mode try to uninstall the rangeplus adapter and try reinstalling again after rebooting the system normally.
Nov 15, 2009 | Dell Inspiron 1000 Notebook
System Boot Up Display changed from English to another language
Go into Control Panel> Regional and Language Option,Double Click
*Click on the Languages tab
* Click on the Details button
Under Default language, select English : If English is not a choice, you can click Add, and add it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2008 | Computers & Internet
Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
May 29, 2008 | Dell Inspiron 8500 Notebook
Laptop display goes black and then rebuilds each window
this is problem with operating system or with the RAM,Try re-installing Operating system..If still Happens Change the RAM
Apr 01, 2008 | Dell Inspiron 8500 Notebook
Dell inspiron 7500 pentium 3, 18 gigs
Hopefully your other OS's are on a different drive letter (d: or e: for example). As long as they are then there is no conflict with XP.
You could effectively remove access to them by editing c:\BOOT.INI . Note that you will have to right click boot.ini, select "properties" and remove the "read only" and "hidden" properties for the file before editing it. I would recommend making a copy of the boot.ini first for a backup.
Then just open it with notepad. There will be one line for each OS in there. just delete the extra lines. Then you can just erase or format the partitions for the other OS's.
Dec 13, 2007 | Dell Inspiron 2200 Notebook
Open Questions:
Dell Inspiron 8500 Notebook Logo
87 people viewed this question
Alun Cox
